n00b question: denon 1612 vs 1712 what to get? - AVS Forum | Home Theater Discussions And Reviews
Old 09-01-2012, 05:55 PM - Thread Starter
Stealth3si's Avatar
Quoted: 32 Post(s)
the only main difference i'm concerend with is hte multieq and multieq xt that is making me choose between them..
what's the differentce between them? basically what makes the xt better for practicability purposes?
i suspect it may have to do with a messed up room or something so xt would do betteR? i dunno..how can i tell if i woudl benefit great with xt than the regular one?
btw, i'm a home end-user so i'm not a sound technician or audio expert on these things..
5.1 small-room size: 800 ft³+ 54 ft³ corner door space
AVR: Denon 1712
Fronts: Pioneer SP-BS41-LR /Center: Pioneer SP-C21 / Rear: Pioneer SP-BS21-LR
Subwoofer: SVS PC12-NSD
Screen: Samsung UN46EH6070 46" 1080p 3D LED 240 CMR TV
Viewing distance: 7.33 ft
Stealth3si is offline
Old 09-01-2012, 05:58 PM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
XT offers better EQ capability and generally the difference is only $50 between the two so is worth the extra cost.
jdsmoothie is offline
Old 09-01-2012, 07:00 PM - Thread Starter
Stealth3si's Avatar
Quoted: 32 Post(s)
umm well J&R sells 1612 refurbed for $199.99 w/ 3-month warranty
A4L sells 1712 refurbed for $260.52 w/ 1 year wrranty
that's $60 difference. is it worht the extra cost?why would i use the eQ capbility? what's that?
AVR: Denon 1712
Old 09-01-2012, 09:24 PM
pukemon's Avatar
Quoted: 275 Post(s)
Liked: 70
It is better trust us. If you don't have a subwoofer skip the 1712. If you dont have a sub but plan on getting one, get the 1712. The reason we are telling you this, especially for a lower budget, is to get the Max potential for the money spent, to avoid upgrade bug sooner than later and the better your speaker system the more you'll notice , or depending on how you look at it, won't notice the difference in how your speakers and subs interact with each other. The xt will help your sub disappear in your soundstage to simplify things if I was trying to sell it to you.
butter and jelly please.
Home theater gladly not designed by ereed or bgtighe23. 65" JS9500, Marantz 7702MKII, Parasound Halo A31, ClassDaudio SDS470 4ch, RBH R56, 4xRBH R55, 2x RBH R5, Hsu VTF 2 MK 3 and VTF 3 for subwoofage, OnStage MS7701B mic stand with boom for improved Audussey XT32 calibrations. Listening space happily treated with 1" OC 703 rigid fiberglass. OPPO 203 or 205 soon.
pukemon is offline
Old 09-02-2012, 01:22 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
The 1712 has 6 HDMI while the 1612 only has 4.
1712 has more power and Audyssey MultEQ XT. It's worth the $60 difference.
Refurb Denon receivers should all have 1 year warranty if you buy from authorized dealer.
AC4Less sell the 1612 for $197 and the 1712 for $237.
http://www.accessories4less.com/make-a-store/item/DENAVR1612/DENON-AVR-1612-5.1-Channel-A/V-Home-Theater-Receiver/1.html
http://www.accessories4less.com/make-a-store/item/DENAVR1712/DENON-AVR-1712-7.1-A/V-Surround-Receiver/1.html
Afro GT
afrogt is offline
Old 09-02-2012, 05:52 AM
jdsmoothie's Avatar
Liked: 5508
You're thinking of Audyssey 2EQ on the lower level Onkyo AVRs which cannot EQ the sub but is not featured on any Denon AVR. MultEQ (1612) and MultEQ XT (1712) both use the same number of control points for the subwoofer.
Old 09-02-2012, 07:37 AM
skally's Avatar
From AC4L:
Stepping up from the 1612 to the 1712 adds:
Audyssey MultEQ XT instead of "regular" MultEQ
7 channels x 90 watts
The ability to "assign" the two extra amps
6 HDMI inputs (up from 4 on the 1312/1612)
2 Component Video inputs with 1 output
Dedicated "2CH DIRECT/STEREO" menu for configuring 2-channel audio differently than multichannel audio
Zone 2 functionality (no pre-outs, must be powered via the two "assignable" amps)
Room-to-room IR jack for hard-wiring a remote control (e.g. from another room or to hide gear in a closet)
NO USB port
IMHO for $60 extra the 1712 is a better choice. Its a 7.1 vs the 1612 is 5.1 and offers a few more options & HDMI's.
skally is offline
Old 09-02-2012, 12:19 PM - Thread Starter
Stealth3si's Avatar
Quoted: 32 Post(s)
so it doesn't matter whether i ahve a sub or not?
AVR: Denon 1712
Old 09-02-2012, 12:21 PM
Frankiebob5's Avatar
I've had a refurb 1712 for about three weeks. It replaced a pioneer I had. The difference in sound is night and day! Still trying to figure a few things out but I love mine.
I considered the 1612 but went for the 1712 for the Audyssey MultEQ XT set-up.
Frankiebob5 is offline
Old 09-02-2012, 12:47 PM
jdsmoothie's Avatar
Liked: 5508
Feel free to post any setup/troubleshooting questions on your 1712 in the Denon AVR-XX12 Owner's thread linked in my sig. Also review posts #3-6 in that thread for helpful information.
