Pioneer PC control - AVS Forum
post #1 of 7 Old 08-04-2012, 04:36 AM - Thread Starter
HMontauk's Avatar
This may be an easy question, but Is there a way to operate Pioneer receivers from a PC? I have a VSX-60. I know that there's an app to control from iphone/ipad but want to know if I can control from my laptop as well.
HMontauk is offline
post #2 of 7 Old 08-06-2012, 04:36 PM - Thread Starter
HMontauk's Avatar
Anyone know if this is possible?
HMontauk is offline
post #3 of 7 Old 08-06-2012, 05:33 PM
M Code's Avatar
Quoted: 83 Post(s)
Liked: 117
The VSX60 does have a rear panel RS232 serial port for control..
Usually these are for some of the custom controllers available like from Crestron
You should check with Pioneer support and check if they will supply the codes for PC control...
M Code is offline
post #4 of 7 Old 08-07-2012, 01:48 AM
eNorm's Avatar
I know there is a software to control some receiver,
I think its for the Sc series, just check on the Pioneer web site.
http://www.pioneerelectronics.com/PUSA/Support/Home-Entertainment-Custom-Install/Detailed+Product+Information/A+V+Receivers
I have the SC-65 that i would like to control over my pc,
I download the file 2012 PC Setup software..
but the problem is it need a password to extract the file.
anybody know???
Norm.
eNorm is offline
post #5 of 7 Old 10-22-2012, 01:28 PM
PubFiction's Avatar
I know this is old but I was looking for this too. One option you have is to use a virtual machine to run android on your PC this will allow you to use any android app. I have used this to control my harmony link from my PC. One fairly easy to install VM is blue stacks, but it is rather annoying with ads and only worked right one 1 of 2 machines. Given the correct network settings and no silly behavior from the receiver software engineers I would think you could get this working.
PubFiction is offline
post #6 of 7 Old 03-25-2013, 08:49 AM
JoeBoxster's Avatar
Hi,
Its pioneerci.
JoeBoxster is offline
post #7 of 7 Old 08-12-2013, 01:11 PM
surfertom's Avatar
thanks for the Password!
it worked just wish i had more customization with the speaker set up.
surfertom is offline
User Tag List
