Help me with my first surround set up - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-03-2012, 10:24 PM - Thread Starter
Tbonenga's Avatar
Hello,
I have a new Sharp 70" 3D from Sams. I've never had a surround sound system. My room size is 15 x 32. My budget is $1,000. Well maybe up to $1,500. This is just for the receiver. My plan is to get the TV (done), get the receiver and then the speakers. My equipment: Comcast HD DVR, Xbox and I'm getting a ps3 so I can get the NFL Sunday ticket. I have a Bose 3 speaker setup on my computer that I got from Sams. I never new a computer could sound so good. I want that on a larger scale now for my TV. I think I want a 7.1 or 7.2 type of set up. Oh yeah if possible one with Sirius so I can jam Hair Nation time to time. Brands don't matter to me since I have no experience with any.
Tbonenga is offline
post #2 of 2 Old 09-03-2012, 10:39 PM
TazExprez's Avatar
If you're going to be using two subs, one receiver that gets recommended a lot is the Onkyo TX-NR3009. The 3009 has Sub EQ HT, which helps you set up two subs. If you're only using one sub, then you should probably get the TX-NR818. Another great receiver with Sub EQ HT is the Denon AVR-4311CI. If you want be able to upgrade to 11.1 in the future, then get the 4311.
HD-A1 + XBOX Add-On + PS3 = Format Neutral
TazExprez is offline
