Yamaha rx-a720 "official" owner's thread - Page 11 - AVS Forum | Home Theater Discussions And Reviews
post #301 of 317 Old 02-16-2014, 02:14 PM
mknecht01's Avatar
Quoted: 91 Post(s)
Liked: 50
Originally Posted by ballerchris33 View Post
Question to all you smart folks: I am duplicating my display from my windows pc. When I run it straight to my TV. Video is smooth. But of course I want to run it to the receiver so I can the surround sound. However, the problem is there is artifacting meaning like there is lines that run through videos and games during playback. It does not happen when I run the HDMI from my pc directly to my TV only when I run through the receiver do I see artifacting. Do you know why that is? Any suggestions on how I could fix this?
Sorry for the delay, I don't visit here much any more. A couple of suggestions: First, try using a different HDMI input on the AVR. If that doesn't do anything for you, maybe check your video mode setting. If it is set to "processing," some sort of interaction between the output signal of your PC and the processing the AVR is trying to do may result in artifacts. That setting is accessed via the Option button just above and to the right of the circular arrow controls on the remote. "Video Mode" is the last thing in the "Option" menu that pops up. If it is set on "Processing" try switching it to "Direct" and see if it solves your problem.
Fronts: LSi7
Center: LSiC
Surround: LSiF/X
Sub: Infinity BU-2 - Don't judge me, it was free and I have neighbors.
AVR: Denon X3100W
Adcom GFA-7000 5-channel amplifier
mknecht01 is offline
post #302 of 317 Old 04-17-2014, 07:13 AM
RocNYRunner's Avatar
Quoted: 14 Post(s)
Zone 2 question.
Hi all. I'm wiring up a basement remodel. I'm planning on running speaker wires for a set of outside speakers to use on Zone 2. I'd like to have the Zone 2 music play upstairs in the family room as well. Can I use the "Zone 2 Out" jacks on the back of the receiver to run a set of cables upstairs to one of the inputs on my old Yamaha receiver to play the zone 2 audio up there? I'd like to run every thing I can before drywalling!
RocNYRunner is offline
post #303 of 317 Old 11-24-2014, 09:38 PM
el_Fernando's Avatar
Quoted: 13 Post(s)
Liked: 31
Just updated my rec to the latest firmware. Looks like it was recently released! Sweet!
Don't underestimate the power of stupid people in large groups.
el_Fernando is offline
post #304 of 317 Old 12-03-2014, 07:19 AM
SeauxCrazy's Avatar
My setup: I have all video run through my unit, with one hdmi running to my new 4k tv.
I know the unit upconverts to 4k resolution, but does it do this automatically through the video setting "DIRECT" or do I need to set it to "PROCESSING", set it to 4k? I've noticed when I do this, my blacks on my tv become muted and gray and the video is jittery. It's definitely noticeable while watching scrolling text at the bottom of CNN/ESPN etc.
Does DIRECT know to automatically upconvert to 4k since it's connected to a tv capable of that resolution? I may try different HDMI inputs on my tv to see if that solves the issues, but I was wondering if anyone could help me out. Thanks!
PS: I know cable providers only provide 720p/1080i, but upconverting definitely makes the image a tad clearer, especially on a larger TV.
SeauxCrazy is offline
post #305 of 317 Old 12-03-2014, 07:36 AM
kriktsemaj99's Avatar
Quoted: 653 Post(s)
Liked: 378
^ You need Video Mode = Processing (not Direct), and also choose an output resolution (which can be Auto).
Note that the A720 does not support 4K at 60Hz (max is 30Hz), so it might affect how smooth the video looks. It should not affect the black level though.
But all 4K TVs will convert their inputs to 4K (if they didn't the picture wouldn't fill the screen), and the TV might well do a better job than the A720.
kriktsemaj99 is offline
post #306 of 317 Old 12-03-2014, 07:44 AM
SeauxCrazy's Avatar
I was hoping the 30hz wouldn't be the cause of the smoothness of the video, but it could be. I'm running old firmware, noticed I had an update to firmware 1.20, which is way behind what the website has as the newest update (1.85). I'm going to update this afternoon and keeping fingers crossed there was something fixed in these updates. Is the 30hz/60hz a hardware difference or something that can be pushed through an update? The input I have it going through on the tv is the 60hz hdmi, may try the other to see if it solves my issues.
One more question, I know this unit has ARC, will this solve my issue of not having sound while using the "SmartTV" apps on the actual tv or will I need to run an optical cable to achieve sound? I need to dig to find out how to activate on the tv, if it's an ARC issue.
post #307 of 317 Old 12-03-2014, 08:47 AM
Quoted: 653 Post(s)
Liked: 378
^ Running an optical cable from TV to receiver will give you sound for the TV Apps (when you select that input on the receiver). ARC should work as well, but not all devices that support ARC play nice together. On the TV only one HDMI connector will probably support ARC (it should be labelled).
