Are there stereo amps for less than $500 with audyssey built in? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-04-2012, 08:51 PM - Thread Starter
flargosa's Avatar
I just bought two floor standing speakers(PSB T6), now looking for an 2.0 stereo amp with room correction built-in not necessarily audyssey . My living room is untreated and opens up to the kitchen with lots more walls. I'm guessing I will probably be getting distortions from all the walls and the wood flooring. Any suggestions? I'm thinking of getting a Marantz HT w/ audyseey built-in, but don't know if that is the best choice since I only need it for two speakers which are not even hooked up to my TV.
flargosa is offline
post #2 of 10 Old 09-04-2012, 08:54 PM
pukemon's Avatar
Quoted: 275 Post(s)
Liked: 70
Maratnz is the only one I know.
butter and jelly please.
Home theater gladly not designed by ereed or bgtighe23. 65" JS9500, Marantz 7702MKII, Parasound Halo A31, ClassDaudio SDS470 4ch, RBH R56, 4xRBH R55, 2x RBH R5, Hsu VTF 2 MK 3 and VTF 3 for subwoofage, OnStage MS7701B mic stand with boom for improved Audussey XT32 calibrations. Listening space happily treated with 1" OC 703 rigid fiberglass. OPPO 203 or 205 soon.
pukemon is offline
post #3 of 10 Old 09-05-2012, 05:27 AM
jdsmoothie's Avatar
Quoted: 12103 Post(s)
Liked: 5508
Keep in mind that a 5.1 AVR w/Audyssey will still allow you to run Audyssey on just 2 speakers connected. smile.gif
jdsmoothie is offline
post #4 of 10 Old 09-05-2012, 05:38 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
so you would not be using the receiver when watching TV? When would you use them?
Afro GT
afrogt is online now
post #5 of 10 Old 09-05-2012, 05:48 AM - Thread Starter
flargosa's Avatar
I have another audio setup for TV viewing, that one is 5.1 system located on the TV room. This one is for the living room solely for audio and will never be used with the tv, I really only need a stereo amp for this one, but looking for something with some sort of room correction to give a flatter response to the sound.
Is room correction recommended for stereo speakers anyway? or does it distort sound in some way? I'm new to this.
flargosa is offline
post #6 of 10 Old 09-05-2012, 05:59 AM
afrogt's Avatar
Liked: 755
I don't believe room correction distorts the sound at all. You'll always the the option to turn it offf though if you dont like the results.
Afro GT
post #7 of 10 Old 09-05-2012, 06:06 AM
jdsmoothie's Avatar
Liked: 5508
Room correction will EQ the speakers connected to the AVR, regardless of whether there are 2, 3, 4, ... etc. speakers connected.
post #8 of 10 Old 09-05-2012, 06:11 AM - Thread Starter
flargosa's Avatar
Is there a reason why room correction is rarely included on stereo amps, but common on home theater amps?
flargosa is offline
post #9 of 10 Old 09-05-2012, 06:24 AM
jdsmoothie's Avatar
Liked: 5508
Likely because there's no market for it and far more demand for 5.1/7.1 AVRs.
post #10 of 10 Old 09-05-2012, 06:04 PM
Kilian.ca's Avatar
Liked: 37
The vast majority of stereo integrated 'amps' are analogue only, very few are digital.
The only Marantz stereo receiver I can find on their website is the SR4023 and it doesn't mention Audyssey.
Even if a digital stereo amp/receiver has Audyssey, for <$500 it's likely to be an entry-level version, not more than MultEQ.
Don't expect room correction esp. lower versions to work miracles in a difficult room. Better to treat the room and concentrate on sub EQ.
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
