ARC between RX-A810 and Panasonic GT50 - AVS Forum
post #1 of 3 Old 07-27-2012, 11:08 PM - Thread Starter
hotsho111's Avatar
Hey, I have a quick question I was hoping I could get some help with.
I have my Panasonic GT50 hooked up to an RX-A810 receiver using ARC (Hdmi 2 from the tv).
ARC works but every time I turn off the tv it seems to reset (it shuts the receiver down with it). In order to get it working again on the receiver I need to go to setup and turn arc off, then back on and it works fine.
Any idea how to avoid needing to do this every time I turn on the tv?
hotsho111 is offline
post #2 of 3 Old 07-28-2012, 02:18 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 611 Post(s)
Liked: 1370
If it's resetting then something is wrong with the implementation. Your best bet may simply be using an optical cable from the TV to the AVR which is actually the better connection as it will pass DD 5.1 from DD 5.1 sources (eg. Netflix) whereas the HDMI(ARC) connection will only pass PCM 2.0.
"JD" – jd@avscience.com ; shop.avscience.com ; 585-645-1006, AVScience - Authorized dealer for AV Gear
Mon - Fri: 8am – 8pm EST (Sat/Sun too, will return call if I don't pick up)
Call for pricing on Denon, Marantz, Yamaha, Onkyo, Klipsch, Def Tech, Oppo, Parasound
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #3 of 3 Old 07-28-2012, 03:32 PM - Thread Starter
hotsho111's Avatar
I'll give that a shot then.
Yamaha Rx A810bl Receiver
Gear in this thread - A810bl by PriceGrabber.com
