Is it possible to set the Front "A" channel speakers to "small" and the "B" Channel speakers to "Large"??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 08-20-2012, 06:04 PM - Thread Starter
TJeep_1999's Avatar
Is it possible to set the "A" channel speakers to small and the "B" Channel speakers to "Large" on a Denon ARV-1910???? I've been messing with this for awhile and I don't think it's possible, but before giving up completely I thought I would check it out here first.
I have Satellite speakers in the house on the "A" front speakers and some larger outdoor speakers on the "B" front speakers. I would like to play the "B" outdoor speakers as "Large" and keep the interior "A" front channel speakers as "small". Is there another way to do this that I haven't thought of yet??
Thank you in advance.
TJeep_1999 is offline
post #2 of 17 Old 08-20-2012, 06:06 PM
jdsmoothie's Avatar
Quoted: 15344 Post(s)
Liked: 7501
The A and B speakers are connected to the same amp. You could connect the outdoor speakers to the Surr Back/Amp Assign speaker posts and set Amp Assign to Zone 2 with the restriction that only "analog" sources would pass to the Zone 2 speakers, however, they would be set as LARGE.
jdsmoothie is online now
post #3 of 17 Old 08-20-2012, 08:45 PM
afrogt's Avatar
Quoted: 1434 Post(s)
Liked: 982
JD,
Aren't the B speakers stereo only since the Denon doesn't do any bass management to them? I could be wrong though.
Afro GT
afrogt is offline
post #4 of 17 Old 08-21-2012, 02:28 AM
jdsmoothie's Avatar
Liked: 7501
The B speakers get the same signal as the A speakers and all settings for the A speakers apply to the B speakers except when using the Custom 2CH/Direct settings noted in post #9.
post #5 of 17 Old 08-21-2012, 06:34 AM
garciab's Avatar
Quoted: 156 Post(s)
Liked: 71
Originally Posted by jdsmoothie View Post
Nope. The A and B speakers are connected to the same amp. You could connect the outdoor speakers to the Surr Back/Amp Assign speaker posts and set Amp Assign to Zone 2 with the restriction that only "analog" sources would pass to the Zone 2 speakers, however, they would be set as LARGE.
Would you happen to know what model year Denon's allow digital sources to be placed in Zone 2? I'd like to have a typical HT setup with small speakers all around, but use large speakers to listen to USB music. Your Zone 2 setup would work.
bg
garciab is offline
post #6 of 17 Old 08-21-2012, 06:43 AM
jdsmoothie's Avatar
Liked: 7501
Depends on what you mean by Zone 2? If you just mean a 2nd set of "music only" speakers in the same main zone, then the Front B feature will do that and is a feature of any Denon 7.1 AVR (the Surr Back/Amp Assign speaker posts are used for the Front B speakers). In this configuration, any audio selected in the main zone will pass to the Front B speakers (HDMI, digital, or analog). If you truly want an independent source option (ie. Zone 2), only the 33XX series and higher feature PCM 2.0 over optical/digital coax (but no HDMI) to Zone 2 (although this feature has been removed on the new 3313CI model in lieu of the new Zone 2 (HDMI) connection).
post #7 of 17 Old 08-21-2012, 08:50 AM
garciab's Avatar
Quoted: 156 Post(s)
Liked: 71
Thanks JD.
bg
garciab is offline
post #8 of 17 Old 08-21-2012, 03:54 PM - Thread Starter
TJeep_1999's Avatar
I thought I might be able to use the "Zone 2" option, but all of my sources are digital. It's not a major issue. I'll play around with the HPF ranges and find a good balance between the indoor and outdoor speakers. Thank you for all the details and info! At least I know what my options are now...
post #9 of 17 Old 08-21-2012, 05:25 PM
jdsmoothie's Avatar
Liked: 7501
I forgot the 1910 offers the 2CH/Direct custom settings which you can use to achieve your goal. If you don't use STEREO mode in the main zone, you can use the custom STEREO settings (p. 29) to set the Front B speakers to LARGE, and then set the Front Speaker Setup (p. 27) for STEREO mode to Front B. Then whenever you switch to STEREO mode, then only the Front B speakers will be active.
post #10 of 17 Old 08-22-2012, 05:32 AM - Thread Starter
TJeep_1999's Avatar
JD do you have one of those photographic memories?? Love that the page numbers where included. I'll set it up tonight. I should be able to make this work. Thank you!
post #11 of 17 Old 08-22-2012, 06:08 AM
jdsmoothie's Avatar
Liked: 7501
Not at all ....... rather just have all of the Denon Owner's manuals from the last 5 years downloaded from Denon's website. smile.gif
post #12 of 17 Old 08-22-2012, 06:31 AM
garciab's Avatar
Quoted: 156 Post(s)
Liked: 71
Cool! I'll see if the 2311CI has this feature. I've got my eye on a refurb form a4l.
bg
garciab is offline
post #13 of 17 Old 08-22-2012, 06:37 AM
jdsmoothie's Avatar
Liked: 7501
Note however, that on the new XX13 models, the feature has been removed on all but the 3313CI.
post #14 of 17 Old 08-22-2012, 07:39 AM
garciab's Avatar
Quoted: 156 Post(s)
Liked: 71
Yup, just looked at the manual. This clinches it for me. Very cool feature indeed! Thanks again...for remembering!
bg
garciab is offline
post #15 of 17 Old 01-27-2014, 09:26 PM
abhi1's Avatar
Hi,
I have KEF3005se(5.1) and a pair of Paradigm Studio 60 V3.0's. I would like to use the KEFs for movies and Studio 60s for music (all speakers are in the same room).
For me, manual equalizers are important.
My question is, after I set the EQ manually for each speaker (5+1 and 2), when I switch to "Front B" stereo, will the EQ settings still be applied to these speakers?Thanks.
abhi1 is offline
post #16 of 17 Old 01-28-2014, 06:50 PM
jdsmoothie's Avatar
Liked: 7501
If you are referring to the 1910, then no. The EQ would only apply to the main zone (ie. Front A) speakers.
post #17 of 17 Old 01-28-2014, 07:05 PM
abhi1's Avatar
How about in Denon 3313CI? Will EQ settings be passed to Front B speakers? Thanks.
abhi1 is offline
Denon Avr1910 7 1 Channel Multi Zone Home Theater Receiver With 1080p Hdmi Connectivity
