Yamaha RX A 2010 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-08-2012, 07:32 PM - Thread Starter
jpope's Avatar
any & all insight to this unit as I now see it is last years model (to the NEW 2020) but dont see that much difference???
Some stores have discounted the 2010 to under $1000 now and wondering if it is time to rid myself of my old RX-V3000?
some of the features I like and do get wtih the 2010 include Pandora and dual subwoofers.....
I can get Airplay by connecting my Apple TV box to the unit and that takes care of that.......
4k might still be "out there" so thinking it is not needed now??
Comments??
THANKS
jpope is offline
post #2 of 4 Old 09-10-2012, 07:17 AM
lflorack's Avatar
Quoted: 72 Post(s)
Liked: 59
Comments??
THANKS
I should have asked you where to buy my RX-A2010 on Saturady from Amazon since you can find it for under $1000.
The 2010 and 2020 are fairly similar with the most notable diffrerences are (as you suggested) AirPlay/dropping netweok radio support on versus no AirPlay but network support on the the 2020. Unless you really want/need AirPlay (you obviously don't), I'd get the 2010 -- especially if you can find it for under $1000. That's the choice I made.
Link: System Pix & Diagrams
Klipsch: (2) RF-83, (1) RC-64, (2) RVX-54, (2) RSX-5, SVS: (1) SB13-Ultra
Yamaha: Aventage RX-A2010, CDC-685, Oppo: BDP-93, JVC: Procision DLA-X550R
DragonFly: 16:9 133" High Contrast Screen, Apple: AppleTV, Roku: Roku4
Amazon: FireTV Stick, SimpleControl: IP Remote, Logitech: Harmony One
ACP: J15BLK 1.5 kVA Power Conditioner/UPS
lflorack is offline
post #3 of 4 Old 09-10-2012, 08:54 AM
cbragwel's Avatar
Bestbuy has them on clearance for $998 if you can find one. You can also negotiate that price down further. I purchased their demo model for a great price (in my opinion).
cbragwel is offline
post #4 of 4 Old 09-10-2012, 09:18 AM - Thread Starter
jpope's Avatar
I would like to have Airplay but cant I get Airplay IF I connect my NEW Apple TV (which has Airplay) to the 2010?
When you say "Network support" on the 2020, what do you mean? As I thought the 2010 has the Network support as well?
Just doesnt have the pandora, napster, sirus options?
Please advise
Yes, it is Best Buy.......if they still have one I will try to knock more off of it
thanks for the insight
jpope is offline
