Integra Dtr 7.9 - AVS Forum
post #1 of 6 Old 07-25-2012, 08:09 PM - Thread Starter
ar19's Avatar
How do you disable Dolby Digital on a DTR 7.9? Thanks
ar19 is offline
post #2 of 6 Old 07-25-2012, 08:17 PM
WiWavelength's Avatar
Simple. Do not input a Dolby Digital format signal.
AJ
WiWavelength is offline
post #3 of 6 Old 07-25-2012, 08:18 PM - Thread Starter
ar19's Avatar
in my other outputs it is not on. How do I disable it?
ar19 is offline
post #4 of 6 Old 07-25-2012, 08:22 PM
Why? Dolby Digital decoding is automatic. It is required with Dolby Digital format signals and is disabled with other format signals.
AJ
post #5 of 6 Old 07-26-2012, 06:20 AM - Thread Starter
ar19's Avatar
ok because i thought i hit something on the tuner and messed it up. So dolby digital is automatic?
ar19 is offline
post #6 of 6 Old 07-26-2012, 09:45 AM
No, the FM tuner and Dolby Digital are completely unrelated.
AJ
User Tag List
