How to turn Off USB port on Onkyo 3009? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-12-2012, 10:52 AM - Thread Starter
andrechaves's Avatar
Dear Fellow HT enthusiasts
I have recently acquired a USD fan as a cooling aid for my Onkyo 3009. It is the Thermaltake 23CS that was recommend in this forum.
It is connected to the rear USB port on the receiver and it does a great job in reducing the internal temperature.
However to my surprise the USD pro is powered even when the Receiver is turned off. Therefore the fan is always on.
So what I wanted to know is if there is any setting the will turn off power to the rear USB port when the receiver is turned off.
Thank you for your input.
André Chaves
andrechaves is offline
post #2 of 4 Old 08-12-2012, 11:20 AM
pukemon's Avatar
Quoted: 283 Post(s)
Liked: 71
do you have network standby or hdmi passthrough on? i believe you have to turn those off to get a full off for what you're asking. because of this, i went with a component cooler with a/c power supply on switched surge protector.
Home theater gladly not designed by ereed or bgtighe23. 65" JS9500, Marantz 7702MKII, Parasound Halo A31, ClassDaudio SDS470 4ch, RBH R56, 4xRBH R55, 2x RBH R5, Hsu VTF 2 MK 3 and VTF 3 for subwoofage, OnStage MS7701B mic stand with boom for improved Audussey XT32 calibrations. Listening space happily treated with 1" OC 703 rigid fiberglass. OPPO 203 or 205 soon.
pukemon is offline
post #3 of 4 Old 08-12-2012, 01:15 PM - Thread Starter
Yes. I have passthrough on so I can wathc TV without turning the receiver on. I will try turning those off and see if it works.
Thank you.
post #4 of 4 Old 09-11-2012, 05:22 PM
joebob296's Avatar
I am in the same boat but with the 809. I have network control enabled, when network control wasn't enabled the rear USB would lose power.
joebob296 is offline
