Balanced vs Unbalanced - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By MichaelJHuman
  • 1 Post By Jinjuku
post #1 of 19 Old 08-11-2012, 02:55 PM - Thread Starter
bohai's Avatar
Ok so I am confused. I have been told that the balanced lines excel when the distance between the amp/preamp is considerable. But I have also been told that for short hookups, say 2-3 feet, that unbalanced lines are just fine. I have noticed that some higher end pre/pro amps do not have balanced out jacks, such as some of the NAD lines.
Comments/recommendations appreciated.
Tim in Houston
Anthem D2v(update installed), Parsound Halo A51 5 Ch Amp, DirecTV DVR(3d), LG BDP, Onkyo CD Player, Music Hall MMF 5.1 Turntable, Cambridge Audio phone pre-amp, Knoll 50 Amp whole house distribution amp, Paradigm Studio 100's, Paradigm ADP 690 Center, Paradigm Millenia Rear,...
bohai is offline
post #2 of 19 Old 08-11-2012, 04:06 PM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
Almost all pre-amps and amps that offer balanced connections are "fake". They take a single-ended line level source and split it to XLR right at the connection terminal. As such, there is little benefit to using XLR connections with these "fake" balanced components, except in the rare occasion where you need to run 50Ft+.
Sam S is offline
post #3 of 19 Old 08-11-2012, 04:32 PM - Thread Starter
bohai's Avatar
So if the source had balanced out, would it be better? Although I dont recaal any processor/preamps having balanced inputs to them . And what about optical sources to the pre/pro? Would that make balanced outputs better?
Tim in Houston
bohai is offline
post #4 of 19 Old 08-11-2012, 06:42 PM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
Most sources with balanced outputs are fake, as well. Denon has a processor with true balanced inputs.
Sam S is offline
post #5 of 19 Old 08-11-2012, 06:51 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Is it really correct to call a balanced connection fake as long as it's balanced? It does what it's advertised to do...reject common noise, right?
Seems more correct to note that you can't assume the internals are balanced just because the connections are.
GrandPixel likes this.
"But this one goes up to 11"
MichaelJHuman is offline
post #6 of 19 Old 08-11-2012, 07:12 PM
Jinjuku's Avatar
Quoted: 58 Post(s)
Liked: 148
Your statement is very much in error...
As a concrete example I have a Denon 4308Ci. It is single ended (RCA) on the sub out. If I go to my Crown's RCA in I have ground induced noise. If I convert over to XLR and then to go to XLR on the Crown: Dead quiet. It's a problem that is solved with a balanced CONNECTION. The amp and source don't to be full blown fully differential designs.
An audiophile likes to talk about how much they spent and how good it sounds.
A DIY'er likes to talk about how little they spent and how good it sounds.
Jinjuku is offline
post #7 of 19 Old 08-11-2012, 08:36 PM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
My statement was not in error. You have a ground loop hum. The OP does not. Hence the benefit of him using such connections is suspect in benefit.
Sam S is offline
post #8 of 19 Old 08-12-2012, 01:14 AM
Quoted: 266 Post(s)
Liked: 148
Well, not to pick a fight, but I think it's a distortion of reality to call the balanced inputs and outputs fake, as long as they implement the circuitry needed for common noise rejections.
Saying a product as balanced inputs and/or outputs, IMO, does not imply a promise of the internal circuits being balanced. Maybe you honestly feel it does, but I would not make such an assumption.
Also, someone has a long tow to hoe to prove that a processor with a balanced "topology" actually can make an audible difference. But that's another debate, I guess.
post #9 of 19 Old 08-12-2012, 05:55 AM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
If I put these on the pre-amp outputs of my receiver, can I now tell everyone my receiver is "balanced"? Of course not.
It's not "circuitry" in most of these products with XLR, it's a simply wiring change which is the equivalent of the adapter linked above.
That was my entire point. VERY few products with balanced connection have balanced topology. In other words, you can get the same effect by using the adapter I linked above. If that helps your situation in regards to noise rejection, that is a good thing. But there is no guaranty.
Indeed, a different discussion.
Sam S is offline
post #10 of 19 Old 08-12-2012, 09:28 AM
WiWavelength's Avatar
Quoted: 29 Post(s)
Liked: 24
You are moving the goal posts. Not once prior did you mention "topology." Yes, very few components incorporate a true differential topology. But no matter how you want to argue otherwise, many components do incorporate true balanced inputs/outputs. As long as they utilize active positive and negative leads at equal impedance about the ground, the inputs/outputs, themselves, are balanced.
AJ
WiWavelength is offline
post #11 of 19 Old 08-12-2012, 09:41 AM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
AJ
Read my first post in this thread. I specifically mentioned how most components take a single ended signal, and convert it to XLR at the terminals, i.e. fake topology.
Sam S is offline
post #12 of 19 Old 08-12-2012, 09:51 AM
Quoted: 29 Post(s)
Liked: 24
Your insistent use of the word "fake" is really unnecessary. A component with balanced inputs/outputs is balanced at those inputs/outputs because the circuitry at those inputs/outputs is differential, bar none. The full circuit topology of the component may or may not be differential -- it usually is not. But you act as if a component with balanced inputs/outputs but not full differential topology is some sort of attempt at deception.
AJ
post #13 of 19 Old 08-12-2012, 10:00 AM
gbaby's Avatar
Quoted: 558 Post(s)
Liked: 187
Balanced is better, not to be confused with beta is better.smile.gif I just purchased my first truly balanced processor, and it has a much better noise floor and is cleaner than unbalanced RCAs. Even my sub, seems to play an octave deeper.
gbaby is offline
post #14 of 19 Old 08-12-2012, 10:04 AM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
AJ
It may not be deception on the parts of CE manufacturers, but it certainly generates a lot of confusion.
As far as my use of the term "fake"... Do we consider breasts with silicone implants "real" or "fake"?
Sam S is offline
post #15 of 19 Old 08-12-2012, 11:36 AM
gbaby's Avatar
Quoted: 558 Post(s)
Liked: 187
gbaby is offline
post #16 of 19 Old 08-12-2012, 02:02 PM
Quoted: 266 Post(s)
Liked: 148
So you want these people to call their XLR connectors, with the appropriate circuitry to invert the signal as needed and such to call the inputs...what? Unbalanced?
You confuse me.
post #17 of 19 Old 08-12-2012, 03:09 PM
Quoted: 29 Post(s)
Liked: 24
If the body of the breast contains an implant, that does not make the nipple "fake." And the same is true of balanced XLR inputs/outputs, even on a component without full differential topology.
AJ
post #18 of 19 Old 08-12-2012, 06:00 PM
mmiles's Avatar
Quoted: 465 Post(s)
Liked: 214
So the nipple in a breast enhancement is like the tip of the XLR connector in these inverted connector back planes.
Mike Miles
mmiles is offline
post #19 of 19 Old 08-12-2012, 07:05 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
Me too. IDK for sure but I don't think pro analog equipment is internally balanced, generally speaking.
JHAz is offline
