The "Official" Pioneer Elite SC-61/-63 Owners Forum - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #901 of 923 Old 04-06-2015, 09:36 PM
realnt's Avatar
Quoted: 28 Post(s)
Originally Posted by 000528958 View Post
Hey hey! So I am having an issue with my Pioneer Elite sc-63. I am not able to get an internet connection with this receiver (at least I think that is my issue). So I currently have DHCP set to "on" and I have an IP address assigned when I look under "network information". Does this mean I am connected to the internet. Either way, I do not have access to internet radio, pandora, etc. and the icontrolAV app/AVNavigator cannot find my receiver on the network. I have tried assigning a static IP address when turning DHCP "off" but no luck. I also have my Network Standby set to "on". I would love any advice or help you all can offer. Thanks in advance for any and all help!
ABC
try factory reset I thought my network port was bad not even hardwiring did nothing but factory reset worked for me.
realnt is online now
post #902 of 923 Old 05-03-2015, 04:37 PM
tjaltz's Avatar
Pioneer SC-61 and DirecTV HR34 HDMI
I have a Pioneer Elite SC-61 receiver that I had been using with a DirecTV HR-24 with no problems. I recently changed to a DirecTV HR-34 (Genie) connected the same way the previous DirecTV unit was connected, with one 6 foot HDMI cable to one of the SC-61's HDMI inputs, and another 6 foot HDMI from the SC-61's output to my TV. Since the installation of the DirecTV HR-34, when the receiver is turned on after being off for several hours, it does not pass video, and sometimes does not pass video or audio. Turning the DirecTV receiver or the SC-61 off and back on do not resolve the issue. If I unplug the SC-61 from power, the reconnect it, it will pass the DirecTV audio and video and works okay? When the SC-61 id off, the HDMI light on the front of the unit flashes. When it is working properly, the HDMI light on the front of the unit is solid. Has anyone else experienced this? Any assistance would be appreciated.
tjaltz is offline
post #903 of 923 Old 06-09-2015, 11:07 PM
Liked: 0
This is my first post not sure how to do it
Sc61 7 speakers and sub
Two questions when listening to movies 5 speakers work how do i get 7....is it the movie only has 5 channels
Next ? When listening to my ipod through the usb or headphone jack. Only front two speakers work
The dvd plays 5 speakers from movies but only 2 when playing a cd
Test tones play all speakers
rickentent is offline
post #904 of 923 Old 07-17-2015, 12:08 PM
Liked: 1
Hello all, I have been scowering through the forum to see if anyone has had a similar issue with the Pioneer Avnavigator browser setup pages not displaying the information so i can setup my SC-63 with a new configuration. The browser I am using when i run the software is Internet Explorer 11 Windows 7 and it does ask me if i would like to enable scriptx which i say yes to however it will not display the content properly. I also installed the disc on two other computers in order to ensure its not an installation problem and was able to replicate this issue on all three.
Any help is appreciated.
JD
jdtibbett is offline
post #905 of 923 Old 07-20-2015, 10:25 PM
Liked: 0
Hello everyone! New here just upgraded my old JVC RX-809v to the Elite SC-61. I have a couple question that I'm sure you experienced folks can answer off the top of your head (have tried to search, but having no luck). First off I have yet to get around to hooking up rear speakers for the surround, I have it set up in the "B speaker" configuration, I have a L, C, R and a powered sub hooked up, I have run the MCACC for the two seating positions I have and have two speakers in a separate room but don't want to run them as a separate zone (plan on creating a Zone 2 in another room). I get great sound in my main room using Pandora, Milk Music from my TV and a Bluetooth dongle I have going into the CD input. I, however, get crap sound out of the speakers I have running from the "B speakers"- lower volume and they just sound bad. It's not the speakers because they worked fine when I had them hooked up to my JVC and got the same quality of sound whether I selected A, B or A&B, now not so much. Is there a cure for this or am I stuck with lower quality sound out of my "B speakers"?
Second question, I sometimes like to have the TV on but have sound from a different source playing out of the speakers. Is it possible to have video run through the receiver to the TV while still being able to listen to music from my Bluetooth dongle? I have my Direct TV running into HDMI 2 and then out of the receiver to the TV, I have control turned off and I have it set to pass through in standby. Big thanks ahead of time for any help thrown this newbies way.
Jimpaine1 is offline
post #906 of 923 Old 11-02-2015, 02:12 PM
Liked: 1
I have an SC63, and I have read through the threads, and i am looking to setup of ZONE2 which is dedicated to the backyard so that i may play spotify through chromcast. I know the reciever does not support play through via hdmi, however i was reading about matrix's. Im just not sure how this will all work out before i spend the money on one i want to be sure.
post #907 of 923 Old 12-17-2015, 07:48 PM
dharris1969's Avatar
Quoted: 14 Post(s)
Just purchased Sony XBR-55X850C 4k display. Question, if I send my video feeds through my SC61 will the feed be degraded? Should I connect Dish Net and BRP directly to TV?
dharris1969 is offline
post #908 of 923 Old 01-01-2016, 10:10 PM
Nemesiss's Avatar
Hi,
I had posted this question in another part of the forum which seems to be the wrong forum. I can't move it so I apologies for the repeat question. The amp I'm using is the SC-1227-k which from my understanding is the same as the SC-63 model. My TV is the Panasonic ST60. I don't know if this is an amp issue or a TV issue at this point.
