Looking at buying a Receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 55 Old 08-26-2012, 02:14 AM - Thread Starter
djtoodles's Avatar
Quoted: 18 Post(s)
Just bout a new 64" samsung tv. was looking to buy my first surround sound system. People have been telling me to buy an Onkyo what are your guys thoughts? and what is a good model? And is it worth it to buy the home theater sets or buy it all separate? will be used for tv, movies and for hosting guests with music playing.
djtoodles is offline
post #2 of 55 Old 08-26-2012, 02:52 AM
afrogt's Avatar
Quoted: 1056 Post(s)
Liked: 757
Better to buy seperates
How big is your room?
How much are you willing to spend?
There are other brands more reliable than Onkyo.
Afro GT
afrogt is online now
post #3 of 55 Old 08-26-2012, 06:47 AM
joeyvaz's Avatar
Quoted: 69 Post(s)
Liked: 29
I agree with AFROGT with the exception of reliability. ALL brands have issues with the receivers due to the complexity they bring to the table. I've had nothing but exceptional results with my last three Onkyo receivers. All with the last 4 Pioneers and 2 Yamahas (I upgrade every 12-18 months)
With that said, Onkyo gives some of the best bang for the buck receivers right now. I love the way they sound with my Emotiva speakers. I love the way Pioneer pairs with my Def Tech setup in my main HT.
I would advise you to come up with a budget (receiver, speakers, and sub) decide if you prefer towers or book shlef speakers (room size MAY dictate which route you should go) and then we can give you some suggestions. Nice thing about going individual components versus a HTIB (home theater in a box) is that if you ever want to upgrade the receiver, sub, or speakers in the future, it will be easier to do because the other components are of better quality. I've learned from being in this hobby 25 years or so, once you're in, it's very addicting. Of all the hobbies I've had, this is the only one that I've never gotten tired of. I don't think I ever will.
joeyvaz is offline
post #4 of 55 Old 08-26-2012, 09:38 AM
jpcamaro70's Avatar
Quoted: 16 Post(s)
Liked: 25
Everyone will have different opinions regarding the AVR's. I prefer Denon, they've done very well by me, but i've also used onkyo without any problems.
The biggest mistake i made was going HTIB (home theatre in box) to try and save money. Yes, you'll spend more on separates, but what a difference in sound.
Denon X3100W
Klipsch RB-61 II (Fronts), Klipsch RC-52 II (Center)
Deftech StudioMonitor 350 (surrounds)
Klipsch SW-115 (sub)
LG 50LB5900
TiVo Roamio
jpcamaro70 is offline
post #5 of 55 Old 08-26-2012, 07:37 PM - Thread Starter
djtoodles's Avatar
Quoted: 18 Post(s)
The room is probably 15x15. To be honest I am. It looking to have a movie theater replica sound. I like good bass and other than that just something that spuds good and can run my xbox. Ps3 cable box and anything else since my tv only has 3 hdmi I'd rather use te receiver to plug all my devices in to and just use 1 hdmi on the tv.
post #6 of 55 Old 08-26-2012, 08:15 PM
pukemon's Avatar
Quoted: 278 Post(s)
Liked: 70
Figure out your budget, what you want in a receiver, what kind of speakers you want to fit your space, bass wants and then come ask us. All the mainstream receivers have good options. Speakers are easy to come by for any budget, though you'll get a lot more if you spend at least a few hundred dollars, better yet at least a grand. Personally, I recommend starting out with a 3.0 setup to get started, or better yet 3.1 if the budget allows. Upgrading to .2 or more and getting surrounds are very easy to integrate into any system, low end all the way to no holds barred budget.
butter and jelly please.
