Using Amp for Headphones only, Do I need to put load on speaker outs? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-15-2012, 07:57 AM - Thread Starter
Eric Goldman's Avatar
I just picked up a Crown D75 to use solely as my headphone amp. Question is will the amp be damaged without some load being placed on the speaker out terminals?
If I do need to place a load...how is it done?
Eric Goldman is offline
post #2 of 4 Old 08-15-2012, 07:59 AM
hakstone's Avatar
Most audio equipment bypass speakers when headphone jack is used.
hakstone is offline
post #3 of 4 Old 08-15-2012, 08:22 AM
DonoMan's Avatar
^true, and also most modern ommercial (meaning for sale, not as in professional only or anything) amplifiers do work fine with no load. It is possible to build (and probably buy, but uncommon these days) an amplifier that does not behave that way, but that problem should be rare. Just FYI, if you needed to add a load that you don't want to actually make sound, you'd get what's called a "dummy resistor" of the appropriate resistance (8 ohms to mimic most speakers, but can vary) and power (not too hard to find ones rated to 50w or 100w).. they've got them at www.parts-express.com amongst other places.
"Vintage" is good for wine, not for A/V equipment.
-Dan D.
DonoMan is offline
post #4 of 4 Old 08-15-2012, 09:59 AM
M Code's Avatar
Quoted: 733 Post(s)
Liked: 442
DonoMan is correct..
Parts-Express has these..
http://www.parts-express.com/pe/showdetl.cfm?partnumber=019-020
You should definitely use these as your power amplifier can destroy the headphones if the level is too high, as headphones are very fragile relative to power handling..
M Code is online now
