I cannot believe it...what am I missing?????? - AVS Forum | Home Theater Discussions And Reviews
Old 08-20-2012, 11:56 AM - Thread Starter
Russ Rubman's Avatar
Quoted: 54 Post(s)
I need to buy a 5.1 channel receiver urgently.
My only requirements are:
1. Silver finish
2. HDMI 1.4 (for 3D reasons)\
3. Pre-out
I want to believe that something so simple would allow me to have several choices.
Unfortunately either I am Google challenged or I am missing something eek.gif
Please please PLEASE! Someone make a suggestion.
I don't care what brand it is or if it is used, B-Stock or a legacy piece and I am only looking for a mid-price unit in the $300-$700 range.
Anyone?
Russ Rubman is offline
Old 08-20-2012, 01:11 PM
Selden Ball's Avatar
Quoted: 3052 Post(s)
Liked: 1494
Silver finish is going to be very hard to find. The vast majority (probably all) of the receivers intended for the U.S. market in your price range are black. Silver is often an option in the European market, though.
Similarly, pre-outs are only going to be available near the top of (or above) your price range, especially in current generation equipment. Cost-reduction is the over-riding factor in the current economy.
The version level of HDMI support has not been allowed to be specified on HDMI equipment since January. 3D support is available with many current-generation AVRs, but 4K support (which you didn't mention) tends to be limited to top-of-the-line models (which have list prices near or above $2K).
Hopefully someone else will be able to provide some more optimistic suggestions.
Selden
Selden Ball is online now
Old 08-20-2012, 01:37 PM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
Why the major color requirement? Silver has less distortion than black? tongue.gif
Sam S is offline
Old 08-20-2012, 01:48 PM
Paraneer's Avatar
Quoted: 25 Post(s)
Liked: 75
Cambridge Audio makes a line of AVR's that are available in a silver finish here in the US market, but not at the budget you indicated. They will meet all your other requirements though.
Here is a link to one model -
http://www.audioadvisor.com/prodinfo.asp?number=CA551R&variation=SIL
I cannot think of any other manufacturer here in the US that can help you. Good luck in your search.
Marantz PM15S2 LE, Oppo BDP-103, Simaudio Moon 100D DAC
VPI Traveler V2 with an Ortofon Rondo Blue and Simaudio Moon 110LP, Technics SL-1400 with an Audio Technica AT-14sa and Pro-ject Phono Box S
Dynaudio Focus 260's, Rel T-1 and a Panasonic TC-P54S1.
Paraneer is online now
Old 08-20-2012, 02:22 PM - Thread Starter
Quoted: 54 Post(s)
All my equipment is silver already and this receiver is only serving to add 5.1 to an existing 2 channel system (hence the pre-out)
I saw the Cambridge audio 7.1 receiver but it is 3X the money and way overkill for my simple needs.
Never thought this would be so difficult....
Maybe I should consider importing a Marantz 1402 or 1403 from overseas (or Canada if I am lucky enough to find one)??
Old 08-20-2012, 02:32 PM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
You realize that any silver component you find is going to be a different color silver from your existing equipment?
Sam S is offline
Old 08-20-2012, 02:41 PM
bfreedma's Avatar
Liked: 51
True, but still closer than a black one would be. Aesthetically, I understand why he's shooting for a single color. I did the same, though easier, as I finally got to an all black set of gear recently. Going to be tough for under $700 though.
bfreedma is offline
Old 08-20-2012, 04:01 PM
Paraneer's Avatar
Quoted: 25 Post(s)
Liked: 75
Maybe I should consider importing a Marantz 1402 or 1403 from overseas (or Canada if I am lucky enough to find one)??[/quote]
The Marantz 1402/1403's have only 2.1 pre-outs. Sorry, these units probably wouldn't work for your needs either. Full pre-outs start at above mid level AVR's up to flagships. I know it can be a real challenge sometimes trying to find that perfect piece of gear at an affordable price. I think manufacturers know this too and this is why they build these kinds of pieces but leave out the affordable part. For example, why are there no "affordable" pre-pros? If you think about it, they should be less then AVR's because your not getting an amp section. But they are not. And when you factor in aesthetics too (I can appreciate this if the gear is out in the open), sometimes you really gotta pay to get the look you want. I'll bet Cambridge sells more of the silver than the black because of this very reason.
Again, good luck with your search.
