The "Official" Pioneer Elite SC-61/-63 Owners Forum - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #721 of 929 Old 01-02-2014, 01:56 PM
LastButNotLeast's Avatar
Quoted: 1774 Post(s)
Liked: 1395
Typically, a short in the speaker wires. Check them (at both ends) carefully.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #722 of 929 Old 01-03-2014, 07:56 AM
SF FAN's Avatar
I have a question I have the sc-61 and it seems like my subwoofer isn't on all of the time ? Any ideas what it could be ?
Thanks in advance !
SF FAN is offline
post #723 of 929 Old 01-03-2014, 10:39 AM
Liked: 1395
Try turning the gain on the sub down and the sub output on the AVR up (to get to the same volume).
post #724 of 929 Old 01-03-2014, 01:05 PM
missourian's Avatar
Just scored a brand new SC-63 from BB on clearance, this my first AVR, planning for a simple 5.1 setup to start with. The unit was manufactured on May 2012 according to the box, do I need to do any type of firmware upgrade?
missourian is offline
post #725 of 929 Old 01-03-2014, 02:50 PM
ljn21's Avatar
When I did the hard resets, had everything unplugged except the power cable. I use bananna plugs and everything worked fine on my old Harman unit that this is replacing before the swap and after, I looked carefully at both ends of each speaker wire, no loose strands. We are moving from FL to MN in 13 days so I am in a goofy position, cant drop it off for service as the local authorized repair center said 14-21 days, could not gaurantee it would be ready by our move date, if I wait to get it fixed in MN, I will be outside the return date to Bestbuy...anybody know how Pioneer's warranty works, if for some reason it cant be fixed, does Pioneer refund purchase price or do they substitute a replacement?
ljn21 is offline
post #726 of 929 Old 01-03-2014, 04:50 PM
missourian's Avatar
Ohh that sucks, if I were you I would simply return the item to bestbuy and get the money back. My speakers won't here until monday, I am waiting to connect mine and I hope it won't have any issues like yours
post #727 of 929 Old 01-03-2014, 05:19 PM
downsc123's Avatar
if you want the subs to be on all the time, you need to set the subwoofer to "plus".
downsc123 is offline
post #728 of 929 Old 01-04-2014, 10:57 AM
jrhooper1963's Avatar
Quoted: 99 Post(s)
Liked: 38
I see the SC-63 on E bay for $725 new. Is this a good deal ?? I realize this would be from an unauthorized dealer as well. Is there a better deal out there on a new Elite model? Do any authorized dealers give good "over the phone" discounts?
jrhooper1963 is offline
post #729 of 929 Old 01-04-2014, 02:29 PM
ureshiidesuka's Avatar
Hey all,
I just gor the sc-63, and i cant seem to get my sub to work
plugged the coax into the LFE port on the klipsch sub, and the other end into the preamp sub 1 plugin
i do the auto levels adjustment with the mic, and the sub doesnt seem to be outputting anything. however if i go to adjust db manually, you can hear it pulsing with each increase in db, but there is no bass humm.
i dont know whats going on here, as the sub should be working fine. tapping the other end of the coax will make it rumble just fine as well. i tried both sub 1 and sub 2 ports for the preamp section. new monoprice sub coax cable
set speakers to small, cross over is at 100
still nothing comes out of the sub... when i increase the volume on the receiver the sub seems to be pulsing with each increase step in volume, which is really weird. any ideas?
ureshiidesuka is offline
post #730 of 929 Old 01-04-2014, 02:30 PM
jrhooper, i saw a couple sc67s for open box at best buy online, check your area. i found some for 500, sad that i bought my sc63 for 635 now
post #731 of 929 Old 01-04-2014, 02:58 PM
missourian's Avatar
$725 is high but if you decide to go through ebay route ask the seller for receipt for registration and warranty
post #732 of 929 Old 01-04-2014, 03:00 PM
missourian's Avatar
PCM audio
I need help, I connected my Bluray player to SC-63 but when I watch "Life of Pi" with DTS 7.1 Master HD on the receiver screen I see "PCM", is this normal, right now I am still waiting for my 5.1 speakers but I connected it with 2 bookshelf speakers as of right now.
I couldn't able to here any dialog just only the parts of music and some background :-)
post #733 of 929 Old 01-04-2014, 05:16 PM
downsc123's Avatar
Originally Posted by missourian View Post
PCM audio
If you receiver is saying PCM, it means that the blu-ray player is doing the decoding. Switch the blu-ray to bitstream and your receiver will then do the decoding.
post #734 of 929 Old 01-04-2014, 05:37 PM
missourian's Avatar
Thank you , I changed to Bitstream(unprocessed) and also I just did the auto calibration, Now I see it says stereo  and also DTS HD , attached the image for your reference. As I mentioned earlier my current setup is only with two front speakers.
Please let me know if this doesn't look correct
sc-63.jpg 47k .jpg file
post #735 of 929 Old 01-04-2014, 06:36 PM
downsc123's Avatar
The dts ma indicates that the receiver is decoding that audio track from the Blu ray. The stereo indication is the sound field that you currently have selected which would be appropriate for your 2.0 setup.
missourian likes this.
post #736 of 929 Old 01-04-2014, 07:02 PM
missourian's Avatar
Awesome thanks, appreciate your help, also HDMI switching was very slow, as recommended by AVS forum member set the Video out put as 1080P (passthrough) and let AVR do its job, no more issues with HDMI switching, I feel I learnt a lot in while setting up my home theater
post #737 of 929 Old 01-04-2014, 07:15 PM
JChin's Avatar
Quoted: 367 Post(s)
Liked: 210
Hi Missourian, you have SP: A+B on. Do this cause any issue with incoming DTS HD audio, like down mix to 2 Ch?