I can't get the TV sound to output to my receiver if I'm playing something on the TV. (eg, netflicks) I have the HDMI cable connected to the 2nd hdmi connection on the TV, I have turned on the ARC feature within the receiver and I when I go to the VIERA menu and change the sound output from TV to Home theatre, it's still not working and through an error. Normally I run my cable box through the receiver which has the TV sound but for the odd instance that I want to run the apps on the TV I can't get the sound to go through to the receiver.
The error I get when I set the TV to output to the home theatre setting is to check the connections.
Is there something I'm missing here?
Nemesiss is offline
post #909 of 923 Old 01-01-2016, 10:49 PM
JChin's Avatar
Quoted: 348 Post(s)
Liked: 204
Hi Nemesiss, beside setting Viera Link from Main Menu also on the TV's remote control hit the Apps button and go to the Viera Link app. Then set Speaker Output to Home Theater.
JChin is offline
post #910 of 923 Old 01-02-2016, 10:20 PM
Nemesiss's Avatar
Thanks for the reply. On my remote all I have is the Apps button. If I go to the Viera link once in the apps and click on it, I don't get any options. I only get an online message "feature unavailable"
Nemesiss is offline
post #911 of 923 Old 01-03-2016, 07:40 AM
JChin's Avatar
Quoted: 348 Post(s)
Liked: 204
Could try replacing the HDMI cable between receiver and TV (power down, unplug power cord and replace HDMI cable).
JChin is offline
post #912 of 923 Old 01-26-2016, 04:37 PM
Ron6000's Avatar
This morning my SC 61 started automatically switching to the TV input function after being on for a minute or so. Any suggestions what could be causing this?
Ron6000 is offline
post #913 of 923 Old 01-26-2016, 05:10 PM
scoobdude's Avatar
Quoted: 59 Post(s)
Liked: 30
Hdmi-cec
scoobdude is offline
post #914 of 923 Old 01-27-2016, 08:28 AM
Ron6000's Avatar
Originally Posted by scoobdude View Post
Hdmi-cec
That was it. Thanks.
Ron6000 is offline
post #915 of 923 Old 02-15-2016, 07:10 AM
Lack of SiriusXM Support
Did not know if others are aware of this, but Pioneer no longer supports SiriusXM on the SC-61/63 receivers. Apparently Sirius has changed their streaming protocol, and Pioneer is not going to update their legacy receivers to support the new protocol. You have to stream from the app. Kind of a bummer.
jthomp27 is offline
post #916 of 923 Old 02-15-2016, 07:18 AM
jthomp27 is offline
post #917 of 923 Old 05-01-2016, 11:05 AM
Quoted: 14 Post(s)
SC-61 ohm setting
does the sc-61 have setting I need to change from 4-8 ohm?
post #918 of 923 Old 06-05-2016, 01:41 PM
CHASLS2's Avatar
Quoted: 354 Post(s)
Liked: 125
My SC61 is still going strong. Had it since 2012.
Panny 60VT60 Acurus 200x3
OPPO 83 &103
Pioneer Elite DV 59AVI
Paradigm 490cc B&W 685 S2's
Pioneer Elite SC61 SVS SB13Ultra
2 S-VHS VCR's B&W CM10 S2's
CHASLS2 is offline
post #919 of 923 Old 06-29-2016, 07:04 PM
Liked: 0
I have a SC 63 which died last month. Started with UE22 issue then no sound. Since Onkyo purchased Pioneer service is very poor. I need a main board assembly part AWX1200. They are saying September now but one week before it was August. I am losing hope. Does anyone know where I can get the board (AWX1200)? I would be eternally grateful!
kmanglos is offline
post #920 of 923 Old 06-30-2016, 09:11 AM
LNEWoLF's Avatar
Quoted: 222 Post(s)
Liked: 133
This maybe helpful
http://www.avsforum.com/forum/90-receivers-amps-processors/2066818-ue22-error-master-thread-pioneer-you-listening.html
kmanglos likes this.
LNEWoLF is offline
post #921 of 923 Old 08-02-2016, 10:56 AM
Liked: 0
Well I have an update-Sept 2016 :
kmanglos is offline
post #922 of 923 Old 09-21-2016, 09:51 PM
Liked: 0
NO part-gave up and bought a Yamaha Rx-V779......
kmanglos is offline
post #923 of 923 Old 01-08-2017, 08:53 PM
Nemesiss's Avatar
Hey,
I'd like to know if anyone else has experienced this issue with their sc-63. I have a sc-1227-k which my understanding is the same as a sc-63.
The issue that I've been experiencing is that the sound is cutting out, as well as the picture goes black periodically. The sound too, when it's cutting in and out, the odd time when it goes out for about 10 or 15 seconds, there is an ear piercing squelching sound that comes through the speakers. I've ruled out the problem being the HDMI cables by connecting the same cable directly from the DVR to the TV. (the dvr was supplying the sound through the receiving that is experiencing the sound issues)
There is no error codes produced, but it sounds like a similar issue as the previous post.
It's frustrating that this receiver is only 3 years old and it's crapped out. I'm not sure if there is anything that can be done, other than replacement since repair costs would be to high to justify.
Nemesiss is offline
