Ticked off at my BB rep... Biamp question for center B&W CMC2 and Pioneer Elite 65 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 29 Old 08-01-2012, 10:36 PM - Thread Starter
native's Avatar
I got the Pioneer Elite 65 for my B&W CM9 fronts and CMC2 center. The speakers are bi-amped and the BB Magnolia guy swore that I can use the two fronts and center all in bi-amp configuration.
Well, shame on me for not checking the manual thoroughly before buying the thing but clearly this model doesn't but the 67 model does..
Before I go and return this thing, do you guys even think it'll be worth the upgrade so the I can have bi-amp in the center?
I would think the B&W should have good passive crossovers but I'm not sure how much better the active bi-amp from the receiver will be.
Thanks for any thoughts on this
native is offline
post #2 of 29 Old 08-01-2012, 10:47 PM
derrickdj1's Avatar
Quoted: 982 Post(s)
Liked: 714
The avr is not active bi-amp. For active Bi-amping you need external amps and another xo network. That is a great avr, why return it? It has more than enoungh power for your speakers. You can always add external amps to the SC 65 pre-outs if you think you need more power. Each extra gain in audio performance cost $$$ . To go from 98 to 99 may not even be audible. My Klipsch RF7's are 250-1000 watts and the Center is 200-800 watts and my Pioneer SC 35 handel them with no problem. If you need more power, get more effiecient speakers. You are correct that the passive xo are well design and getting an active one may not give you a better sound.
derrickdj1 is offline
post #3 of 29 Old 08-01-2012, 10:57 PM
afrogt's Avatar
Quoted: 1364 Post(s)
Liked: 947
I don't think I've ever seen a AVR that has built in biamping for the center channel. One may exist but I've never seen it.
Not that it makes a difference anyway....
Afro GT
afrogt is offline
post #4 of 29 Old 08-02-2012, 12:39 AM
Kilian.ca's Avatar
Liked: 37
The pointless practice of using an AVR alone for bi-amping needs to be added to the AVR and amp FAQ!
My N803s are only driven by a pair of 175W mono amps (previously by a 150WPC stereo amp) and aren't even bi-amped: the manual only mentions bi-wiring as the preferred method. I'd be very surprised the CMs need bi-amping or it's recommended by B&W.
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
post #5 of 29 Old 08-02-2012, 02:40 AM
jdsmoothie's Avatar
Quoted: 14609 Post(s)
Liked: 6946
Although the SC-67 can be set up to have its' amps bi-amp either the center or side surround speakers with a 5.2 setup in the main zone, as already noted, there would likely be no real added benefit in either additional power nor improved audio fidelity. What the BB sales person was more likely referring to was that you could connect an external amp (eg. XPA-3) to the FL/C/FR pre-outs and bi-amp the speakers that way rather than using the AVR's own amps as you can with the SC-67.
jdsmoothie is offline
post #6 of 29 Old 08-02-2012, 04:20 AM
Sam S's Avatar
Quoted: 218 Post(s)
Liked: 107
Forget the biamp idea.
Sam S is offline
post #7 of 29 Old 08-02-2012, 06:31 AM
oztech's Avatar
Liked: 101
I personally have never heard a difference and have tried it on my Integra 10.5 along with bridging the main amps nada not one bit of difference.
oztech is offline
post #8 of 29 Old 08-02-2012, 07:13 AM - Thread Starter
native's Avatar
ok, thanks. that's a relief.
The BB guy was specifically saying that I can connect both the fronts and the center using biamp wiring, etc.
He must have been thinking about the SC-67 version and not the 65, although he made a phone call to someone else in BB who confirmed it with it.
I'm assuming that the B&W centers have good enough cross over that even with the 67 biamp, I won't be able to tell any difference (I'm hoping). If people don't biamp the centers anyways, then maybe I'm worried about an issues that's not even there. At least I have the front bi-amped for whatever that's worth..
native is offline
post #9 of 29 Old 08-02-2012, 11:38 AM
ccotenj's Avatar
Liked: 101
it's not "worth" anything... passively bi-amping any speaker (which is what you are doing) is pointless...
