OUTLAW 975 - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #331 of 528 Old 02-06-2013, 03:32 PM
dcnblues's Avatar
Originally Posted by RichB View Post
Subs produce more bass. Which according to your tastes may or may not be *better*.
...It could sound better, but I do not have many placement choices due to its size and WAF (Wife approval factors). - Rich
Roger on those comments.
dcnblues is offline
post #332 of 528 Old 02-06-2013, 03:49 PM
dcnblues's Avatar
A quick question as I'm new to multichannel audio.
I'm slowly grasping that threads like these (and equipment like the Outlaw 975) are for people who's preference largely involves flowing sound from 2 channel stereo to multichannel home setups.
But I'm on the legacy side (I want to optimize a home music server with HD files) and want to send the flow in the other direction: mostly from multichannel video down to my analogue 2 channel setup.
Existing outputs from my cable box and new bluray player have a terrible mix probably familiar to most of you - center dialogue mixed in too low to side channels, and a poor listening experience. However, I'm not that fussy for movie sound. 2 channel HD music is my priority.
I'd like to find a solution where I could put one speaker behind the couch and route the center channel there, exclude the subwoofer channel, and run some optimum mix of the remaining channels out to my analogue system. My old pre-amp does not have an HT passthrough, and I'd like to know if I could use something like an aux input on my preamp for this. I'd like to be able to balance the volume between the center channel speaker (powered?), and the other channels going to by two floorstanding speakers. This would be ideal for late night quiet tv viewing, which I need. Can the Outlaw 975 let me do this? I don't understand the output options. Many thanks.
dcnblues is offline
post #333 of 528 Old 02-06-2013, 04:51 PM
Roger Dressler's Avatar
Quoted: 1523 Post(s)
Liked: 711
The 975 will let you define a 5.1 speaker set like this:
L/C/R: on, all Large
Surround: none
Subwoofer: Yes
Connect the C output to the dialog speaker behind the couch.
Connect the L/R out to the 2-ch preamp aux in to hear music and effects at any level you like by using the volume control on the preamp. Once the ratio between this and dialog is set, use the 975 volume control.
Do not connect a subwoofer. The LFE will not be heard.
If you feed the 975 TV audio in stereo, use PLII Movie mode to extract the dialog to the center. If you feed 5.1, you will get whatever separation is in the source. Not all dialog is carried in the center, so you might hear some crosstalk into the preamp at a lower level.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #334 of 528 Old 02-06-2013, 06:47 PM
dcnblues's Avatar
Thanks very much Roger. This looks like a workable solution, though I was hoping to do this for half the price. Good looking box though, so that helps.
dcnblues is offline
post #335 of 528 Old 02-06-2013, 09:30 PM
Audiophil's Avatar
I might be missing something here, but you want to have center channel audio coming from behind your listening position? Dialog on screen in front of you will be coming from behind you with video content? eek.gif While Roger's suggestion would work, why not just use the 975's "night mode"? This will process the audio with compression and avoid large changes in audio level. The center channel audio would still remain up front too. tongue.gif
Possible undocumented feature for 2 channel people... when in 'Stereo+Sub' mode if you press the surround effect button once the 975 defaults to 2 channel only mode. This might also be helpful if you want to limit bass at night.
JVC RS-40U Screening Room and Listening Room - Dedicated Home Theater Construction
Audiophil is offline
post #336 of 528 Old 02-07-2013, 10:07 AM
dcnblues's Avatar
Actually, yes. I am SO fed up with not having control over all the different formats, differences between show / movie sound levels and commercial levels, crappy mixes from just about every source I hear, I just want some control back. I love the idea of getting control of the mix. I talked once to a theatre owner who had just redone his movie theatre, and put in top line audio, but didn't pay for THX certification because he didn't like the sound insulation / muting requirements. To him, a big room should sound like a big room, and echo had a small place in the world of high fidelity. I agree with that perspective.