Old 08-20-2012, 04:14 PM - Thread Starter
Quoted: 54 Post(s)
Perhaps I don't have a good grasp of what I need here.
If I want to take a two channel tube preamp and just add three extra channels of power/processing what kind of pre-outs do I actually need on the receiver?
I was under the impression that it was only 2 channels of preamp output, to bypass the left and right fronts so my tube amp and preamp can do the heavy lifting at the front?
Oh...and Bingo on the "another shade of silver trumps black"...it does wink.gif
My gear is all Hovland. Lots of Chrome and glass and soft blue lighting. Very high WAF (until I plop in an ugly black receiver that's a foot tall).
Old 08-20-2012, 04:41 PM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
How about if you get a black receiver and put a little miniature white picket fence and some silk flowers in front of it?
commsysman is offline
Old 08-20-2012, 05:16 PM
Paraneer's Avatar
Quoted: 25 Post(s)
Liked: 75
If you only want the AVR to output L/R Main info through its pre-outs, then your OK. The interconnects would go into your 2 channel pre-amp (assuming you have an HT Bypass Feature on the pre-amp) and another set of interconnects from your 2 ch pre-amp into your 2 ch power amp. The AVR would then power the center and L/R surrounds using its own built in amplifiers. The sub-out of course takes care of just the powered sub; the .1 of the configuration. I only run 5.1 too and do something very similar. I am using an AVR as strictly a preamp/processor going into a 2 channel pre-amp and then to a 5 channel power amp. But my 2 channel pre-amp has an HT Bypass feature that allows for easy integration. If yours has this, no problem. You still have the silver probelm though. Good luck.
Old 08-20-2012, 05:41 PM
pukemon's Avatar
Quoted: 275 Post(s)
Liked: 70
Onkyo might have what you want in a used x07, x08, x09 receiver but kind of hard pressed to recommend any of those because of HDMI issues. Not sure if the x07 or x08 models support HDMI 1.4 either. Doesn't Yamaha have silver options too?
butter and jelly please.
Home theater gladly not designed by ereed or bgtighe23. 65" JS9500, Marantz 7702MKII, Parasound Halo A31, ClassDaudio SDS470 4ch, RBH R56, 4xRBH R55, 2x RBH R5, Hsu VTF 2 MK 3 and VTF 3 for subwoofage, OnStage MS7701B mic stand with boom for improved Audussey XT32 calibrations. Listening space happily treated with 1" OC 703 rigid fiberglass. OPPO 203 or 205 soon.
pukemon is online now
Old 08-20-2012, 06:10 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
Keep in mind..
That an AVR with a black front panel complies with the NAB anti-glare standards.. rolleyes.gif
M Code is online now
Old 08-20-2012, 09:27 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
You could get a Harmon Kardon receiver which is silver (gray) and black. At least you'd be halfway there.
http://www.amazon.com/Harman-Kardon-Channel-Receiver-iPhone/dp/B002IKKFUA/ref=sr_1_2?ie=UTF8&qid=1345519421&sr=8-2&keywords=Harman+Kardon+AVR+3600
Afro GT
afrogt is offline
Old 08-20-2012, 11:09 PM - Thread Starter
Quoted: 54 Post(s)
Sorry, in this country we have affirmative action and any percentage of black is still black.
Silver, as the great unwashed minority, is still relegated to the position of beaten-down and bloodied up, red headed stepchild smile.gifsmile.gif
Come on out there. There must be at least half a dozen silver Receivers that came out over the last 2-3 years since HDMI 1.4 protocol dropped.
Old 08-21-2012, 01:22 AM
afrogt's Avatar
Liked: 755
not is this country there arent a half dozen, at least not in your price range. Silver and HDMI 1.4 are not common here.
Now you can find an older silver non hdmi reciever like this Denon 3805. Maybe you'll just have to use optical for your audio output?
http://www.ebay.com/itm/Denon-AVR-3805-7-1-Channel-Receiver-Silver-Color-GREAT-Condition-/300762936460
Otherwise silver is a specialized color now. Good luck with that search.
Afro GT
afrogt is offline
Old 08-21-2012, 05:51 AM
ccotenj's Avatar
Liked: 101
unfortunately for the op, the marketplace in the usa spoke awhile ago when it came to silver equipment... they stopped buying it...
anecdotally, this is supported by the vann's absolute giveaway of silver apc s15's not too long ago (while maintaining retail price on black ones) amoungst other examples...
