The "Official" Pioneer Elite SC-61/-63 Owners Forum - Page 30 - AVS | Home Theater Discussions And Reviews
 2Likes
post #871 of 899 Old 06-19-2014, 07:55 PM
tlb48's Avatar
how would you wireless stream rhapsody from a computer to sc-63 ?
tlb48 is offline
post #872 of 899 Old 06-19-2014, 09:46 PM
Done Deal DR's Avatar
Quoted: 76 Post(s)
Liked: 131
Purchase the Airfoil PC app, it allows you to select any application on a PC... such as a browser, and stream it to any airplay device (such as your receiver). It's a simple but rock solid App and well worth the money.
Home Theater Build in Progress (Contemporary living room, Klipsch RF-7 II 5.2 audio, Sony VPL-HW50ES Projector, Da-Lite 16:9 159" HP, recessed Mid Atlantic rack, etc)
Done Deal DR is online now
post #873 of 899 Old 07-06-2014, 09:09 AM
Lancair's Avatar
AVNavigator
When I install the AVNavigator disc that came with the SC-61 it gives me an option to choose a language. I choose English but it installs the program in either Japanese or Chinese which makes it useless to me. Did anyone else have this problem?
Lancair is offline
post #874 of 899 Old 07-06-2014, 10:20 AM
ss9001's Avatar
Quoted: 283 Post(s)
Liked: 355
which version of Windows?
been awhile but IIRC, I think this happened to some for one of 2 reasons:
1. when they didn't have admin privileges, or user-access control was not turned off. try temporarily disabling UAC, install with an admin acct or or right click on the exe file and see if you have options to install as admin or in XP mode.
or
2. they didn't have newer versions of .Net Framework installed.
I can't remember which one but #1 should be EZ to try. If #1 doesn't work, then go into Add/Control Programs and see which Win Service Packs & .Net Frameworks are installed.
Steve
ss9001 is offline
post #875 of 899 Old 07-06-2014, 02:46 PM
Lancair's Avatar
or
Thanks, you're right it needs to be installed as administrator otherwise it picks a random language. Got it installed but it's not very helpful in setting up all the various inputs.
Thanks again
Doug
Lancair is offline
post #876 of 899 Old 07-07-2014, 12:33 AM
andremedia's Avatar
Hey Everyone,
I have an SC-61 with a 5.1 Def-Tech setup inside the house (zone1) and 2 bose outdoor speakers outside (zone2). Currently im not able to play anything that is connected to zone1 on my zone2 speakers. I want to be able to play sporting events on my ourdoor speakers as well as my indoors while we bbq outside. Any ideas on how i can do this?
andremedia is offline
post #877 of 899 Old 07-07-2014, 07:07 AM
JChin's Avatar
Quoted: 140 Post(s)
Liked: 140
Originally Posted by andremedia View Post
Hey Everyone,
Hi andremedia, only analog input sources are output to zone 2.
JChin is offline
post #878 of 899 Old 07-25-2014, 08:27 PM
chirpie's Avatar
Quoted: 53 Post(s)
Liked: 94
No surround from games on XBOX 360
Hey all, I'm late to the party on this receiver. (SC-63)
I picked one up and finally got around to hooking it up.
Everything seems to be working fine minus one weird issue.
When I try to play games on the XBOX 360, there's no surround sound. The reciever shows it's getting a 5.1 signal (speakers light up on the front display), but there's no sound coming out of my rear speakers. XBOX is set to surround output in settings and it's a direct HDMI cable from the XBOX to the SC-63. I tried turning on the components in different order, changing the 360 from surround to stereo and back, just to see if it was some sort of odd handshake, but no dice.
PS3, blu-ray player, and Apple TV are all working fine. This is the only one acting up. If I were to guess, the XBOX 360 is at fault, but I thought I'd hit up people here to see what they thought.
Or should I hit up the 360 forum for this question? Thanks for any and all ideas!
chirpie is offline
post #879 of 899 Old 07-26-2014, 10:02 PM
MCNE's Avatar
Quoted: 12 Post(s)
chirpie is it just an HDMI connection? I dont have the SC-63 but I just bought the SC-61 open box for what I thought was cheap but who knows. Anyway I have a few Xbox units the look at. I use the mobile app as well to see if its 5.1 coming in and going out as well that might help troubleshoot.
