Which Receiver For Me? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-02-2012, 11:03 PM - Thread Starter
jgaffney2008's Avatar
I've read thru several threads here, but I can't find the answers to my questions. So, here goes....
I'm replacing a Sony 5.1 receiver that I've had for about 10 years. The biggest reason for the replacement is that the Sony pre-dates HDMI inputs, so switching things on the TV usually requires 3 different remotes and a multi-step process. Also, I'm remodeling my back yard and I want to add speakers outside.
Here are the parameters I'm dealing with:
Price Range: $400 or so.
Availability: Best Buy is my first choice, but I'm not shy to order from Amazon, Crutchfield, J&R, etc.
Inputs: At least 4 HDMI inputs.
Output: 1 HDMI.
Network: Yes, preferably wifi.
Speakers: 5.1 in the main room, plus the two outside speakers.
iPod, iPad: Don't care. I have Android.
I don't plan on listening to a different source outside, but I do want to be able to shut the outside speakers off (can't wire in parallel with the fronts). Also, I don't want to go through the hassle of a separate amp for the outside speakers. A salesman at Best Buy tried to explain how to connect the second set of speakers to a 7.1 system, but he wouldn't tell me if they would be always on.
Thanks for your input.
jgaffney2008 is offline
post #2 of 7 Old 09-03-2012, 06:07 AM
jdsmoothie's Avatar
Quoted: 12254 Post(s)
Liked: 5583
Best Buy is clearing out last year's models at much reduced prices which should work for you just fine. Check the stores in your local area to see what inventory is still available. Select a 7.1 AVR that has powered Zone 2 capability (ie. 5.1 in the main zone and uses the Surr Back speaker posts for Zone 2, eg. Denon 1912 or 2112CI).
jdsmoothie is online now
post #3 of 7 Old 09-03-2012, 09:26 PM - Thread Starter
Mr. Smoothie:
I checked the Denon 1913 on the Denon website - quite a step up from my Sony receiver! Yes, I can fiddle with the assignable outputs and make my outside speakers do what I want them to. I was a little leery when the Denon owner's manual told me that it won't play a digital source in Zone 2...unless I use the Front B/Amp Assign to set the Front B speakers to parallel the Front A speakers. From my reading of the online Denon manual, this only has to be set once. Then, when I switch to Zone 2, the outside speakers come on in parallel with the inside front speakers, right?
Best Buy has the 1913 on sale for $50 off - big deal. Amazon Shopping has shown me a half dozen online retailers that have it for less. As soon as I convince my wife that we need a $500 receiver, I'll place an order.
post #4 of 7 Old 09-03-2012, 09:31 PM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
Better make sure those other retailers are authorized resellers of Denon products.
http://usa.denon.com/US/WhereToBuy/Pages/OnlineETailers.aspx
Sam S is offline
post #5 of 7 Old 09-03-2012, 10:03 PM
afrogt's Avatar
Quoted: 1062 Post(s)
Liked: 766
My local Fry's puts the 1913 on sale for $299 or $327 every 2-3 weeks...and they're authorized. In fact it was $299 today.
Afro GT
afrogt is offline
post #6 of 7 Old 09-04-2012, 06:33 PM - Thread Starter
Good point! Over half of the retailers listed on Google Shopping are not authorized retailers. And, I understand that buying from such a retailer will cause problems in the future with things like warranty, etc.
It's $530 right now, and I'd have to mail order it. I live in Sonoma County, and the closest retail outlet is in Concord. Unless it goes on sale, it's at the same price as Amazon.
post #7 of 7 Old 09-05-2012, 05:48 AM
jdsmoothie's Avatar
Liked: 5583
Mr. Smoothie:
The Surr Back/Amp Assign speakers can either be set to Zone 2 or Front B. If set to Front B, switching to Zone 2 won't do anything. If you don't use STEREO mode in the main zone, you could setup the Front B for STEREO mode and then when you select STEREO mode, the audio would automatically change to just the Front B (or when you want to play the same audio to both zones, simply change the Front Speaker Setup setting to "a+b").
Also note that you'll sometimes get a better deal when you "call" the authorized reseller rather than just going by what is posted on their website. Open box items from authorized resellers will still provide for the full 2 year warranty just as a new in box item will.
