Official Pioneer SC-68/67 Thread - Page 63 - AVS | Home Theater Discussions And Reviews
post #1861 of 1867 Old 02-10-2015, 06:52 PM
Elite Jake's Avatar
Pioneer says its all in the encoding. That all Discs don't have signal there.... :-(
Mains-Klipsch RF82ii Center-Klipsch RC 64ii Front Height-Klipsch Quintet II Surround-Klipsch Synergy S-1 Surround Back-Klipsch RS62ii Sub-Definitive Technology PF15TL Receiver-Pioneer Elite SC-65 BluRay-Pioneer Elite BDP-62FD Power Conditioner-Monster Power HTS 3600 Display-VIZIO M801d-A3
Elite Jake is offline
post #1862 of 1867 Old 02-13-2015, 08:05 AM
Dust Bubble's Avatar
Hey guys I have the SC-67 and when I plug my I-phone inthrough the usb port and select the i-pod option I am able to play my musicbut for some reason my subs don’t work. Can anyone potentially tell me why my subs aren’t working and how topossibly make them work with the music? I'm guessing its some sort of setting?
Dust Bubble is offline
post #1863 of 1867 Old 03-02-2015, 09:50 AM
Beerce's Avatar
Hi all,
As I'm not an owner, maybe this is in the wrong thread but at the same time this is where the most SC-67 relevant info and expertise seems to be so I apologize if so.
Would anyone bother buying a used (although claimed unused i.e. BNIB and with receipt from authorized dealer and 2 years on warranty) one of these at this point or get something newer? If so, what price would you consider a good deal? Hopefully without biasing the answers, the asking price on this one is $1000 CAD.
Thanks in advance.
Beerce is offline
post #1864 of 1867 Old 03-12-2015, 12:35 PM
gizmofanv's Avatar
AirPlay Issues
Lately, I have been having playback issues with AirPlay.
Symptoms and signs....
  1. First song plays fine but fails to play next selected song
  2. Songs from first playlist plays fine but fails to play next playlist
  3. While playing second song or playlist, AirPlay connection drops after few seconds. Looks like receiver is dropping it. Image on TV screen displays partial image - like good old image rolling (vhs) but horizontally
  4. Was not able to update to latest firmware using network - had to use USB.
Tried following but no luck
  1. Same issue with multiple iOS devices
  2. Same iOS device work with VSX-44 without any issue
  3. Changed network cord from one port to another - direct connection to router
  4. Restarted, unplugged for few minutes, removed and inserted network cord after 10 min
  5. Restarted router
Potential issues but not tried yet:
  • Network cord
  • Receivers network port
Hope someone has answer to this issue. Thanks in advance for your input.
gizmofanv is offline
post #1865 of 1867 Old 04-04-2015, 05:18 PM
realnt's Avatar
factory reset
Did you try factory reset it worked for me i thought network port was dead.......
realnt is offline
post #1866 of 1867 Old 04-07-2015, 10:04 PM
Hawkrider's Avatar
Well, I got the UE22 error and its unrecoverable. All the resets and attempts to clear it have not worked. I even tried force updating the firmware but it hangs at 45% and then gives "Update Error 1". UE22 happened about a month ago and resetting worked temporarily. It's still under warranty so I'll be getting it fixed. Hopefully the part will be unavailable and Pioneer can send me a new SC-87. This sucks...
Hawkrider is online now
post #1867 of 1867 Old Today, 01:31 PM
Hawkrider's Avatar
Update: My SC-68 is at the repair shop and has been there for about a week. Had to go round and round with Pioneer because the shop I bought the unit from is no longer an authorized dealer. They dropped Pioneer about a year ago. Pioneer used their CURRENT list of dealers and initially denied warranty. That got resolved, but now the part is on backorder until the end of June! I did not get a top of the line receiver to have it sit in the shop for 3 months! Music and movies are a major pastime for me and my family. I've owned Elite receivers for many years (started with a TSX-45TX, then an SC-37), and if this isn't resolved to my satisfaction then that will done with Pioneer.
I have opened a case with Pioneer and will be requesting a replacement SC-89. I use the USB-DAC feature with my HTPC and the SC-87 doesn't have that feature and it's a less expensive unit than the SC-68 was anyway. Their only choice is to replace it with the SC-89, honestly.
Greg
Pioneer , Pioneer Elite Sc 67 9 2 Channel Thx Select 2 Plus A V Receiver , Pioneer Elite Sc 68 9 2 Channel Thx Ultra 2 Plus A V Receiver , Receivers Amplifiers