MCNE is offline
post #880 of 899 Old 07-27-2014, 09:16 AM
chirpie's Avatar
Quoted: 53 Post(s)
Liked: 94
Yes, it's a straight HDMI cable from the 360 to the receiver. Only stereo comes out.
PS3 outputs a surround signal, as does the Apple TV and the Blu-ray player.
I'll take a peak at the mobile app. My guess is if the front display of the actual receiver says it's receiving a surround signal (Even though nothing comes from anything but the front two speakers), then the mobile app will probably show it incorrectly as well. We'll see. Thanks!
chirpie is offline
post #881 of 899 Old 07-27-2014, 09:33 AM
JChin's Avatar
Quoted: 140 Post(s)
Liked: 140
Hi chirpie, as a test what happens when the Xbox is swapped with PS3, ATV or BD player input?
JChin is offline
post #882 of 899 Old 08-01-2014, 09:33 AM
chirpie's Avatar
Quoted: 53 Post(s)
Liked: 94
The same thing happens. (Always best to check though.)
So last night the daughter put in some different games and lo and behold the rears came to life. So maybe I need to be asking a more obvious question... are some games actually in regular stereo and not surround? (I'd be surprised if the Dance Central series was only stereo)
Odd thing is, even when I try a setting like Dolby Pro Logic II [MV] for the stereo only games, it still comes out as stereo only.
I've only seen tiny scrapes of ideas on other forums that floated a theory that it could be a HDCP issue causing stereo only, but never any concrete proof.
If that were the case, maybe my old projector is part of the problem? I'll have a new one in next week and watch to see if that behavior changes.
Thanks for the ideas everyone.
chirpie is offline
post #883 of 899 Old 08-01-2014, 09:49 AM
JChin's Avatar
Quoted: 140 Post(s)
Liked: 140
The only other thing to check is to see if turning off Display Discovery" on the Xbox will solve the issue.
JChin is offline
post #884 of 899 Old 08-01-2014, 12:59 PM
Quoted: 76 Post(s)
Liked: 131
Do you also have a standard display connected through a dual HDMI output at any part in the chain? I know this is an SC-61/63 thread, which I own and clearly it doesn't have a dual HDMI output, but perhaps you're running an HDMI splitter at some point in the chain? This can cause issues and can sometimes cause it to downmix to stereo. I can't think of anything else, I've used both a 360 and a One with my SC-61 with no issues.
post #885 of 899 Old 11-04-2014, 12:12 PM
neurot's Avatar
Quoted: 21 Post(s)
Atmos for SC-61 SC61 Pioneer Elite
Does the Pioneer Elite SC-61 (SC61) support the new Atmos standard? I don't think so, but want confirmation.
neurot is offline
post #886 of 899 Old 11-04-2014, 12:47 PM
Quoted: 76 Post(s)
Liked: 131
No.
post #887 of 899 Old 11-08-2014, 06:26 AM
mgproudfit's Avatar
Does anyone else have issues when streaming Pandora? Every third song or so, the playback stops at :04 seconds in. Sometimes it starts again on its own but other times it just gets hung up and I have to switch inputs then switch back for it to work. Is there a new firmware I could download to fix that? When I have Pandora on I'm usually around the house and would love for it to work properly so I don't have to keep messing with it.
Matt
mgproudfit is offline
post #888 of 899 Old 11-27-2014, 06:33 AM
MCNE's Avatar
Quoted: 12 Post(s)
Matt
The SC-61 I have it works fine. At time it runs for hours so no issues. Could it be your network possibly?
MCNE is offline
post #889 of 899 Old 12-05-2014, 09:43 AM
mattwelke's Avatar
Hey guys I have a issue with my SC-61 going into shutdown mode its really wierd. I assumed at first it was because I was turning it up too high and it was putting a strain on my speakers. I ended up buying external amps to run my speakers and it was still happening which is when I really started to wonder.
Then even after disconnecting all my speakers and running it with nothing but the power cable hooked in, when I turn it up to about +5 to +10 the amp just shuts off. Im trying to return it but the store warrenty computer system has been down for a few days so I can't even get an return answer. Wondering if this is a common problem?
mattwelke is offline
post #890 of 899 Old 01-14-2015, 09:17 PM
hogsrul's Avatar
Treble or Bass settings? Also, how do you reset the receiver?
Hey all,
I have the SC-61 and for some reason, seem to be locked out of alot of screens to adjust settings individually. i.e. Treble and Bass, etc.
