Yamaha HTR-7065 or Denon AVR-2312CI? - AVS Forum | Home Theater Discussions And Reviews
Old 08-01-2012, 12:00 PM - Thread Starter
acamato's Avatar
I was all set to get the 2312CI from EE and then I heard that Costco carries the HTR-7065 for $479. Would be about $50 cheaper out the door then the 2312.
They have very similar features. Why should I go with the Denon over the Yamaha?
I am replacing a Onkyo TX-SR875 with one of these.
acamato is offline
Old 08-02-2012, 12:02 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Denon benefits
3 year warranty
Audyssey MultiEQ XT which also EQ's the subwoofer
Yamaha benefits
dual HDMI outputs
7.1 preouts to add an external amp.
Costco return policy
You'll have to decide which of those differences is more important to you.
Afro GT
afrogt is online now
Old 08-02-2012, 03:10 AM
jdsmoothie's Avatar
Quoted: 12087 Post(s)
Liked: 5502
If you use a sub in your setup, audio fidelity wise it would be a downgrade going to the Yamaha (ie. no sub EQ) while the Denon uses the same version of Audyssey as is used in your current Onkyo.
jdsmoothie is offline
Denon Avr 2312ci Receiver , Yamaha Htr 7065
