what good a cheap av receiver for a simple 2.1 setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-24-2012, 08:03 PM - Thread Starter
mike kaw's Avatar
im looking for suggestions and advice. i have limited budget.
Im planning to get a simple 2.1 setup for my dad. he wants a simple receiver with decent sound quality.
I was going to buy him a sound bar but change my mind when I remembered, had I an extra pair of unused polk tsi100s. . ill worry about the subwoofer later.
so here are my choices:
pioneer 522 or 521
yamaha 373 or the 371
denon 1312 or 1311
onkyo 309 or 313
mike kaw is offline
post #2 of 8 Old 07-25-2012, 12:00 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
any of those would work for a simple 2.1 setup. The only drawback of the two Denon's your listed is that they don't have any room calibration at all. The other 3 brands do. If you want to get a Denon, don't go lower than the 591 or 1612.
http://www.crutchfield.com/p_033AV1612/Denon-AVR-1612.html?search=denon_avr_1612&skipvs=T
The Denon 1612 actually has better room calibration than the other receivers you listed since it also EQ's the subwoofer.
Afro GT
afrogt is online now
post #3 of 8 Old 07-25-2012, 07:53 AM - Thread Starter
mike kaw's Avatar
1612, Audyssey MultEQ eq subs, its a little more over my budget ill keep that in mind.
whats is the most reliable brand on my list?
mike kaw is offline
post #4 of 8 Old 07-25-2012, 09:23 PM - Thread Starter
mike kaw's Avatar
found a used denon 2808 for sale around the same price as a new receiver. are used denon amps safe? is the denon 2808 a good model?
mike kaw is offline
post #5 of 8 Old 07-25-2012, 09:41 PM
afrogt's Avatar
Liked: 755
The Denon AVR 2808 will be better than any of the entry level models you were looking at. More powerful too. it was originally a $799 receiver. And it has Audyssey MutlEQ XT which is even better than the version on the 1612.
As long as 2 HDMI inputs is enough for your needs I'd snag that receiver. It also has a phono input in case your dad plans to connect his old turntable.
Afro GT
post #6 of 8 Old 07-26-2012, 04:27 AM
jdsmoothie's Avatar
Quoted: 12079 Post(s)
Liked: 5501
Although the 2808CI is the predecessor to last year's 3312CI and current 3313CI and as afrogt notes uses the higher version of MultEQ XT for better sound quality, it does not feature the Audyssey Dyn EQ/Vol capability nor does it use the nicer GUI the 1612 uses both of which your Dad would better appreciate considering his simple setup. Also you're likely better served going with a new (w/2 year warranty) 1612 for easier setup and use as opposed to an "unknown" condition used unit.
jdsmoothie is online now
post #7 of 8 Old 07-26-2012, 08:36 AM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
You can get a Denon 1612 for around $200, and that is a very good receiver.
commsysman is offline
post #8 of 8 Old 07-26-2012, 09:28 AM
afrogt's Avatar
Liked: 755
If the AVR-1612 @ $200 is over your budget how little were you expecting to pay for those other receivers?
Afro GT