Also, is there a way to reset the receiver back to factory settings?
Thanks, love this forum!
hogsrul is offline
post #891 of 899 Old 01-14-2015, 10:29 PM
Aarghon's Avatar
Quoted: 48 Post(s)
Liked: 309
@hrosgul :
http://www.ehow.com/how_7641168_rese...receivers.html
Polk Audio LSIM703, Polk Audio LSIM704c, Polk Audio RTI-A1 surrounds
Dual Reaction-Audio BPS212
Pioneer Elite sc-61 AVR, Rotel RMB-1095 power amp
Pioneer Elite n50 network player
Marantz CD6004 cd player, Marantz UD5007 Blu ray player
Panasonic Tcl55dt60 led tv,Playstation 3 and a lot of old consoles
Aarghon is offline
post #892 of 899 Old 01-16-2015, 09:06 AM
dharris1969's Avatar
Looking at possibly going to a 4 ohm speaker, is there a switch or something that tells the receiver that the speaker is 4 or 8 ohm?
dharris1969 is offline
post #893 of 899 Old 01-16-2015, 10:01 AM
Quoted: 76 Post(s)
Liked: 131
No there isn't.
post #894 of 899 Old 01-16-2015, 10:29 AM
Originally Posted by Done Deal DR View Post
No there isn't.
Thank you for the response :-) So I guess it does it all automatically, cool!
post #895 of 899 Old 01-29-2015, 05:25 PM
Odys's Avatar
Is the SC-63 capable of 7.1 analog audio connections? I've only used HDMI so far, but I just bought an Oppo 105D and wanted to use HDMI for video, but analog for stereo and surround music (DVD-A, SACD & BD). The analog connections on the back of the SC-63 say Pre-Out. Shouldn't they be inputs? The Oppo's connections say output. You can't connect an out to another out, right? Sorry if this is a stupid question.
Odys is offline
post #896 of 899 Old 01-29-2015, 06:07 PM
Aarghon's Avatar
Quoted: 48 Post(s)
Liked: 309
Hello Odys!
I don't know if I will answer your questions, maybe you'll already know what I will tell you.
The pre-amp outs are really outs. They are designed to use the signal that the pre-amp stage of your AVR pre-amplifies and send it to a separate amplifier if you want to get better/more power than what the sc63 amps are capable. It'S what I do with my Sc-61. The Pioneer is now a preamp/surround processor.
Secondly, to separate the audio from HDMI you'd need some kind of passthrough... It is feasible, but I doubt it would worth the hassle.
Hope I helped a little
Odys likes this.
Aarghon is offline
post #897 of 899 Old 01-29-2015, 07:35 PM
Odys's Avatar
Originally Posted by Aarghon View Post
Hello Odys!
Thanks! That's what I figured, but I thought I should ask in case I was missing something.
Aarghon likes this.
Odys is offline
post #898 of 899 Old Yesterday, 12:10 PM
WizeGuyDezignz's Avatar
Hey guys, I have some questions about the SC-61. I already have a Pioneer VSX-1123-K that I bought less than a year ago brand new. There is a guy locally who is willing to sell me his Pioneer Elite SC-61 for $380 in mint condition with all accessories included.
Should I do it? Would it be a nice upgrade, or mostly a sidegrade? I can probably sell my 1123 in the $200-250 range. Would the SC-61 be worth the extra money and hassle involved making the switch?
Also, I really like how the volume and input show up on my TV screen when I change the volume, etc. Does the SC-61 do this? I thought I heard that it didn't, but I was just curious.
WizeGuyDezignz is offline
post #899 of 899 Unread Today, 10:12 AM
Quoted: 76 Post(s)
Liked: 131
Pro: Class D amp section on the SC-61 is much stronger than the A/B on the VSX series, and includes pre-outs if you want to use an external amp.
Con: No OSD for volume, etc. Set up menu is on-screen, but nothing else is.
If you need the stronger amp section, it might be worth it... but you'd be taking a step back in modern features being that the SC-61 is now about 3 models years old. The no OSD is the main reason why I'll eventually need to replace my SC-61, being that I don't have line of sight to the AVR it makes relatively simple things like volume or mode changes difficult... but if you have line of sight visibility this may not be as much of a deal breaker. The amp section is as much as you could ask for even at original MSRP compared to the competition... for $380 it's unheard of.