For 4K video, I think the 720 hardware is limited to 30Hz. Later models go up to 60Hz. But the upscaler on the receiver is not necessarily better than the one in your TV. So there's probably no real benefit from enabling processing in the receiver.
post #308 of 317 Old 12-13-2014, 09:13 PM
KeZrr's Avatar
So, late post, but I did end up adding a good sub and it made a tremendous difference. Sounds really, really good now and plenty of bass output. In fact, I have to keep the sub turned down quite a bit and it still produces a lot of bass. Perfect for my liking. Music and movies sound great, and if I'm feeling in the mood I can shake things off the walls.
Now, the real update is that I learned that all this time I did not have my player (ps3 slim) set up correctly and have not been getting lossless TrueHD or DTS Master. I now have it properly set up and WOW what a complete difference for my 7.1 set up!! I cannot stop watching BD movies now. Games are way better too, Advanced Warfare, for example, is pretty amazing.
This would have helped me, had I found it long ago, so I will post it here in the hopes it helps others (although most probably already know this unlike me lol). If running a ps3 as your player, be sure to go into manual HDMI audio settings and check everything but ACC. Bitstream or Linear PCM is up to you, but I use Linear PCM and let the player do the decoding rather than the AVR. If you're the type that wants your AVR to display the codec, choose bitsream.
KeZrr is offline
post #309 of 317 Old 01-30-2015, 06:21 AM
Liked: 0
Hello all,
I purchased a 720 last year and we just got a new TV that supports ARC. I want to take advantage of it but when I turn on the TV the receiver turns on automatically. Does anyone know if there is a receiver setting anywhere that will keep it from turning on when I turn on the TV? I want to have surround when watching TV but I want to control when that happens. I don't want surround all the time. Hope that makes sense.
I have a feeling that its not possible but thought I would ask my fellow 720 owners just in case!
atoddvr6 is offline
post #310 of 317 Old 01-30-2015, 09:46 AM
Quoted: 653 Post(s)
Liked: 378
Originally Posted by KeZrr View Post
...This would have helped me, had I found it long ago, so I will post it here in the hopes it helps others (although most probably already know this unlike me lol). If running a ps3 as your player, be sure to go into manual HDMI audio settings and check everything but ACC. Bitstream or Linear PCM is up to you, but I use Linear PCM and let the player do the decoding rather than the AVR. If you're the type that wants your AVR to display the codec, choose bitsream.
Over HDMI the PS3 should automatically select all formats the AVR supports, but it only does that when you explicitly run the auto-setup. So if (for example) you had previously done the setup when connected to a TV that only supports basic audio, it would remain that way after you connect it to the AVR. Re-running the auto-setup should fix it.
post #311 of 317 Old 05-18-2015, 12:23 PM
Lemnitzer's Avatar
I have a universal remote so I can turn on everything I need at the same time; the receiver turns on just fine. However it will not play audio out of the speakers. I have to turn the receiver off and then back on again for the audio. I believe that there is a setting that needs to be changed and I thought I read it here on boards one time but now I can not find it. If anyone knows how to fix this, please help. Thanks
Lemnitzer is offline
post #312 of 317 Old 09-12-2015, 04:00 PM
montyss's Avatar
Liked: 0
Region setting ?
Would anyone know which printed circuit board you would have to change to switch the region setting in Yamaha RXA-720 ? some of the Yamaha apps are not available unless you are in the US . Have tried updating the firmware to the newest by USB with no internet connection and still no apps ...
montyss is offline
post #313 of 317 Old 09-12-2015, 09:27 PM
Quoted: 653 Post(s)
Liked: 378
The firmware is the same for all regions, and a resistor on one of the PCBs determines the region (the firmware reads an A/D and gets a value that depends on the resistor that's installed), At least that's the way it used to work, but you'd need to check the 720 service manual to see if it's still done that way.
post #314 of 317 Old 09-13-2015, 07:20 AM
montyss's Avatar
Liked: 0
Thanks for the reply on my post ... can the resistor be changed or would you have to change the circuit board ? I do have the service manual for the RXA-720 / RX-V673
montyss is offline
post #315 of 317 Old 09-13-2015, 02:13 PM
Quoted: 653 Post(s)
Liked: 378
^ There can be other hardware differences as well. Changing the resistor to make the firmware think you have a different model can enable some features that are region specific, but not others (for example, the radio tuner has different frequency steps in different regions, and I believe the tuner itself is different). So there could be unwanted side effects.
What apps are not working for you, and what region is your model? Maybe the apps are checking that you have a US IP address, not that you have a US model?
post #316 of 317 Old 09-13-2015, 06:13 PM
montyss's Avatar
Liked: 0
I have the Can version and looking to get the apps available in the US , Pandora for example doesn't show in the menus
Currently running a blocker service for the ip address and all my other electronics are fine (working) except the Yamaha receiver
I'm just a stones throw from the border so everything else should be good
montyss is offline
post #317 of 317 Old 03-20-2016, 03:04 PM
allargon's Avatar
Quoted: 70 Post(s)
Liked: 49
I have a similar issue with my receiver. Now that it's a few years old, it will start popping on various speakers or playing high pitched garbage. I recabled my speakers and checked them. Test tones play fine. It's only after the receiver has been on for a few minutes.
I bought this Yammy instead of a similarly priced Onkyo because everyone swore Yamahas were so much more reliable!
allargon is offline
Yamaha Rx A720 7 2 Channel Network Aventage Av Receiver
