suggestions on overheating - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-30-2012, 08:57 AM - Thread Starter
razorcat's Avatar
Just purchased an onkyo TX-NR3009 receiver, it gets very hot, need help in deciding how to keep it cool. Spent all my money on the receiver, any suggestions on keeping it cool
razorcat is offline
post #2 of 10 Old 08-30-2012, 09:45 AM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
What type of cabinet/rack is it in right now?
Sam S is offline
post #3 of 10 Old 08-30-2012, 09:57 AM
BeeMan458's Avatar
Liked: 813
High and low, I drilled a bunch of ventilation holes into the back of the entertainment credenza. By going both high and low, doing so improves convection air flow and when driving the unit particularly hard, to improve air flow further, I open the cabinet door a few inches during movie viewing.
BeeMan458 is offline
post #4 of 10 Old 08-30-2012, 12:03 PM
M Code's Avatar
Quoted: 718 Post(s)
Liked: 423
How much free-air clearance do the L/R sides and top cover have?
You should have at least 4-6"...
Anything less can impact the AVR's reliability..
Onkyo AVRs run hot due to their high-biased amplifiers.
M Code is online now
post #5 of 10 Old 08-30-2012, 12:08 PM
DonH50's Avatar
Quoted: 1797 Post(s)
Liked: 1333
Parts Express and other places have fan coolers you can place on top. Probably worth checking out.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #6 of 10 Old 08-30-2012, 12:10 PM
LVIV73's Avatar
Get Denon instead,my AVR 391 can be left on for months at a time and stay cool as my fridge.Yo can find it for little more than a $100 now.
LVIV73 is offline
post #7 of 10 Old 08-30-2012, 05:14 PM
M Code's Avatar
Quoted: 718 Post(s)
Liked: 423
The Onkyo TX-NR3009 has 4x the power of the 391, so it runs hotter.
Kinda like comparing a 1.4L 4 cylinder to a 6.4L supercharged hemi.. biggrin.gif
post #8 of 10 Old 08-30-2012, 06:02 PM
Ray77085's Avatar
Quoted: 132 Post(s)
Liked: 160
Buy one of these. http://www.antec.com/soundscience/AVCooler.php
Works well with my 809, although I never had a heat issue with it. I don't want to take any chances.
MY 5.4.4 SET UP.
Onkyo TX-NR809, Denon X4200 (Klipsch-KF-28 mains),( Center KC-25), (side surrounds Primus P363), (Front height-Pioneer Dolby Atmos Enabled Add-On Speakers) ( Back height- Onkyo SKH-410 Dolby Atmos-Enabled Add-On Speakers) 2 each Klipsch RW12D subs. HSU VTF-3 MK3 and HSU VTF-3 MK4 subs.
Mitsubishi 3D DLP MODEL73-738, DarbeeVision DVP-5000.Pioneer BDP-62FD.
Ray77085 is offline
post #9 of 10 Old 08-30-2012, 07:34 PM
pukemon's Avatar
Quoted: 279 Post(s)
Liked: 71
Don't buy that one. Try the com cool cooling station with dual 120mm fans. Can be found on amazon. Will cost more than the wanted. Better airflow and reliability than the above mentioned. Or look through the 3009 thread for some cheaper and/or better options.
butter and jelly please.
Home theater gladly not designed by ereed or bgtighe23. 65" JS9500, Marantz 7702MKII, Parasound Halo A31, ClassDaudio SDS470 4ch, RBH R56, 4xRBH R55, 2x RBH R5, Hsu VTF 2 MK 3 and VTF 3 for subwoofage, OnStage MS7701B mic stand with boom for improved Audussey XT32 calibrations. Listening space happily treated with 1" OC 703 rigid fiberglass. OPPO 203 or 205 soon.
pukemon is offline
post #10 of 10 Old 08-31-2012, 02:50 AM
dowop's Avatar
Quoted: 42 Post(s)
He already bought it so you are saying send it back & get a Denon AVR 391?
I bought the 3009 because I wanted the 9 channels.Isn`t 391 is just a stereo receiver?
dowop is offline
