OUTLAW 975 - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #271 of 524 Old 01-07-2013, 08:33 PM
cwt
cwt's Avatar
Liked: 32
Originally Posted by lonwolf615 View Post
thanks colin, that makes sense. You're right, it is good to know, but I can't help feeling now that the Emo quote is vaguely misleading.It is a plus that the 200 has two chips of course, but weighed against other factors I'm still leaning towards the outlaw,
Its good that theres 2 components available to suit different requirements and you cant really go wrong value wise . Exciting times smile.gif I put faith in the extra processing power enabling additional dsp modes as theres many new ones just around the corner - of course its impossible to pick which ones will succeed wink.gif [theres a dolby atmos disc available allready]
cwt is offline
post #272 of 524 Old 01-07-2013, 10:24 PM
Roger Dressler's Avatar
Quoted: 1457 Post(s)
Liked: 667
Which one is that?
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #273 of 524 Old 01-08-2013, 05:28 PM
Dave Vaughn's Avatar
Quoted: 635 Post(s)
Liked: 973
My review of the 975 just went live: http://www.hometheater.com/content/outlaw-model-975-surround-processor
ZOOM ZOOM likes this.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
My Atmos Renovation Part 1 http://www.soundandvision.com/conten...odyssey-part-1
My Atmos Renovation Part 2 http://www.soundandvision.com/conten...odyssey-part-2
Dave Vaughn is online now
post #274 of 524 Old 01-08-2013, 07:59 PM
cwt
cwt's Avatar
Liked: 32
Originally Posted by Roger Dressler View Post
Which one is that?
Should have double checked Roger was thinking of the 2l auro 3d
http://www.2l.no/e-book/2L090.pdf
Hopefully dolby wont be far behind with a taken 2 version when its cinema run ends smile.gif
http://www.dolby.com/us/en/consumer/content/movie/release/taken-2.html
cwt is offline
post #275 of 524 Old 01-09-2013, 05:40 AM
lonwolf615's Avatar
Quoted: 33 Post(s)
Liked: 134
Read it earlier in the day, didn't even grasp the fact it was you. smile.gif Great review, I almost subscribed to the mag on the spot based soley on your review. And it pretty much cinched it for me-the 975 sounds perfect for my needs. Kudos to you and to Outlaw.
"There is no truth. There's just what you believe."
lonwolf615 is offline
post #276 of 524 Old 01-09-2013, 08:49 AM
Quoted: 635 Post(s)
Liked: 973
post #277 of 524 Old 01-09-2013, 11:22 AM
biggerdave37's Avatar
Thanks Dave - great review. Any ideas on how the 975 would perform with a vinyl setup? I know I would need a phono preamp but was more curious about how the 975 treats the analog signal. I currently have a Parasound 5250 amp and was thinking of getting the Parasound 2100 (with bypass) for 2.1 channel music playback and the the 975 for everything else.
biggerdave37 is offline
post #278 of 524 Old 01-09-2013, 04:03 PM
Quoted: 635 Post(s)
Liked: 973
Dave,
When I compared the analog output with FLAC files over a Squeezebox versus the digital, I thought they both sounded great. Same thing using an Oppo BDP-95 via analog stereo into the 975. In my treated room both sounded excellent. One caveat though...I'm basing the audio on the price of the pre/pro, which performs much better than its cost. I'm sure there is better out there for significantly more money. Does that make sense?
post #279 of 524 Old 01-09-2013, 07:43 PM
Thanks Dave I understand exactly what you're saying. I ordered the 975 and am going to try it out with my vinyl set up first and go from there. I also have the old Oppo BDP-83 Special Edition so real curious how it will sound via analog stereo. At least I'm confident the 975 will handle everything else I need an av processor for. Thanks again for the fine review.
post #280 of 524 Old 01-09-2013, 07:51 PM
Quoted: 635 Post(s)
Liked: 973
Let me know what you think of it when it arrives.
post #281 of 524 Old 01-09-2013, 08:10 PM
Audiophil's Avatar
Thanks Dave, nice review!
As for analog in to the 975 well it does go through a ADC like any other high-end pre/pro without a bypass. How much this degrades the audio by any measure would require test gear and some detailed listening. I do use an Adcom GFT555 FM tuner with my 975's analog in for my local classical station. I don't notice much difference between my old Lexicon pre/pro analog in doing the same thing. My listening is mostly red book CD and loss less Blu-Ray but Outlaw really should have added an analog pass through for the vinyl lovers.
JVC RS-40U Screening Room and Listening Room - Dedicated Home Theater Construction
Audiophil is offline
post #282 of 524 Old 01-10-2013, 05:23 AM
Does anyone know if the Analog Stereo or PCM Stereo listening modes on the 975 trigger the subwoofer? I use an Outlaw ICBM-1 for stereo bass management so I would prefer it did not.
post #283 of 524 Old 01-10-2013, 05:56 AM
bootman_head_fi's Avatar
Quoted: 530 Post(s)
Liked: 336
It should not in "direct" mode.
Are you really hearing a difference?
http://youtu.be/G-lN8vWm3m0
Set an example:
Treat everyone with kindness and respect, even those who are rude to you...