- chris
ccotenj is offline
post #10 of 29 Old 08-02-2012, 12:52 PM
6sj7gt's Avatar
There is no point in asking technical questions of anyone at BB, unless you are doing so strictly for entertainment's sake.
There is, sort of, but it's buried well within the Audyssey FAQ here: b)8. Why doesn't Audyssey work properly with my AVR's 'biamping mode'?
True biamping requires an external, active crossover between the preamp and the power amp. If you do not have such an arrangement then you are simply wasting good wire and not actually biamping at all.
The form of 'biamping' in your AVR is often called 'audiophile biamping' or, less politely but possibly more accurately, 'fools' biamping'. … In other words, there is no scientifically sound reason at all why 'fools' biamping will make the slightest difference to your sound quality.
6sj7gt is offline
post #11 of 29 Old 08-02-2012, 01:07 PM
M Code's Avatar
Quoted: 798 Post(s)
Liked: 487
Keep in mind..
M Code is offline
post #12 of 29 Old 08-02-2012, 07:07 PM - Thread Starter
native's Avatar
OK, thanks. exactly what I was looking for. I guess Pioneer is FOS with their biamping support for the receiver. I mean, that's pretty crazy that they can claim true biamping, and charging the extra $$ for that...
I'm a little bit disgusted, some of it at myself for not knowing enough yet
native is offline
post #13 of 29 Old 08-02-2012, 07:27 PM
kikkenit2's Avatar
Quoted: 823 Post(s)
Liked: 305
Get over it. Almost every brand of receiver has "passive bi-amping". Much more effective is a receiver with preamp outputs.
If you buy speakers that really need lots of power connect an external amplifier. Much more effective and much more expensive.
kikkenit2 is offline
post #14 of 29 Old 08-02-2012, 08:09 PM - Thread Starter
native's Avatar
I had a call from the BB guys, saying that they can get me a deal, $200 more for SC-67.... I said I'll think about it.
SO, there's ABSOLUTELY nothing to be gained with their biamp set up and my biamp compatible center?
native is offline
post #15 of 29 Old 08-02-2012, 08:15 PM
Sam S's Avatar
Quoted: 218 Post(s)
Liked: 107
No.
Put that $200 towards an Outlaw amp if you're really hot to get more power to your speakers.
Sam S is offline
post #16 of 29 Old 08-02-2012, 08:43 PM - Thread Starter
native's Avatar
ok. only temptation was that it'll be $1200 for SC67. but I guess it's just money wasted i'll hold off. thanks
it's been a while, i need to educate myself on this stuff more
native is offline
post #17 of 29 Old 08-02-2012, 09:59 PM
oztech's Avatar
Liked: 101
The amp section in the 67 is stronger than the 65 and without A/Bing them in the same environment hard to say if you could hear the difference.
oztech is offline
post #18 of 29 Old 08-03-2012, 02:01 AM
jdsmoothie's Avatar
Liked: 6946
The 10W difference in power is moot. Choose the SC-67 only if you want a "feature" it offers that the SC-65 does not (eg. HDMI input to Zone 4).
post #19 of 29 Old 08-03-2012, 08:13 AM
oztech's Avatar
Liked: 101
I will ask the rep when we see him I don't think he was referring to the mere 10w difference he did point out the draw difference of 330 vs 370 whether that was all do to the amps or other circuitry I will have to ask unless someone here knows the answer.
I also wonder if the amps are the same why does the 68 get the Ultra spec and the 67/65 get the Select spec since they are different in ohm load and room size vs volume output according to THX.
oztech is offline
post #20 of 29 Old 08-03-2012, 08:28 AM
ccotenj's Avatar
Liked: 101
ever since the sc series came out, the sc-x5 and sc-x7 have benched very similar...
10 extra watts ain't squat... it wouldn't have an audible difference to you, no matter how hard you listened... the difference between 140 and 150 watts is tiny*... remember that you have to double the amount of power to get 3db more spl...
