Another Speaker Hum Question... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-01-2012, 11:28 AM - Thread Starter
MadMyers's Avatar
Quoted: 205 Post(s)
Liked: 123
I've had a small hum in my speakers for 6 months or so. I haven't wanted to deal with it. Today I spent some time looking at it.
Here are my quick questions (which I didn't see answered in the wealth of other discussions on this topic):
1) Does the pure existence of dimmer switches contribute to hum or do the dimmer switches need to be in use? For example, if the lights controlled by the dimmer are turned off, can dimmers produce hum? I'm thinking no, but wanted to verify
2) Similar for fluorescent lights. Can they cause hum when turned off?
3) It seems that "noisy" devices on different circuits can cause hum. Is this true? (Other threads have implied yes to this, but wanted to triple check)
Now, a little more about my situation:
0) It's a old but trusted HK 525 receiver
1) With all inputs to the receiver disconnected, it's still present
2) The sub doesn't hum
3) With the sub output disconnected, the hum on the main speakers is still present
4) When I turn the volume up louder, the hum gets louder
5) Even though there are no inputs connected, when I change AV source the hum goes away briefly. FWIW, the receiver is pretty slow at detecting the digital mode and this the time where the hum goes away seems to match the digital format acquisition time
The HK525 is suppled with a power cord that does not have a ground plug. With all the inputs disconnected and the hum occurring, as well as the sub output disconnected, I don't see how a ground loop could be a cause.
I'm thinking something has happened to the HK525 or there is noise on the power line. I do not have a snazzy power conditioner.
What do you guys recommend?
The answer to the dimmer question will help as I have about 4 or 5 dimmers for can lights, as well as florescent lights. However, the hum occurs when these when both of these are off.
I'm thinking I'll try the extreme approach and turn off all other circuits.
... Altan
MadMyers is offline
post #2 of 6 Old 09-02-2012, 05:44 PM - Thread Starter
MadMyers's Avatar
Quoted: 205 Post(s)
Liked: 123
Went ahead and did the circuit breaker thing...
With all the other circuits turned off, the hum remains...
Thinking it's either dirty power or just the HK525. What do people think?
... Altan
MadMyers is offline
post #3 of 6 Old 09-02-2012, 06:11 PM
BeeMan458's Avatar
Liked: 813
... Altan
Too many variables. How old is your home electrical system? It sounds like it's a fairly new system. Is the system properly grounded. Is the AVR properly grounded? Today, many units are grounding through the neutral return. I don't like it when that's done. If there's a short to the neutral (white) wire, you could be getting a ground loop that way. That's why I ask how old your house wiring is. My understanding, dimmer switches are more an inductance problem, as can be refrigerators and freezers which can cause GFI fits. Do you have any CFL's attached to the home theater circuit? CFL's kick up their own brand of electrical interference.
You might have a switched polarity where the hot and the neutral are reversed. You can get a outlet tester at a local hardware store in the form of a simple, go/don't go, test light interface.
BeeMan458 is offline
post #4 of 6 Old 09-02-2012, 06:19 PM - Thread Starter
MadMyers's Avatar
Quoted: 205 Post(s)
Liked: 123
Thanks for the reply.
Originally Posted by BeeMan458 View Post
Too many variables.
I tried to eliminate many... let's go through your questions and see what's left.
Built in 1993.
To the best of my knowledge.
Not sure what "properly" means. As mentioned, the AVR supplied plug doesn't have a ground, so it would be using the neutral.
Today, many units are grounding through the neutral return. If there's a short to the neutral (white) wire, you could be getting a ground loop that way.
Short between what?
I've used one of those circuit testers (thingies with the 3 lights) and it tests "ok"
That's why I ask how old your house wiring is. Dimmer switches are more an inductance problem and can cause GFI fits. Do you have any CFL's attached to the home theater circuit? CFL's kick up their own brand of electrical interference.
Not on the home theater circuit. But they exist on another circuit, but the problem occurs when they are turned off and when that circuit is disabled.
Does this info tend to focus the issue?
... Altan
MadMyers is offline
post #5 of 6 Old 09-04-2012, 10:16 AM
Selden Ball's Avatar
Quoted: 3431 Post(s)
Liked: 1700
Unfortunately, your descriptions of the symptoms suggest to me that there might be a problem in the part of the power supply providing power to the preamp inputs of your receiver. Perhaps some of its filter capacitors are starting to fail.
One thing you might try is to short-out the inputs on the receiver that you don't use. I.e. put a jumper wire between the central socket and the surrounding metal of each of the RCA jacks. You might be able to locate some RCA shorting covers at a local electronics or audio/video store. If the hum is being caused by RF interference being picked up by the receiver's internal wires connected to the preamp circuits, this might help -- it forces the input signals to be 0 volts.
Selden
Selden Ball is offline
post #6 of 6 Old 09-04-2012, 10:40 AM
BeeMan458's Avatar
Liked: 813
... Altan
Only that from your above, it reads as if your home electrical system is not the problem.
