Receiver front wide speaker terminal question / Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-17-2012, 02:04 PM - Thread Starter
sperezmore's Avatar
Hello,
I am planning to buy a new receiver soon, probably the Pioneer Elite SC-65. Can I use the front wide speakers terminal to place two more speakers in the front? The receiver will drive the front and wide as an "A + B" speakers?
Thanks in advance.
Sergio Carlos Perez-More
My Blu-Ray, HD DVD and DVD, DVD Audio, SACD Collection
Sergio's Home Theater & Bar
"Long Live Dolby TrueHD & DTS HD Master Audio"
sperezmore is offline
post #2 of 8 Old 08-17-2012, 02:40 PM
Scout's staff's Avatar
yes see link to manual - page 19. There are several possibilities when setting up your speakers
http://www.pioneerelectronics.com/StaticFiles/Manuals/Home/SC-65_OperatingInstructions061112.pdf
Scout's staff is offline
post #3 of 8 Old 08-17-2012, 05:03 PM - Thread Starter
sperezmore's Avatar
Thanks Scout's staff.
Still I'm not clear in what configuration the sound from the speaker B terminals will be the same as the sound from the A speaker terminals without down mixing the multichannel sources to 2 channels. I want to have 4 front speakers with equal power (watts) from the receiver. Can this be possible?
Thanks again.
post #4 of 8 Old 08-18-2012, 11:50 AM - Thread Starter
sperezmore's Avatar
Anybody?
post #5 of 8 Old 08-18-2012, 04:14 PM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
Thanks again.
Yes. Set the front to bi-amp. That is true speaker A+B these days.
kikkenit2 is offline
post #6 of 8 Old 08-18-2012, 05:41 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
Thanks again.
AFAIK all A ad B speaker terminals are sim[;y two different connections to the same amps. So your two left front speakers will get the exact same signal. The connections are parallel, so you may overtax your amps by attaching a total impedance below their minima. If they are in the same space the dueling speakers will cause frequency response anomalies.
JHAz is offline
post #7 of 8 Old 08-18-2012, 05:47 PM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
Although generally true in the case of AVRs with dedicated "Front B" speaker posts, in the case of AVRs that have "assignable" Front B speaker posts (eg. Denon 7.1 AVRs), they are generally powered by their own amp, which is also likely the case here as well considering the SC-65 is a 9.2 AVR.
jdsmoothie is offline
post #8 of 8 Old 08-20-2012, 10:24 AM - Thread Starter
sperezmore's Avatar
Thank you.
