Denon 790 vs Onkyo709 Specs HUH?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-06-2012, 10:38 AM - Thread Starter
RyanJE's Avatar
Hi ALL,
I am looking at two AVRs. I currently have a Denon 790 and it sates the power is 90W per channel for each channel seperately.
I was looking to upgrade to an Onkyo tx-nr709 and it says the power is 110w per channel 2 channlers driven?
Can that be right? Can the Denon 790 really drive each channel at 90 with the same distortion level the Onkyo 709 can only drive 2 channels at 110? Here are the specs..
ONKYO
Power Output
Front L/R
110 W + 110 W (8 ohms, 20 Hz-20 kHz,
0.08%, 2 channels driven, FTC)
130 W + 130 W (6 ohms, 1 kHz, 0.1%,
Center
Surround L/R
Surround Back L/R
Or is the Denon really also 2 channels driven like the Onkyo?
RyanJE is offline
post #2 of 5 Old 08-06-2012, 10:50 AM
jdsmoothie's Avatar
Quoted: 12105 Post(s)
Liked: 5508
Denon AVRs are generally rated into 2CH as well, as are most AVR brands, although regardless the difference of 20W/CH would be moot. The 709 is more in line with the 2312CI, and both use Audyssey MultEQ XT which would be an upgrade over the MultEQ used on the 790.
jdsmoothie is offline
post #3 of 5 Old 08-06-2012, 01:17 PM - Thread Starter
RyanJE's Avatar
Jd, thanks for the input.
How come the website and manual for Denon says that all channels are rated then? I am confused.
Surely I would rather keep my Denon if its 90w x all channels vs 110 x 2 on the Onkyo.
RyanJE is offline
post #4 of 5 Old 08-06-2012, 02:51 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
I highly doubt you could tell a power difference between those two receivers....
Afro GT
afrogt is offline
post #5 of 5 Old 08-06-2012, 03:59 PM
jdsmoothie's Avatar
Liked: 5508
What a mfr uses as it's "marketing" rating and the actual benchmark testing values is very different. The 709 is a more powerful AVR than is the 790.
Denon Avr790 7 1 Channel Multi Zone Home Theater Receiver With 1080p Hdmi Connectivity , Receivers Amplifiers , Onkyo Tx Nr709