* heck, the difference between 140 and 280 watts falls into the "just noticeable" range in terms of spl...
- chris
ccotenj is offline
post #21 of 29 Old 08-03-2012, 08:48 AM
oztech's Avatar
Liked: 101
I know this from experience years ago when I noticed no difference adding an external amp that was only 100wpc more but I guess my question would the difference be in load ability since Ultra would be all speakers into a 3.2ohm and Select is 4ohm fronts and center while rears at 8ohm or at least thats the way I remember it correct me if wrong.
oztech is offline
post #22 of 29 Old 08-03-2012, 08:55 AM
ccotenj's Avatar
Liked: 101
oh yea, the specs are different...
however, that's where the marketing from pio comes in... once the units have gotten on the bench (at least prior to this year, and i wouldn't expect it to be any different now), the results have pretty much shown that the x5 unit would have passed the higher spec had pio chosen to license/market it that way...
it's the same marketing theory that increases the wattage by 10w or so as you go up to the next to the next level in a cem's line... we "know" that 10 more watts really doesn't matter, but a bigger number enhances the perceived value... especially for the 99.999% of the world who aren't a/v geeks, and have no clue about how stuff works...
- chris
ccotenj is offline
post #23 of 29 Old 08-03-2012, 09:02 AM
oztech's Avatar
Liked: 101
I figured as much but hated to assume.
I will say this the 57 we installed last year seems to handle anything load wise we threw at it and still sounds great using Kef towers all 5 channels that did impress me now they just need to add adjustable crossovers and bass correction.
oztech is offline
post #24 of 29 Old 08-03-2012, 09:04 AM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 274
Without malice and simply because it's one of those little things that bug me, there are two different if similar words:
"Yea, though I walk through the valley of the shadow of death . . . " (sounds like "yay")
"She loves you, yeahh, yeah, yeah.
just sayin'
Entirely agree with the points being made, BTW
JHAz is offline
post #25 of 29 Old 08-03-2012, 09:07 AM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 274
Of course, I type like crap. "yeahh?" uh, nope.
JHAz is offline
post #26 of 29 Old 08-03-2012, 09:11 AM
ccotenj's Avatar
Liked: 101
yeah, i'm a major offender there... redface.gif and i really should know better... redface.gif
especially since i have a few pet peeves along those lines as well... i dunno how many times i wish a poster would hit his internal mute button when a point is moot... wink.gif
edit: lol... biggrin.gif the thing is, i'm a wicked good typist on a keyboard, and equally wicked bad on my ipad... redface.gif writing approximately 5 zillion lines of code will do that to a person... tongue.gif
- chris
ccotenj is offline
post #27 of 29 Old 08-03-2012, 09:15 AM
ccotenj's Avatar
Liked: 101
yup, good figuring...
and yes to all 3 of those things... the sc's have never been shy about handling a difficult load, and those 2 features are notably lacking..
- chris
ccotenj is offline
post #28 of 29 Old 04-03-2013, 08:50 AM
i3arnstormer's Avatar
Hey I know this is an older thread but I just got a SC-67, CM9's & CM Center 2 and was searching for the same answers you were. This is the responce from B&W on the subject.
Hello, hope you are well
depending on your receiver and how much power you are sending to the speaker we do like BI-amping the front left and right channels this will send more power to the speaker allowing you to push your receiver less to get the same output. when bi amping you are sending the same signal to the HF and the LF terminal but the signal is coming from separate channels on your receiver. For the CM9's I would set the crossover at 60HZ.
I also sent a simlar question to Pioneer I'm still awaiting their responce.
i3arnstormer is offline
post #29 of 29 Old 04-03-2013, 09:20 AM
and here is Pioneer's responce
Thank you for contacting Pioneer Electronics (USA) Inc.
I would suggest making the connection and see if you can hear the difference. Some people can hear the difference, while others can not.
The signal would be the same to both terminals, so you speaker would need to filter the signal.
Sincerely,
Rocky
Customer Service Representative
