Best receiver for $100? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-29-2012, 08:07 AM - Thread Starter
Wolfetan44's Avatar
Best receiver for $100 that have a phono for vinyls and can power 2 bookshelf speakers and a sub.
Wolfetan44 is offline
post #2 of 8 Old 09-02-2012, 09:57 PM
ChrisW6ATV's Avatar
For $100 with a phono input? Look for a good used receiver on Craigslist. I doubt there are any new receivers with phono inputs anywhere near $100.
Chris
"It's [expletive] lame to watch Jaws, a film that uses the 2.40 ratio as well as any ever produced, in the wrong format on HBO." -Steven Soderbergh, Oscar-winning director
ChrisW6ATV is offline
post #3 of 8 Old 09-02-2012, 10:42 PM
pukemon's Avatar
Quoted: 275 Post(s)
Liked: 70
And it won't power a sub. You'll have to provide your own powered sub. Nut yeah a used receiver off craiglsit is your best bet.
butter and jelly please.
Home theater gladly not designed by ereed or bgtighe23. 65" JS9500, Marantz 7702MKII, Parasound Halo A31, ClassDaudio SDS470 4ch, RBH R56, 4xRBH R55, 2x RBH R5, Hsu VTF 2 MK 3 and VTF 3 for subwoofage, OnStage MS7701B mic stand with boom for improved Audussey XT32 calibrations. Listening space happily treated with 1" OC 703 rigid fiberglass. OPPO 203 or 205 soon.
pukemon is offline
post #4 of 8 Old 09-02-2012, 11:02 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Whatever receiver it is, it will have to be used. Nobody sells anything new like that.
Afro GT
afrogt is offline
post #5 of 8 Old 09-03-2012, 06:45 AM
jdsmoothie's Avatar
Quoted: 12079 Post(s)
Liked: 5500
jdsmoothie is offline
post #6 of 8 Old 09-03-2012, 07:40 AM
BeeMan458's Avatar
Liked: 813
Phono Pre-Amp.
But now you're into +$200.00 between the combined price of the AVR and Phono Pre-Amp which puts you back into used in order to get the price. I hate budgets.
BeeMan458 is offline
post #7 of 8 Old 09-03-2012, 09:38 AM
afrogt's Avatar
Liked: 755
Wolfetan44,
Now you can get a stereo receiver with a phono input for $100 but it doesn't have a line level sub output.
http://www.amazon.com/Sherwood-RX-4109-Stereo-Receiver-Black/dp/B000MBUSD6/ref=pd_sim_sbs_e_2
If your subwoofer has speaker level inputs you could connect the bookshelf speakers to Speaker A outputs and the sub to Speaker B.
If your subwoofer has speaker level inputs AND outputs you could wire the receiver to the sub with speaker A outputs and then the bookshelf speakers directly to the subwoofer. You would then use the subwoofer crossover dial to set your crossover point.
What subwoofer do you have?
Afro GT
afrogt is offline
post #8 of 8 Old 09-09-2012, 10:36 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
used will be much better. Even go to goodwill and look at what they have.
lespurgeon is offline