Home theater gladly not designed by ereed or bgtighe23. 65" JS9500, Marantz 7702MKII, Parasound Halo A31, ClassDaudio SDS470 4ch, RBH R56, 4xRBH R55, 2x RBH R5, Hsu VTF 2 MK 3 and VTF 3 for subwoofage, OnStage MS7701B mic stand with boom for improved Audussey XT32 calibrations. Listening space happily treated with 1" OC 703 rigid fiberglass. OPPO 203 or 205 soon.
pukemon is offline
post #7 of 55 Old 08-27-2012, 04:07 PM - Thread Starter
djtoodles's Avatar
Quoted: 18 Post(s)
5-600 I suppose. I would rather a nicer receiver than speakers. I have an old SS unit with some speakers so if worse comes to worse i can use some of them. They are sony and a few technics.
post #8 of 55 Old 08-27-2012, 04:27 PM
pukemon's Avatar
Quoted: 278 Post(s)
Liked: 70
See if you can find a denon 3312 within your budget. I would go no less than an 818, if you want onkyo, but that is a couple hundred above budget. Or get the best Yamaha you can with your budget. Start looking at last years models to get the best deal. I am up in the air about pioneer. The limited listening time I've had with any pioneer was underwhelming in very bad environments. But out of all these mentioned, perhaps try and get a Yamaha 1010.
pukemon is offline
post #9 of 55 Old 08-27-2012, 06:09 PM - Thread Starter
djtoodles's Avatar
Quoted: 18 Post(s)
Damn those are some expensive receivers. I was looking at the Onkyo NR515. Is that no good?
post #10 of 55 Old 08-27-2012, 07:42 PM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
Code:
To be honest, you're not going to have "movie theater replica sound" with a $600 reciever.
Sam S is offline
post #11 of 55 Old 08-28-2012, 05:50 AM
jpcamaro70's Avatar
Quoted: 16 Post(s)
Liked: 25
Buy a good reciever that has just what you need, don't spend more to have unnecessary stuff, and spend the rest on speakers. Good speakers are the best way to even come close to movie theatre sound.
The Onkyo looks good. You can get the Denon 1613 for under 400. Then spend every other penny on speakers. Since you want good bass, expect to put a lot towards the powered sub.
Denon X3100W
LG 50LB5900
TiVo Roamio
post #12 of 55 Old 08-28-2012, 07:15 AM
jdsmoothie's Avatar
Quoted: 12140 Post(s)
Liked: 5530
This is the reverse of what is generally recommended (ie. better to have a lower end AVR with better quality speakers) as the audio comes from the speakers. The Onkyo 515 uses the lowest version of Audyssey 2EQ, so you're better served with a lower level Denon (eg. 1612 or 1613) which has 2x the speaker filters as does 2EQ and can also EQ the subwoofer which 2EQ cannot do.
jdsmoothie is online now
post #13 of 55 Old 08-28-2012, 10:10 AM
KidHorn's Avatar
Quoted: 1375 Post(s)
Liked: 883
If you want good bass, get this..
http://www.outlawaudio.com/products/lfmEX.html
It's on sale until sept 4th for $599 with free shipping. It's an awesome sub for the price.
I agree you should spend much more on speakers than the receiver. All receivers more or less sound the same. Speakers don't. Having said that, whatever receiver you buy should have room correction software, Audyssey for Onkyo, Marantz and Denon. YPAO for yamaha. MCACC for pioneer. Audyssey is better than the others at the higher end (XT and XT32).
KidHorn is offline
post #14 of 55 Old 08-28-2012, 07:41 PM - Thread Starter
djtoodles's Avatar
Quoted: 18 Post(s)
I was just looking on the main page article about the surround sound. what kind of setup is recommended for a 15x15 room. its probably between 12-15' but for argument sake. should i go 2.1, 5.1 or 7.2? Wouldnt that be the best way to figure out a receiver? I guess I just want a nice setup that I can use 1 hdmi out on my tv and the receiver will do the rest for my devices. also i see some of the onkyo's now are ready for the 4k. that would be nice to have a somewhat future proof receiver.
this all being said i had a samsung powerbar that i got with my tv before returning it that to me sounded good and that thing is 300 brand new. I would prefer like i said to have it all for about 5-600. I can upgrade later if need be but i am using sony speakers a friend had from his SS system that he spent a total of 300 on and a few little cheap JL speakers and to me it doesnt even sound bad.
