Only center and right play in Dolby modes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 08-04-2012, 05:55 PM - Thread Starter
strakele's Avatar
Quoted: 88 Post(s)
Liked: 104
I just set up my HT system tonight - Denon AVR-1712 with Jamo S606 5.0 speakers (sub on the way).
Ran setup wizard, Audyssey, etc and everything is going fine. Listened to some stereo music on the towers and everything sounds good. Switched over to cable to watch some Olympics and put it in Pro Logic mode to get most sound from the center, with a bit of fill from the L/R. However, in either Dolby mode, only the center and right speaker play... nothing from the left.
Any ideas?
strakele is offline
post #2 of 18 Old 08-04-2012, 05:58 PM
Socketman's Avatar
Quoted: 130 Post(s)
Liked: 149
are you using a dvr and if so how is it connected to the reciever
Socketman is online now
post #3 of 18 Old 08-04-2012, 06:01 PM - Thread Starter
strakele's Avatar
Quoted: 88 Post(s)
Liked: 104
Motorola cable box for Comcast, connected with composite A/V cable (stereo audio, video, red/white/yellow)
Going to see if we can get one with HDMI, but that's what we got for now.
strakele is offline
post #4 of 18 Old 08-04-2012, 06:11 PM
Socketman's Avatar
Quoted: 130 Post(s)
Liked: 149
reverse the 2 audio rca cables see if the sound changes to the opposite speaker
post #5 of 18 Old 08-04-2012, 06:20 PM - Thread Starter
strakele's Avatar
Quoted: 88 Post(s)
Liked: 104
Yes, it does change to the left.
strakele is offline
post #6 of 18 Old 08-04-2012, 06:39 PM
Socketman's Avatar
Quoted: 130 Post(s)
Liked: 149
bad cable or cable box or check the settings in the cable box.
if you have another cable substitue
btw yellow is a composite cable ,i dont what tv you have but composit is a terrible way to connect your video unless you are still watchin a tube tv. at least go component.
post #7 of 18 Old 08-04-2012, 06:43 PM - Thread Starter
strakele's Avatar
Quoted: 88 Post(s)
Liked: 104
But in stereo mode, left and right play just fine. Same with virtual and multi ch stereo. From the cable box input.
strakele is offline
post #8 of 18 Old 08-04-2012, 06:52 PM
Socketman's Avatar
Quoted: 130 Post(s)
Liked: 149
post #9 of 18 Old 08-04-2012, 07:01 PM - Thread Starter
strakele's Avatar
Quoted: 88 Post(s)
Liked: 104
Yeah it's just the Dolby modes that don't work right.
strakele is offline
post #10 of 18 Old 08-04-2012, 07:07 PM
Socketman's Avatar
Quoted: 130 Post(s)
Liked: 149
do you have another 2 channel source you can try or maybe a different input to isolate. Is this a new reciever or new to you, maybe do a reset and start over. procedure is in the back of the manual
post #11 of 18 Old 08-04-2012, 07:17 PM
jdsmoothie's Avatar
Quoted: 12208 Post(s)
Liked: 5559
Try resetting the microprocessor on the 1712 (p. 96 OM).
jdsmoothie is offline
post #12 of 18 Old 08-04-2012, 07:22 PM - Thread Starter
strakele's Avatar
Quoted: 88 Post(s)
Liked: 104
It was a Best Buy open box item. From the DVD source and Aux input (both stereo, not HDMI) Dolby modes work correctly. It's just the cable that doesn't. Weird.
strakele is offline
post #13 of 18 Old 08-04-2012, 07:36 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi strakele, does your cable box not have digital audio out coaxial or optical jacks? If so use the digital connection instead analog (red/white).
JChin is offline
post #14 of 18 Old 08-04-2012, 07:39 PM
Socketman's Avatar
Quoted: 130 Post(s)
Liked: 149
i suggest you do the reset since it was open box and someone else had a go at it.
post #15 of 18 Old 08-05-2012, 12:16 PM - Thread Starter
strakele's Avatar
Quoted: 88 Post(s)
Liked: 104
The cable box only has analog out... another reason why I'm hoping to get one with HDMI. I'll try the factory reset.
strakele is offline
post #16 of 18 Old 08-05-2012, 01:21 PM - Thread Starter
strakele's Avatar
Quoted: 88 Post(s)
Liked: 104
Did the factory reset and also bi-amped the towers. In Dolby PLII or Pro-Logic, the left speaker still does not play from the cable box, but does in stereo modes. Any other ideas?
strakele is offline
post #17 of 18 Old 08-05-2012, 01:41 PM
Socketman's Avatar
Quoted: 130 Post(s)
Liked: 149
what happens if you feed the cable box into the dvd source input.
post #18 of 18 Old 08-05-2012, 04:24 PM - Thread Starter
strakele's Avatar
Quoted: 88 Post(s)
Liked: 104
Cable box into DVD input works correctly.
Swapped cables completely, and it seems to be working. Though first time I tried swapping through the different sound modes, on the DVD input, in Dolby modes only the center was playing. But now swapping between all modes on both inputs, everything is working.
Weird.
strakele is offline
