Weird alarm with APC J10 battery backup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 09-03-2012, 03:49 PM - Thread Starter
Dizzyboy's Avatar
Quoted: 60 Post(s)
I've had an APC J10 since around 2006 and it's alarm just went off, its screen indicating "int. battery overtemp.". I powered the unit down and re-started it - the system did a self-test and now all is apparently well. This seems odd at best. Should I be concerned?
Dizzyboy is offline
post #2 of 9 Old 09-03-2012, 04:06 PM
pukemon's Avatar
Quoted: 290 Post(s)
Liked: 73
Probably not. Yet at least. It sounds like it was doing it's job. If it continues, probably need a new battery or new ups.
butter and jelly please.
Home theater gladly not designed by ereed or bgtighe23. 65" JS9500, Marantz 7702MKII, Parasound Halo A31, ClassDaudio SDS470 4ch, RBH R56, 4xRBH R55, 2x RBH R5, Hsu VTF 2 MK 3 and VTF 3 for subwoofage, OnStage MS7701B mic stand with boom for improved Audussey XT32 calibrations. Listening space happily treated with 1" OC 703 rigid fiberglass. OPPO 203 or 205 soon.
pukemon is offline
post #3 of 9 Old 09-03-2012, 04:08 PM
PeterK's Avatar
Quoted: 41 Post(s)
Liked: 54
I have used many small APC UPS systems at work. Yours is 6 years old and I sure would expect the battery to be at the end of it's life expectancy. Should not hurt to keep using it but I expect you will start to get more alarms in the near future. It is possible to order new batteries for it. Do a Google search on the model number to see what the cost would be.
PeterK is offline
post #4 of 9 Old 09-03-2012, 04:17 PM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
The batteries on the APC units generally last about 4 or 5 years; it's time for a new one. Just go to the APC website to order.
commsysman is offline
post #5 of 9 Old 09-03-2012, 09:51 PM - Thread Starter
Dizzyboy's Avatar
Quoted: 60 Post(s)
Thanks, everyone. I'll order a new battery. In the meantime, would it be best to power the unit down and simply not use it?
Dizzyboy is offline
post #6 of 9 Old 09-04-2012, 10:21 AM - Thread Starter
Dizzyboy's Avatar
Quoted: 60 Post(s)
Update: the machine has been powered down (turned off) since last night, just to be safe, and the alarm went off again just now, in spite of the unit being turned off (but not unplugged)! Should I just remove the battery now and leave the unit empty and unplugged until I can get a replacement?
Dizzyboy is offline
post #7 of 9 Old 09-04-2012, 11:06 AM
pukemon's Avatar
Quoted: 290 Post(s)
Liked: 73
Either or. Without battery it is just a surge protector.
pukemon is offline
post #8 of 9 Old 09-05-2012, 02:21 AM - Thread Starter
Dizzyboy's Avatar
Quoted: 60 Post(s)
K, thanks.
Dizzyboy is offline
post #9 of 9 Old 09-05-2012, 02:22 AM - Thread Starter
Dizzyboy's Avatar
Quoted: 60 Post(s)
So it can actually be run without battery while I wait for the new one? I hadn't realized that!
Dizzyboy is offline
