How do I stream audio from my Mac, iPhone or iPad? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-20-2012, 09:21 AM - Thread Starter
RNaval's Avatar
How do I use a Macbook, iPhone or iPad as an audio source? I've got a Harman Kardon AVR 247 receiver.
RNaval is offline
post #2 of 9 Old 08-20-2012, 09:33 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
HK AVR 247 does not have network connectivity or a USB port. Probably the best way is to get a $99 Apple TV and connect it to the receiver.
http://www.amazon.com/Apple-TV-MD199LL-NEWEST-VERSION/dp/B007I5JT4S/ref=sr_1_1?s=electronics&ie=UTF8&qid=1345476895&sr=1-1&keywords=Apple+TV
I assume you want stream wirelessly?
If not, you can use the headphone jack and connect it to the receiver with this type of cable.
http://www.amazon.com/Belkin-F8V235-09-9-Feet-Audio-Mini-Stereo/dp/B002MA8SZA/ref=sr_1_9?s=electronics&ie=UTF8&qid=1345476778&sr=1-9&keywords=mini+plug+to+rca
Even the newer HK models are lacking in connectivity features compared to Onkyo, Yamaha, Denon, Marantz and Pioneer.
Afro GT
afrogt is online now
post #3 of 9 Old 08-20-2012, 11:08 AM - Thread Starter
RNaval's Avatar
Yes, I would like to stream using WiFi connectivity (wireless) in the house. Apple TV looks to be a good solution. Is there another option for connecting a laptop to the receiver and perhaps running some type of software on the laptop and a smartphone?
RNaval is offline
post #4 of 9 Old 08-20-2012, 12:00 PM - Thread Starter
RNaval's Avatar
I just found a device - Belkin Bluetooth Music Receiver - which may provide the functionality I'm looking for.
RNaval is offline
post #5 of 9 Old 08-20-2012, 12:12 PM
spiritfox's Avatar
I also recommend the Apple TV--there is also a software solution that works great for times when Airplay is not the answer--AirFoil--give them a look too:
http://rogueamoeba.com/airfoil/
Bob
spiritfox is online now
post #6 of 9 Old 08-20-2012, 12:24 PM
danielo's Avatar
Quoted: 24 Post(s)
Liked: 53
Using bluetooth is a bad idea it will result in less audio quality. Go with the AppleTV for $99 bucks connect if you want to go wild check out music match for $25 and control it using the remote app from your iOS devices. If you upgrade your OS to mountain lion you also don't need to buy something like airfoil (still has some value) because sending audio/video from the OS is now default if machine is new(er). Other options are things like airparrot and indeed the airfoil set of tools all support lossless audio something that bluetooth won't do and you get video for free.
Daniel.
for men to evolve we have to upgrade
danielo is offline
post #7 of 9 Old 08-20-2012, 02:17 PM
ccotenj's Avatar
Liked: 101
the atv is a superior solution to bluetooth... "sound quality" issues aside, a wi-fi network is more robust than a bluetooth connection...
if all you care about is music, you could use an airport express, but once you get the atv, i think you might take advantage of it's other features... smile.gif
- chris
ccotenj is offline
post #8 of 9 Old 08-21-2012, 07:45 AM - Thread Starter
RNaval's Avatar
I did setup the Belkin Bluetooth Music receiver last night and although it provided the basic functionality I'm looking for, I wasn't impressed. I could not step more than 30 feet away from the receiver as the connection would go weak and the quality of the sound was just average. I will definitely go with Apple TV. WiFi connectivity and the sound quality of atv will be far better.
Thanks for all the "sound" advice guys...
RNaval is offline
post #9 of 9 Old 08-21-2012, 06:52 PM
mj66's Avatar
www.BeautifulClockRadio.com
It is the best way to do this and it also has replaced my old Clock Radio. i now place my iPad in a stand and use this app as my alarm-clock-radio.
mj66 is offline