Not because they are nice, but because YOU are. :)
bootman_head_fi is offline
post #284 of 524 Old 01-10-2013, 09:30 AM
Liked: 667
The stereo modes do not, of themselves, trigger the subwoofer. That is decided when you set up the speaker bass management.
post #285 of 524 Old 01-10-2013, 11:08 AM
Great thanks.
post #286 of 524 Old 01-11-2013, 05:28 AM
3rdHerd's Avatar
great review. I am still on the fence about getting this pre due to lack of analog pass through, and no phono stage. Dave, the main question I had was about scaling, what sources did you use other than blu ray? I am into legacy equipment, and will often use the pass through, but at times I want it scaled. My current AVR does a poor job of it for sure. Is the outlaw 4k scaling? what was the issue with that? They won't tell us what chips or software are involved with the video scaling? how rude....
since the competition (emotiva) does not include ANY legacy video support, that is even worse for me than having left out only phono. I am at least thankful that Outlaw has left me an option outside of vastly expensive pre's and avr's with bloated features I will never use. (I have room correction now and never used it)
3rdHerd is offline
post #287 of 524 Old 01-11-2013, 07:40 AM
Quoted: 635 Post(s)
Liked: 973
I used a TiVo Series 3 set to native output, but granted, I don't watch much (if any) and some DVDs from an Oppo (native output). I found the scaling to be good, not great. The DVD output from the Oppo scaled to 1080p was better than what the Outlaw could do, but if your display is smaller (mine is 88 inches diagonally) you probably will be impressed. The output from the Outlaw was superior to the scaling in my TiVo.
post #288 of 524 Old 01-11-2013, 03:55 PM
3rdHerd's Avatar
thanks! I'm sure it's a step up from my HK 2700, which also does not have phono, or even pre outs. and yes, my screen is less than half the size of yours smile.gif I am afraid that if I wait much longer nothing at all will have legacy support,.
3rdHerd is offline
post #289 of 524 Old 01-11-2013, 06:42 PM
Quoted: 635 Post(s)
Liked: 973
I'm having a brain fart right now and can't think of their name, but you can buy an outboard phono "thingy" for around $30 and use that with the 975.
post #290 of 524 Old 01-14-2013, 07:46 AM
markus767's Avatar
Quoted: 3242 Post(s)
Liked: 1139
Dan Laufman (President Emotiva) claims that "the 975 DOES NOT allow for bass management and delay management with all high resolution codecs". Is that true?
Source: http://emotivalounge.proboards.com/index.cgi?action=gotopost&board=preamps&thread=28059&post=478124
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #291 of 524 Old 01-14-2013, 08:33 AM
runnin''s Avatar
Liked: 45
Yeah, that was funny, in a thread about the UMC 200, Big Dan throws that out there with no documentation or anything, and then immediately locks the thread. Classless.
runnin' is offline
post #292 of 524 Old 01-14-2013, 09:40 AM
lonwolf615's Avatar
Quoted: 33 Post(s)
Liked: 134
You need to read the last few pages of this thread. Its been covered.
post #293 of 524 Old 01-14-2013, 10:40 AM
runnin''s Avatar
Liked: 45
Lonwolf, that's the exact same thread that Markus linked to, and it only has 10 posts, not several pages. Is that what you were trying for? There's nothing in there that covers it and the thread is actually on the UMC-200.
runnin' is offline
post #294 of 524 Old 01-14-2013, 10:50 AM
markus767's Avatar
Liked: 1139
I guess he was talking about this post: http://www.avsforum.com/t/1423584/outlaw-975/240#post_22783068
Markus
post #295 of 524 Old 01-14-2013, 11:09 AM
lonwolf615's Avatar
Quoted: 33 Post(s)
Liked: 134
Sorry. I was so concerned about not sounding rude I wasn't clear. I meant this thread here, on avs...If you read back you will see I had the same concerns, was almost in a panic, really. :)The question was addressed, to my satisfaction anyways. Now my only concern is the lack of multichannel analog inputs...I've got probably 30 or so sacds, some are hybrids but some aren't. I could live with listening to the hybrids through optical but the others would be basically useless. Unless there is a work around?
post #296 of 524 Old 01-14-2013, 12:10 PM
runnin''s Avatar
Liked: 45
Funny, I made an assumption there, which was certainly jumping to conclusions, sorry about that.
runnin' is offline
post #297 of 524 Old 01-14-2013, 02:34 PM
Bill Mac's Avatar
Quoted: 1031 Post(s)
Liked: 1074
I'm surprised the 975 does not have a 7.1 analog input. If your SACD player has an HDMI output then you could go that route. But if it doesn't I'd go with a different processor so you can play the SACD layer of your SACDs.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk 1801-TLs, Salk 1801b center, ADS 300C (surrounds) and two Rythmik F12SEs.
Bill Mac is online now
post #298 of 524 Old 01-14-2013, 03:27 PM
Quoted: 635 Post(s)
Liked: 973
Guys...the 975 is only $549 and it isn't going to have all the bells and whistles of a processor that costs 3X as much (or more). At this price point there WILL be things missing such as a phono and multi-channel analog inputs. If it doesn't have something you need, then look elsewhere but be prepared to spend more money for your pre/pro. To my ears, I thought the 975 sounded great, especially for the price, but it isn't meant to compete with products that retail for north of $1000 or more.
post #299 of 524 Old 01-14-2013, 04:52 PM
Bill Mac's Avatar
Liked: 1074
Dave,
I realize the cost issue but including a 7.1 analog input would not have cost much more to add IMO. The other factor is with the 975 offering legacy video inputs one would think the same would apply for a 7.1 analog input.
Bill
post #300 of 524 Old 01-14-2013, 07:40 PM
Quoted: 635 Post(s)
Liked: 973
Bill,
I get what you're saying, but when you start adding small things one by one you end up adding to the cost significantly. Just by adding 7.1 inputs would probably required the unit to have a larger footprint to accommodate the extra inputs, which would then add to the cost and before you know it you're above the $800 level. For the target audience of this piece I would be willing to be that the majority of them are going to use HDMI for their equipment with only the occasional analog audio input.
Outlaw Audio