- chris
ccotenj is offline
Old 08-21-2012, 06:15 AM
BeeMan458's Avatar
Liked: 813
The best I can recommend is a Marantz SR 5007 at a delivered price of $750.00. It's fifty bucks above your stated maximum of $700.00 and yes, it's black but it meets your need for HDMI, 3D pass through and has a full set of 7.1 pre-outs but yes, again it's black. Now if you set it on the bottom shelf and put a curtain in front of the unit, you'll never know it's there.
If placed out in the open where others can see it, the receiver looks great and has a high WAF.
BeeMan458 is offline
PeterK's Avatar
Quoted: 41 Post(s)
Liked: 54
I sure do hope and pray the audio police don't come visit as I am guilty of possessing one of those illegal silver S15s!!!!
I am another that actually like the look of silver components or even better the gold tinted Marantz Reference series components. But like Chris says - they are disappearing! Just checked Marantz's site and they only have one gold component left listed.
PeterK is offline
Old 08-21-2012, 06:18 AM
ccotenj's Avatar
Liked: 101
shhh... if we don't tell anyone we have one, maybe we will get away with it... smile.gif
at the price they were selling them for, it was impossible to pass up, since i needed a good solid ups anyway...
- chris
ccotenj is offline
Old 08-21-2012, 08:45 AM
Iain-'s Avatar
Quoted: 89 Post(s)
Liked: 58
1. Silver finish
3. Pre-out
Anyone?
I realise this is quite subjective, but mixing black and silver kit looks great.
As example, my speaker stands have black base and top whilst riser is silver; KEF iQ30 that sit on them are black ash. Also, sub-woofer is piano black and Denon AVR is satin black and sits in rack which is silver.
Overall effect of this colour contrast quite cool. Initially I didn't think I would like it, but I was wrong.
Iain- is offline
Old 08-21-2012, 09:04 AM
BeeMan458's Avatar
Liked: 813
If this hasn't been mentioned, apparently you can get a silver SR5007 in the UK.
Oh, and if you get the SR7007, Marantz lights the outer mono glass ring with a blue light in the center of the face plate.
Old 08-21-2012, 09:10 AM
Pat6366's Avatar
Pat6366 is offline
Old 08-21-2012, 09:18 PM - Thread Starter
Quoted: 54 Post(s)
O.K. so let's re-cap some of the advice to me thus far:
1. Black receiver with white picket fence and silk flowers
2. Just buy black and get used to it.
3. Buy expensive U.K. import with wrong transformer value.
4. Spray paint
Old 08-21-2012, 09:56 PM
pukemon's Avatar
Quoted: 275 Post(s)
Liked: 70
Sandpaper? Gets the black off.
Old 08-21-2012, 11:32 PM
BeeMan458's Avatar
Liked: 813
Old 08-22-2012, 06:04 AM
Paraneer's Avatar
Quoted: 25 Post(s)
Liked: 75
Let's just say the answers you are receiving are somewhat "creative" bordering on comical because the problem you posed to the group. The product you are looking for simply doesn't exist in the US market. Back when you there were more silver AVR's, there was no HDMI 1.4 so that rules out the used market. To get HDMI 1.4 in a modern piece & silver finish, there are none available at your budget - sole exception the Cambridge.
So without being creative or comical, I see only one solution - cough up the bucks to satsfy the aesthtic or stay in budget and live with the black.
Let us know what you end up doing. Good luck.
Old 08-22-2012, 07:05 AM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
Agreed. And since this is an AVScience forum, most priorities and discussion are focused on meeting a need based on technology, not cosmetics.
Sam S is offline
Old 08-22-2012, 08:18 AM
Pat6366's Avatar
I was just having fun with the Spray paint idea (obviously) but I think as someone already mentioned the closest you will come is with a Harman Kardon. I am in the process of replacing my AVR445 which would almost meet all you requirements but I am not up to speed on the current models.
Pat6366 is offline
Old 08-22-2012, 08:21 AM
ccotenj's Avatar
Liked: 101
well... actually, he wouldn't be the first to paint a unit...
i remember seeing a couple examples of people taking cases apart in order to paint them the color desired... although they were silver to black, not the other way around... smile.gif
- chris
ccotenj is offline