Maybe I dont know much about audio but i always thought denon was cheap quality and onkyo was the king...
post #15 of 55 Old 08-29-2012, 05:51 AM
jdsmoothie's Avatar
Liked: 5530
It's actually the reverse in reference to both audio fidelity and QC on the lower/mid level models .... as Onkyo 717 and lower only use the lowest level Audyssey 2EQ which cannot EQ a sub, while all but the lowest Denon model (1513) use at least Audyssey MultEQ which has 2x the number of speaker filter resolution than does 2EQ and can also EQ the sub.
Also whether you expand from 5.1 to 7.1 depends on whether you are adding front heights, front wides, or surround back speakers and if surround backs, whether there is sufficient room behind the main listening position.
post #16 of 55 Old 08-29-2012, 01:01 PM - Thread Starter
djtoodles's Avatar
Quoted: 18 Post(s)
Yeah I talked with a friend until i move to a new home which can be 5 years out or so i am going to do a 5.1 setup. does that change much as far as model to get? I would prefer to not have to buy another receiver for many many years!
post #17 of 55 Old 08-29-2012, 01:13 PM
jdsmoothie's Avatar
Liked: 5530
With as frequent as the HDMI specification is changing (and whether it will continue at all), it's tough to say an AVR purchased today will still be usable 5 years down the road. Your best bet is to pick up one of last year's models on clearance. Better yet, you may be able to get a refurbished unit for even less. Accessories4Less is an authorized Denon and Onkyo refurb reseller and most units come with a 1 year warranty.
http://www.accessories4less.com/make-a-store/item/DENAVR1612/DENON-AVR-1612-5.1-Channel-A/V-Home-Theater-Receiver/1.html
http://www.accessories4less.com/make-a-store/item/ONKTXNR515/Onkyo-TX-NR515-7.2-Channel-Network-A/V-Receiver/1.html
post #18 of 55 Old 08-29-2012, 01:33 PM
BeeMan458's Avatar
Liked: 813
If the dam don't break and the creek don't rise, you should be good for a couple more weeks. tongue.gif
As long as you don't go and change any of your gear, the gear will be good until the wheels fall of but if the formats change and obsolete your DSP, then you're SOL. Future casting here, I suspect that soon, rationally, Blu-ray will be obsoleted by SS chip technology. You'll buy movie content on a thumb drive. Soon there will be a cross over as the price of SS, flash memory chip technology overtakes the likes of Blu-ray. Maybe one day you'll just plug into the wall and download content from the web. Oh, wait, that's already happening. The point, even the days of Blu-ray are numbered. The clock is already ticking. Tick-tock Blu-ray. tongue.gif
The best way I can suggest to future proof your 5.1 system, is to buy "DECENT" speakers and marry them with a sound system consisting of separates. The Amp will be with you always or until it goes up in smoke as in; that's not good. As to the pre-pro, one can regularly replace the unit as one finds need, making the swap out cheaper to keep one's self current as pre-pros are rudely obsoleted out from under their poor, unsuspecting, innocent, I don't want this to happen, feet.
The above is the long way of saying, no matter what one chooses to do, manufactures are going make sure to hose everybody equally and there's not a darn thing anybody can do to stop the reality of the issue.
Oh boo-hoo!
BeeMan458 is offline
post #19 of 55 Old 08-29-2012, 01:44 PM - Thread Starter
djtoodles's Avatar
Quoted: 18 Post(s)
If it were you guys would you buy the denon 1612, 1613 or the Onkyo NR414, NR515 or NR616? My gut tells me the NR515 but i am a newb. guess the Onkyo brand name has me leaning that way mostly because it seems to offer more.