I tend not to like audio rooms that have been carpeted, and use subwoofers. I like simple excellent systems with very clean midrange, and don't get off on the sensation of feeling air move my body any place other than my eardrums. I'm very suspicious of room sampling, computer processing, messing with the audio signal.
I don't want to festoon my living space with 5, 7, 12, or however many speakers some corporation is peddling in order to push me to attend theatrical movie presentation. Sensurround did nothing for me, and I have no need for or pleasure in hearing space ships or laser effects move from behind right to front left, and I DEEPLY resent having to buy a bunch of ugly boxes for my living space just to get an unmuddied mix of dialogue and other sounds (and the girlfriend wouldn't let me do that anyway).
I think stereo sound is excellent and preferable to multichannel when reproducing music, and perfectly adequate for movies and tv. I think you get a much better return on investment from two quality speakers than 12 mediocre ones, and it's much easier and simpler to balance two speakers in a room than letting some computer try to do it with multiple speakers. The more complexity added to a system, the harder it is to balance / control, and you loose more than you gain.
It would be nice if directors, actors, and sound recorders, a much higher percentage of the time, understood and appreciated that mumbled dialogue is EXTREMELY burdensome to the viewer. When that dialogue is separated into a single channel among seven, then badly mixed back in to a 2 channel output, it can be frustrating enough that viewers will rebel and look for solutions where they can bypass all this corporate trademarked multichannel garbage and get enough control to actually hear what people are saying on the extortionist cable monopoly service for which they are paying.
If they're going to separate most of the dialogue into one channel, I like the idea of taking it to a speaker much closer to my ears. I'm not delighted I need to spend $600 to do so, but I understand that production licensing of these pervasive formats means I have to shell out. But I'm going to use my box the way I want to. My brain rather easily can match dialogue from behind me with moving lips on a screen in front of me. Not going to be a problem. And as I said, low volume listening will be much clearer.
Sorry for the rant, and it's also good to know about 'night mode.' As I said, however, that's one more algorithm I'd rather not have to trust, and would rather come up with a simple solution. Many thanks for the help.
dcnblues is offline
post #337 of 528 Old 02-11-2013, 08:16 PM
Audiophil's Avatar
I am with you on most of those ideas. My 975 is in 2 channel mode 60% of the time as it makes some really nice music. We differ in that I find a properly mixed DTS-HD/Dobly True mix using high-end/high quality loudspeakers adds to the movie going experience. While technically incorrect, placing the center channel behind your listening position for better dialog can certainly be done.
The full size remotes are starting to come in as I received mine today. Outlaw included a nice thank you note for being patient and a deck of playing cards as a thank you. This combined with calling me to see if I wanted the pre-amp shipped over night for x-mas is customer service that rivals other high-end audio firms I have purchased from. Also the fit and finish of the remote puts any Lexicon remote I have owned to shame. A nice remote with classy blue back lighting, high-end sound, and playing cards, what more could you want? Ok, an analog pass through for the vinyl lovers may be. tongue.gif
post #338 of 528 Old 02-12-2013, 03:06 AM
dcnblues's Avatar
Thanks for your comments. Good to know about the remote - I was wondering a bit. Still not sure what I'll end up doing (I'm trying to figure out a design for an audio rack of some kind). Sigh. Complications, complexity, it's all a lot of work...
dcnblues is offline
post #339 of 528 Old 02-14-2013, 04:24 PM
dcnblues's Avatar
I have a new question. I'll probably be going with a 975, but rather than use the RCA output to a multichannel amp, I'll go to a powered speaker (for the center channel). Any data on output voltage for the 975? If I run an RCA to TRS / 1/4" conversion cable, can I use a long cable (25-35 feet)? Or will I need some kind of signal booster?
dcnblues is offline
post #340 of 528 Old 02-14-2013, 11:23 PM
Liked: 711
The length of cable will not make any difference, assuming you use decent cable, low capacitance, good shielding. If the sensitivity of the powered speaker is something on the order of 1 Vrms for full power, it will work fine.
post #341 of 528 Old 02-15-2013, 01:12 AM
gurkey's Avatar
Quoted: 121 Post(s)
Liked: 90
+1.
