Best simple receiver? - AVS Forum | Home Theater Discussions And Reviews
Old 08-16-2012, 11:18 AM - Thread Starter
MadCash's Avatar
Hi folks.
New to the site and couldn't quite find the answer I was looking for. I have 4 in-ceiling speakers on my main floor that I'd like to hook up to my Airport Express to stream music wirelessly on my network...easy enough. What I need is a decent and small receiver to hook the speakers/airport to. Obvious needs are speaker terminals and a digital (optical) input. I really will never need anything else.
Anybody with some input?
cheers
MadCash (my kids names...not my financial aspirations)
MadCash is offline
Old 08-16-2012, 10:19 PM
JBWIII's Avatar
Liked: 43
This Onkyo TX-8050 seems to be what you're looking for:
http://www.amazon.com/Onkyo-TX-8050-Network-Stereo-Receiver/dp/B004UR486G/ref=sr_1_1?ie=UTF8&qid=1345177110&sr=8-1&keywords=onkyo+tx-8050
No first-hand knowledge of it though.
Oh wait you said "small"--maybe this one? Half the power, though, and twice as expensive.
http://www.crutchfield.com/p_642MCR603/Marantz-M-CR603.html?tp=47041#details-tab
JBWIII is offline
Old 08-18-2012, 12:10 PM
jm86wvu's Avatar
I would think that just about any receiver with A+B speaker terminals in your price range would satisfy your needs. If you're just looking for fill the room with sound I wouldn't break the bank but that's totally up to you.
jm86wvu is offline
