Help hooking a buttkicker to a Marantz Sr6006 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-27-2012, 08:03 PM - Thread Starter
kain0rer's Avatar
Quoted: 22 Post(s)
Hey guys,
Lurking on these forums helped me decide on gear for my first HT system, but now I need help getting it together.
I have a pair of speakers attached to my Marantz SR6006 (bi-amped) in stereo.
I want to add my buttkicker without losing any sound quality from the speakers. When i add a subwoofer in the amp menu, it alters the sound (I think from full-range to 'Large') I don't have a subwoofer attached, just the buttkicker and the two floor standers.
Anyway, as I said I'm new to this and would love some direction on how to get this buttkicker working from my receiver without affecting the sound from my floorstanders. The buttkicker is attached to a gaming seat so sound is coming from a PS3 connected via HDMI to the SR6006.
If I left anything out let me know and thanks in advance for the help. If this thread is in the wrong place, feel free to move it.
Cheers.
Marantz SR6006 Reciever | Studio 60 v.5 Fronts (Bi-Amped) | SVS PB-2000 | Samsung JU7000 75" (Firmware: 1460)
kain0rer is offline
post #2 of 7 Old 08-28-2012, 05:32 AM
jdsmoothie's Avatar
Quoted: 12264 Post(s)
Liked: 5593
LARGE and full range are the same as far as the FL/FR signals are concerned; however, w/o the sub connection, the LFE signal is also routed to the FL/FR speakers, whereas with the sub connection the LFE is routed to the buttkicker.
jdsmoothie is offline
post #3 of 7 Old 08-28-2012, 02:51 PM - Thread Starter
kain0rer's Avatar
Quoted: 22 Post(s)
So is there no real way of doing it without losing the full sound of the speakers?
Also, what kind of cable should I be using for this? Will any cheap cable do because it is just being used for the buttkicker or does the quality matter?
Thanks again.
kain0rer is offline
post #4 of 7 Old 08-29-2012, 06:23 AM
jdsmoothie's Avatar
Liked: 5593
Connect RCA (red/white) cables from the FL/FR pre-out to the buttkicker.
post #5 of 7 Old 08-29-2012, 08:26 AM - Thread Starter
kain0rer's Avatar
Quoted: 22 Post(s)
Ok cool I can see how that would work, I can't find a single cable to do it however, so would it be as easy as plugging one of these into the FL/FR pre-out on the marantz and then plugging this into the buttkicker amp?
kain0rer is offline
post #6 of 7 Old 09-02-2012, 12:01 AM - Thread Starter
kain0rer's Avatar
Quoted: 22 Post(s)
On second thought, that will just give me either left or right sound which isn't great when playing games. Is there something I can put between the FL/FR out and the buttkicker amp that will reproduce all low freq. rather than just the left or right channel?
kain0rer is offline
post #7 of 7 Old 09-02-2012, 05:59 AM
jdsmoothie's Avatar
Liked: 5593
Marantz Sr6006 Av Receiver , Receivers Amplifiers , Playstation 3 160gb System