Especially look for "very good" shielding (double) on long cable runs, so you don't pick up any hum or noise on the way.
gurkey is online now
post #342 of 528 Old 02-15-2013, 02:33 PM
dcnblues's Avatar
Excellent. I was hoping that would work. Many thanks for the help.
dcnblues is offline
post #343 of 528 Old 02-22-2013, 07:14 PM
danr1707's Avatar
2 quick questions. Is the front display dimmable? and does volume changes display via OSD?
danr1707 is offline
post #344 of 528 Old 02-23-2013, 02:56 AM
Liked: 711
No. No. Those are the quickest answers I can give.
post #345 of 528 Old 03-04-2013, 06:25 AM
bootman_head_fi's Avatar
Quoted: 535 Post(s)
Liked: 340
Has anyone else seen this blurb yet?
http://news.cnet.com/8301-13645_3-57569615-47/do-separate-components-sound-better-than-av-receivers/
A little disappointing since it isn't really a fair comparison IMO but interesting nevertheless.
Are you really hearing a difference?
http://youtu.be/G-lN8vWm3m0
Set an example:
Treat everyone with kindness and respect, even those who are rude to you...
Not because they are nice, but because YOU are. :)
bootman_head_fi is offline
post #346 of 528 Old 03-04-2013, 06:45 AM
markus767's Avatar
Quoted: 3641 Post(s)
Liked: 1298
He somehow forgot to describe the test conditions thoroughly. Without it the test is worthless.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #347 of 528 Old 03-04-2013, 09:11 AM
Bill Mac's Avatar
Quoted: 1268 Post(s)
Liked: 1446
I had seen that "review" before and I agree the comparsion isn't very fair. While the reviewer was at it why didn't he connect the Outlaw amp to a Denon AVR with preouts? Then it would have been a much better comparison. But as Markus said without listing the test conditions the "review" is not worth much.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
post #348 of 528 Old 03-04-2013, 12:14 PM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
The review says more about the amp than the preamp.
But I suspect the conclusions are valid.
Here is the hometheater mag reivew of the Outlaw 7500.
Check you the 1974 Dahlquist DQ-10 (LCR) speakers used for this review.
An this person felt this was the proper speaker to make judgements about bass performance. eek.gif
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is offline
post #349 of 528 Old 03-07-2013, 02:15 PM
guisar's Avatar
You could also get a second hand AVR (like the Pioneer VSX-023THX, around $150) which has 7.1 or 5.1 analogue unbalanced I/O and use that instead of the 975. This would both be much less expensive initially but there'd be virtually no (or a lot less) depreciation if/when you decided to get rid of it. It would probably also do a much better job than the 975 as the Pioneer and similar AVR of it's (2009) vintage have pretty decent room correction, parametric equalization and the ability to customize the crossover and routing of audio signals in and out of the line-level I/O.
guisar is offline
post #350 of 528 Old 03-07-2013, 07:43 PM
ZOOM ZOOM's Avatar
Quoted: 12 Post(s)
Liked: 25
Do you mean the VSX-1023THX at $500.00+? I could not find the vsx-023THX. the 1023 does not have pre outs, that counts me out, I need pre outs.
I am debating on the 975 or the Marantz NR1403 at under $400.00.
Edit: My mistake... you mentioned second hand.
ZOOM ZOOM is offline
post #351 of 528 Old 03-18-2013, 07:36 AM
amatuerholic's Avatar
Quoted: 514 Post(s)
Liked: 281
What I'm looking to do is have a stereo setup for a bit, with the potential to expand to a home theater after. The integrated amplifiers available to do what I want are all around the $800-$2,000 price point (Creek Evolution 5350, Plinius, Krell KAV, Marantz PM8004).
