Using an AVR without surround speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-15-2012, 07:19 PM - Thread Starter
JBWIII's Avatar
Liked: 43
What happens to the mix of--to use the simplest example--5.1-channel sound if I tell my AVR that the surrounds aren't present? Does the receiver integrate the surround channels into the front channels, or does it just disregard the surround channels altogether?
I have a Yamaha RX-V473 but anyone with knowledge of how their AVR behaves is welcome to chime in.
JBWIII is offline
post #2 of 8 Old 08-15-2012, 08:03 PM
gregzoll's Avatar
Liked: 33
It would be no different than if you had the source plugged into a old school 2 channel receiver. It will sound the same. With today's modern receivers that use Audyssey or type of computerized system, will lock out any channels not in use and turn off any type of Surround sound features.
gregzoll is offline
post #3 of 8 Old 08-15-2012, 10:25 PM
afrogt's Avatar
Quoted: 1056 Post(s)
Liked: 757
The sound originally designated for the surrounds will be sent to the front speakers.
You wont lose any content.
Afro GT
afrogt is offline
post #4 of 8 Old 08-16-2012, 05:44 AM
jdsmoothie's Avatar
Quoted: 12161 Post(s)
Liked: 5540
The former ... the AVR will downmix the audio to whatever speakers are present regardless of whether 2.0, 2.1, 3.0, 3.1, 4.0, 4.1.
jdsmoothie is online now
post #5 of 8 Old 08-16-2012, 08:21 AM
DonoMan's Avatar
Yeah, as long as you set it up such that the missing speakers are marked as such. It's possible to design an amplifier that is unstable (to the point of burning up) without a load, but any modern receiver/amp won't have that problem, at least. Not sure if they actually sold old audio gear with that trait or not (just that it's possible to build it).
"Vintage" is good for wine, not for A/V equipment.
-Dan D.
DonoMan is offline
post #6 of 8 Old 08-16-2012, 09:54 AM
tod2548's Avatar
This question may sound silly but I'm in the learning stage of things but is there an AVR that will send the unused power to the fronts when in 2.1?
tod2548 is offline
post #7 of 8 Old 08-16-2012, 10:18 AM
jdsmoothie's Avatar
Liked: 5540
Any AVR will do that as there's generally only one power supply so the fewer speakers connected means more total power is available to them.
post #8 of 8 Old 08-16-2012, 10:23 AM
programmergeek's Avatar
Actually depends on the AVR many have seprate amps or use two, three five or seven amp sections. Most have a dedicated amp for the frount channels so there would be no power difference but if iti s a cheap AVR it will not tax the power supply as much and may sond better. But this is really a specific question.
Jason
Note: Any posts are of my personal opinions and not to reflect upon any business.
Jason@programmergeek.com
908 578-6466
programmergeek is offline