Or am I just best off keeping my current technics receiver/sony speaker and sub setup for a few months and wait for a great deal around the holidays?
post #20 of 55 Old 08-29-2012, 02:09 PM
jdsmoothie's Avatar
Liked: 5530
You need to decide which is more important ... features (Onkyo) or audio fidelity (Denon).
post #21 of 55 Old 08-29-2012, 03:39 PM
pukemon's Avatar
Quoted: 278 Post(s)
Liked: 70
Denon. Even though I like and prefer onkyo overall, denon is a better choice with lower tier models. Onkyo isn't a good choice unless you jump up to at least the 818 or higher model. Yamaha is a good brand also with any budget.
pukemon is offline
post #22 of 55 Old 09-02-2012, 06:29 PM - Thread Starter
djtoodles's Avatar
Quoted: 18 Post(s)
Is the audio that much more noticeable from the denon to onkyo?
post #23 of 55 Old 09-02-2012, 06:50 PM
jdsmoothie's Avatar
Liked: 5530
With these lower level model Onkyo AVRs that only use Audyssey 2EQ, most likely yes.
post #24 of 55 Old 09-02-2012, 08:51 PM - Thread Starter
djtoodles's Avatar
Quoted: 18 Post(s)
Damn... The denim was going to be my choice until I saw it only has 4 hdmi. The onkyo may be the only choice now. I see the 515 has hdmi dropouts though.
post #25 of 55 Old 09-02-2012, 08:56 PM
pukemon's Avatar
Quoted: 278 Post(s)
Liked: 70
Denon or Yamaha. I considered Yamaha but really wanted bass eq and it surpassed my expectations. I had a hard time believing bass could get a lot better because of some fancy schmancy algorithms with room correction but it does help. Why don't you research Yamaha some and figure if you could do without audyssey in favor of ypao.
pukemon is offline
post #26 of 55 Old 09-03-2012, 06:39 AM
jdsmoothie's Avatar
Liked: 5530
Consider the Denon 1712 which has 6 HDMI inputs and not likely much more than the 1612.
post #27 of 55 Old 09-03-2012, 12:28 PM
STEVEIB7's Avatar
Pukemon and Joeyvaz - wanted to get your advice on the following: I'm planning on purchasing a Panny VT 50 plasma and wanted to set up a home theater system with Def Tech 8060 floor speakers that have built in subs, 8060 center channel also with built in subwoofer along with 8040 rear speakers. Which of the following receivers would you both recommend to power the system:
Pioneer Elite SC-65
Denon 3313
Onkyo 818
I am very new at this and just started doing a bunch of research and any advice you both can give me would be great.
STEVEIB7 is offline
post #28 of 55 Old 09-03-2012, 02:36 PM - Thread Starter
djtoodles's Avatar
Quoted: 18 Post(s)
Maybe a dumb question but its showing less watts per channel than the Onkyo NR515. Am i reading that wrong or no? denon shows 90W and the onkyo is 100.
post #29 of 55 Old 09-03-2012, 02:53 PM
jdsmoothie's Avatar
Liked: 5530
Actually the 515 is only 80W, however, you're not going to likely notice a difference of even 30W let alone only 10W.
post #30 of 55 Old 09-03-2012, 03:05 PM
pukemon's Avatar
Quoted: 278 Post(s)
Liked: 70
Pioneer Elite SC-65
Denon 3313
Onkyo 818
Are those speakers with powered woofers or passive? If they don't have their own amp built in, chances are you're better off getting an external amp and using an avr as a pre pro. I could be wrong though. Might want somebody with more experience to give a recommendation. But for an answer, if I was in the market for a comprehensive eq, I'd choose the 818 or pioneer. If music was my first priority, the denon. All are good choices though. I ended up passing on the 818 and got an onkyo 3009 for the better amp section.
pukemon is offline
Receivers Amplifiers , Onkyo , Samsung , Samsung Pn64d8000 64 Inch 1080p 600hz 3d Plasma Tv 2011 Model , Speaker Systems , Denon Avr 891 Receiver , Denon Avr3312ci Receiver , Onkyo Tx Nr818 , Denon Avr 1613 Receiver , Playstation 3 160gb System