JChin is offline
post #738 of 929 Old 01-04-2014, 07:43 PM
missourian's Avatar
I almost fixed all of the issues except one annoying issue
My Config
Tivo HDMI OUT ------->Pioneer SC-61 CBL/SAT HDMI IN
Pioneer HDMI OUT ------------->Samsung HDMI 2 ARC
When I switch on the receiver it power on TV and Receiver and I see picture from TIVO for say 10 seconds and immediately my receiver switches the source to TV and I lose picture in TV , I need to select CBL/SAT from pioneer remote to get the picture back.
I am going to call Pioneer on Monday, this is irritating I am not sure what I am doing wrong
post #739 of 929 Old 01-05-2014, 08:08 AM
Done Deal DR's Avatar
Quoted: 98 Post(s)
Liked: 146
Sounds like an HDMI CEC issue to me, try disabling it to see if that corrects the issue.
Home Theater Build in Progress (Contemporary living room, Klipsch RF-7 II 5.2 audio, Sony VPL-HW50ES Projector, Da-Lite 16:9 159" HP, recessed Mid Atlantic rack, etc)
Done Deal DR is offline
post #740 of 929 Old 01-05-2014, 08:53 AM
missourian's Avatar
Yes it works, but I couldn't able to adjust volume and power off/on receiver using TV remote,
post #741 of 929 Old 01-06-2014, 08:35 AM
Quoted: 98 Post(s)
Liked: 146
That's the downside of HDMI CEC, it's garbage. I know that's not useful at all and I'm sorry, but it's just the most half baked buggy feature possibly ever implemented that had the possibility of being great. It works in some rare cases between certain devices, but overall it's just going to introduce annoying bugs like you are experiencing.
I'd recommend getting a quality universal remote and disabling HDMI CEC completely on all devices.
post #742 of 929 Old 01-06-2014, 09:27 AM
ss9001's Avatar
Quoted: 358 Post(s)
Liked: 423
+1
While it does work for me on SC-09 and SC-68 with a Pioneer Elite 151 Kuro plasma (it should work! wink.gif) I leave it turned off and have no use for it. One more thing to troubleshoot when things get flaky and whether it works or not highly depends on how it's implemented by the TV mfg and receiver mfg. some combinations work and by numerous posts in this forum, it's clear some combinations don't work.
just like Audio Return Channel (ARC), for many, it ends up being more problems than it's worth. and it will usually force the receiver to start up with the TV input even if that was not the last one used.
leave it off and you'll be happier not trying to make something work that won't wink.gif
a programmable remote with some simple macros to start the TV and AVR at same time can be far less troublesome.
Done Deal DR and missourian like this.
Steve
ss9001 is offline
post #743 of 929 Old 01-06-2014, 09:39 AM
missourian's Avatar
Yes I learnt my lesson, in the process of learning I powered on & off my SC-63 and TV excessively, Do you guys have any recommendation for universal remote? A decent one, which needs to be operated by non techy spouse,little kids and teenagers.
post #744 of 929 Old 01-06-2014, 02:30 PM
Quoted: 98 Post(s)
Liked: 146
It doesn't get much easier than Harmony. I prefer the older line, including the Harmony One if you have IR line of site or Harmony 900 if you don't have IR line of site. I've had a couple of each and they are fantastic and anybody can use them, and just about anybody could set one up... very easy.
There are some other brands and various price ranges, but I think the Harmony is the best combination of build quality, ease of set up, ease of use, and value. I'm in the process of setting up an iRule remote on an iPad. It's a lot more work, and while I'm capable of it, it's certainly not easy. Right now another person may be able to use it, but they'd need a rundown of how it worked first. I would have stayed with a Harmony but my set up necessitated going this route due to different physical locations of the equipment.
missourian and sigpig like this.
post #745 of 929 Old 01-06-2014, 02:31 PM
Quoted: 98 Post(s)
Liked: 146
Originally Posted by ss9001 View Post
+1
Great point, USUALLY devices of the same brand work together (but of course not always), however once you start mixing brands all bets are off.
post #746 of 929 Old 01-06-2014, 05:28 PM
missourian's Avatar
 I got my HD300 today, to connect the subwoofer will this cable work?
amazon Subwoofer cable
post #747 of 929 Old 01-06-2014, 06:03 PM
Liked: 1395
Sure, or you could spend half that and get one from here:
http://www.monoprice.com/Search?cp_id=12004&keyword=rca%20subwoofer%20cable
or here, depending on shipping:
http://www.parts-express.com/cat/subwoofer-cables/2145
I hope you are aware that all you need is an RCA plug to RCA plug cable. It needn't be anything fancy, just long enough to reach your sub.
You might even find one at your local Shack:
http://www.radioshack.com/product/index.jsp?productId=2102945
post #748 of 929 Old 01-06-2014, 09:35 PM
missourian's Avatar
 thank you, I have ordered some banana plugs, high speed HDMI and one more sub woofer cable, they charged me $8 shipping but still good price
post #749 of 929 Old 01-06-2014, 09:54 PM
JChin's Avatar
Quoted: 367 Post(s)
Liked: 210
Hi Missourian, if your order is over $30 and this your first time as a monoprice new member you can get $10 off by applying code TAXACT10.
JChin is offline
post #750 of 929 Old 01-08-2014, 07:49 AM
missourian's Avatar
Thank you JChin
