TX-SR607 Help! Wii is not displaying image but PS3 is. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 09-11-2012, 08:56 PM - Thread Starter
tyj8tim's Avatar
Hello, I'm lacking a tv so my current setup is as described below.
Game Console (PS3/Wii) -> Receiver (TX-SR607; PS3 hdmi IN; Wii Component IN) -> HDMI out with HDMI-to-DVI converter -> Dell U2412M
The PS3 will show an image while Wii doesn't. And what's even more weird is that the monitor isn't picking up ANY video signals from the receiver, as if Wii isn't outputting any video signals to begin with.
Anyone got any clue what to do?
tyj8tim is offline
post #2 of 17 Old 09-11-2012, 09:56 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
dont you have to turn the video conversion feature on for analog inputs? I'm pretty sure there is a setting for this. Go thru the setup menus.
Afro GT
afrogt is offline
post #3 of 17 Old 09-11-2012, 10:51 PM - Thread Starter
tyj8tim's Avatar
The menu says that composite/component input will be upconverted to 1080i if output by HDMI. I also tried just to "pass through" or 480p into the monitor, no help =(
tyj8tim is offline
post #4 of 17 Old 09-11-2012, 11:05 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi tyj8tim, component inputs must also be assignedi if you haven't done so.
JChin is offline
post #5 of 17 Old 09-11-2012, 11:34 PM - Thread Starter
tyj8tim's Avatar
yep, it's assigned. Anything else? i'm getting desperate lol
tyj8tim is offline
post #6 of 17 Old 09-12-2012, 12:28 AM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Input assign for HDMI select source name set to none
Another option is a Wii2HDMI.
JChin is offline
post #7 of 17 Old 09-12-2012, 12:39 AM - Thread Starter
tyj8tim's Avatar
yep that's done too =) still no dice
tyj8tim is offline
post #8 of 17 Old 09-12-2012, 01:43 AM - Thread Starter
tyj8tim's Avatar
just saw your link for the adapter...do you think it adds latency to the output signal?
tyj8tim is offline
post #9 of 17 Old 09-12-2012, 06:06 AM
splatee's Avatar
Quoted: 30 Post(s)
Just checking, but did you change the Wii video settings to component? We used to have a Wii and when i switched it to component cables i had to switch the video settings to 480p in the Wii menu.
splatee is offline
post #10 of 17 Old 09-12-2012, 09:45 AM
Ross Ridge's Avatar
Liked: 81
Setting the Wii to 480p might help, but there's good chance your computer monitor won't accept the any of the TV format signals that your receiver outputs when converting component to HDMI. Component uses the YCC (YCbCr) colour space, while DVI requires the use of the RGB colour space instead. While HDMI is backwards compatible with DVI and supports RGB, it normally uses YCC. My guess is that your receiver will only convert component to one of the HDMI YCC formats, and not any of the DVI RGB formats. Since your monitor doesn't have an HDMI port, it probably only accepts DVI format signals.
Your PlayStation 3 is backwards compatible with DVI so can just simply send a DVI RGB format signal to your monitor that your receiver don't need to convert or process.
Ross Ridge is offline
post #11 of 17 Old 09-12-2012, 10:33 AM - Thread Starter
tyj8tim's Avatar
my wii has been using component cables for the past 2 years...it wouldn't switch on its own right? i can't see a picture right now...so i can't check T_T
tyj8tim is offline
post #12 of 17 Old 09-12-2012, 11:11 AM
Ross Ridge's Avatar
Liked: 81
The Wii can support either 480i or 480p over component, but 480i is the default. If you just hook up component cables to your Wii you'll get 480i until you change the settings to use 480p.
Note that some games will use 480i regardless of whether you've configured the Wii to use 480p.
post #13 of 17 Old 09-12-2012, 11:20 AM - Thread Starter
tyj8tim's Avatar
ah ic. but that still doesn't explain why i'm not getting an image on my monitor right? the tx-sr607 can upconvert it to 480p, 720p and even 1080i (or just pass through) but none of them gives an image. any thoughts?
edit: just saw your post on the color space. what if I use the original yellow/red/white connectors, does that yellow cable use RGB color?
tyj8tim is offline
post #14 of 17 Old 09-12-2012, 12:16 PM
Ross Ridge's Avatar
Liked: 81
In North America, composite cables actually use a third colour space called YIQ, but assuming you have the cable handy it's worth a try to see if it works.
post #15 of 17 Old 09-17-2012, 12:23 PM - Thread Starter
tyj8tim's Avatar
tried the original cable....still no image T_T
tyj8tim is offline
post #16 of 17 Old 08-17-2013, 12:53 AM
mcaskey's Avatar
Same problem here. Assigned everything and even 'rebooted' the receiver. Getting audio, but no video.
mcaskey is offline
post #17 of 17 Old 08-17-2013, 10:26 AM
Ross Ridge's Avatar
Liked: 81
If you're using a PC monitor as a display instead of normal TV like the original poster then your problem is likely the same as his: your display isn't fully compatible with your AV receiver. Changing settings on your Wii or your receiver won't fix your problem.
Onkyo Tx Sr607 Receiver