For that price, I was thinking that going the route of a 975 + 2200 monoblocks would be a better financial move ($1250) and allow for easier upgrades in the future. The only thing stopping me are reliability of the pro, future resale value (especially if I buy one of those integrated amps used), and AVRs like the Yamaha RX-A720 which are $100 more and provide the amplification for surround channels at a lower cost. With the AVR I'd still buy the monoblocks for stereo listening, but I'm not too concerned when it comes to surround sound. Any advice for what I'm looking to do while keeping the cost under $1200-$1500? For what it's worth, I'm planning on running Dynaudio C1s in the front (long-term) but am currently using the Focus 140s.
amatuerholic is offline
post #352 of 528 Old 03-24-2013, 03:49 AM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
I currently have a denon avr and if I have audyssey turned off the bass coming from my hsu vtf15 is ok for movies. When audyssey is on (which is how I have it) bass is awesome . Way more and powerful with audyssey on. I know 975 doesn't have room correction but has anyone come from an audyssey based receiver to the 975 ? If so was the amount of bass the same with the 975 ? I don't have dynamic eq or dynamic volume on with the denon.
chalugadp is offline
post #353 of 528 Old 03-24-2013, 03:49 AM
chalugadp's Avatar
Liked: 1505
post #354 of 528 Old 04-01-2013, 12:44 PM
bozobuttz's Avatar
I just picked up a used Outlaw Model 7075 amplifier to use with my GoldenEar surround sound system and Pioneer Elite receiver. Well, I quickly discovered my receiver does not have pre-outs and I am in need of a preamp! The seller also had his Outlaw Model 990 preamp for sale but I took a pass, as it would not fit my HDMI needs. So now I am looking at getting either this Model 975 or the Emotiva UMC-200. This will be my first entry into separates and I am "sonically" attracted to the prices of both. I would prefer the 975 since it would match my amp and is less expensive. However, I'm leaning more toward the Emotiva at this point based on price/features. I would pull the trigger on the 975 if it was $499 shipped!
bozobuttz is offline
post #355 of 528 Old 04-02-2013, 08:40 AM
Quoted: 535 Post(s)
Liked: 340
The UMC-200 has the PEQ function enabled and the auto speaker setup enabled, other than that they do use the same chipset.
Also the way the 975 is implemented it may not allow for bass management and delay management with all high resolution codecs.
You should contact Outlaw about this if you think it may affect your system. (It may not in all cases)
Set an example:
post #356 of 528 Old 04-02-2013, 09:07 AM
Dave Vaughn's Avatar
Quoted: 895 Post(s)
Liked: 1346
I've reviewed both (Emotiva review should be online this month) and both pre/pros outperform their price by a wide margin. If you need room correction, then the Emotiva would be a good choice. If you need legacy video support, then the Outlaw. Both sound great.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
My Atmos Renovation Part 1 http://www.soundandvision.com/conten...odyssey-part-1
My Atmos Renovation Part 2 http://www.soundandvision.com/conten...odyssey-part-2
Dave Vaughn is offline
post #357 of 528 Old 04-02-2013, 10:36 AM
bozobuttz's Avatar
Hi Dave, I already read both of your reviews. Thanks. I am not convinced that I *need* room correction. Maybe I am naive, but receivers of yesteryear such as my old Sony did not have room correction yet it sounded pretty darn good in my room. I have not been very impressed by my Pioneer receiver's MCACC EQ feature so I have it turned off anyway. I agree whichever model I choose, it will sound good.
post #358 of 528 Old 04-02-2013, 11:00 AM
Quoted: 535 Post(s)
Liked: 340
Room correction should always come after room treatments.
If you have a well tamed room, you may not need RC at all.
(and not everyone cares for a "flat" sound)
Set an example:
post #359 of 528 Old 04-02-2013, 04:37 PM
chalugadp's Avatar
Liked: 1505
Not everyone can use room treatments for various reasons
. You are certainly right about not everyone having to want flat sound.
post #360 of 528 Old 04-16-2013, 04:55 AM
kucharsk's Avatar
Quoted: 1263 Post(s)
Liked: 685
Does the 975 pass/switch 4K video?
kucharsk is offline
Outlaw Audio
