Denon 3312 Network setup issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-13-2012, 07:36 AM - Thread Starter
hagenstien's Avatar
Ok, I am getting frustrated and I hope I am doing something that is just incredibly stupid. I cannot seem to get the network setup wizard to work on my 3312.
I have it plugged in to a wired network with many other devices running on it just fine. However, it never seems to be able to find the network via the setup wizard. If you look at the network setting manually on the receiver it does not let you modify any of the fields. The IP address is blank, DHCP is on (cannot change it) and it will not let me change the network standby setting.
Any help is greatly appreciated!
hagenstien is offline
post #2 of 4 Old 08-13-2012, 07:46 AM
jdsmoothie's Avatar
Quoted: 15366 Post(s)
Liked: 7516
Try rebooting the router as well as the tips listed in the Denon Troubleshooting guide below ...
http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread/0_100#user_G2
For additional helpful info, join us in the Denon AVR-XX12 Owner's thread linked in my sig.
jdsmoothie is offline
post #3 of 4 Old 08-13-2012, 07:29 PM - Thread Starter
hagenstien's Avatar
So, after doing a microprocesser reset and a network card reset I still have the same issue. I also noticed that after doing the resets the port on my router is not lit up indicating there is no communication from the 3312 to the router when trying to run the network setup wizard. I can take the same ethernet cord and plug it into my PS3 and it lights up fine.
Does this mean that my network card on my 3312 is likely shot and I should pursue a warranty claim?
Thank you for your help.
post #4 of 4 Old 08-13-2012, 07:50 PM
jdsmoothie's Avatar
Liked: 7516
Repair is likely your next course of action if the network reset didn't resolve the issue.
