EMOTIVA, UMC-1 - Pops and undesired Noises from the Subwoofer.. - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 44 Old 09-18-2012, 11:28 AM
bootman_head_fi's Avatar
Quoted: 535 Post(s)
Liked: 342
Originally Posted by ccotenj View Post
math?
Additional components mean more potential points of failure....
Are you really hearing a difference?
http://youtu.be/G-lN8vWm3m0
Set an example:
Treat everyone with kindness and respect, even those who are rude to you...
Not because they are nice, but because YOU are. :)
bootman_head_fi is offline
post #32 of 44 Old 09-18-2012, 12:08 PM
rob80b's Avatar
Quoted: 146 Post(s)
Liked: 95
Hi Jeff
Just to address one possible issue with regards to the sub.
“#2. The Subwoofer periodically CLICKS or puts out some static. Basically if I have no music playing the subwoofer makes this pop sound periodically. When I turn the UMC-1 OFF, the pops stop.”
If the auto on is engaged on the Velodyne there is an audio pop when it first senses a signal, also the sub will go to sleep if no signal is detected after a period of silence and produce another audible pop.
Also when I first got my UMC-1 I had a number of issues with noise and distortion until I got the “.19” firmware properly installed (may take a few tries) which is really the biggest hurdle to getting the UMC-1 properly functioning.
My audible thumps appear to be separate problem from which you are experiencing and yours may very well be software related.
Oddly the thumps I’m experiencing sound very similar to when the capacitors discharge after shutting down some amps, just slightly lower, so there may be some incompatible issue between the outputs of the UMC-1 and the Bryston’s input, some sort of voltage drop, unlikely but possible.
rob80b is offline
post #33 of 44 Old 09-18-2012, 01:05 PM
ccotenj's Avatar
Liked: 101
math?
nice try, but no... merely because the amplifiers are in a separate box doesn't make it any more difficult to troubleshoot... if anything, it makes it easier...
- chris
ccotenj is offline
post #34 of 44 Old 09-18-2012, 04:23 PM
MUDCAT45's Avatar
Quoted: 397 Post(s)
Liked: 290
Assume you upgraded to a UMC-1 and XPA5.smile.gif Your sub has never had a problem until the separates. Now it sounds as if the amp is fading. Bass is more of an echo and almost like a hollow sound. No authority in the bass. That description makes it easy doesn't it?smile.gif Sorry that is the best description I have of a bad amp. The other speakers sound as they should.
where do you start trouble shooting?
MUDCAT45 is offline
post #35 of 44 Old 09-18-2012, 05:04 PM
Quoted: 535 Post(s)
Liked: 342
Again, what do you suggest (constructively) the OP should do to help him with his issues?
Because if you have nothing, there are descriptive words for your kind of postings here and they are frowned upon here in AVS.....wink.gif
Come on, I know you can help.
I have seen it on the various Pioneer threads.
Why not elsewhere? (or here!)
Set an example:
post #36 of 44 Old 09-23-2012, 01:09 PM
Quoted: 75 Post(s)
Liked: 113
I'm having a similar problem which I posted on the Emotiva forum:
http://emotivalounge.proboards.com/index.cgi?board=preamps&action=display&thread=26186
I've been setting up HTs forever and can't for the life of me figure out why I'm getting these beeps and static out of the right surround speaker on two different UMC-1 units. In addition to the steps I've tried in the Emotiva thread, I have even tried going back to component and optical hookups and still get the noise. One thing I haven't tried is plugging the UMC-1 and UPA-500 directly into the wall so will give that a try. Any other ideas would be appreciated. Thanks
rnatalli is offline
post #37 of 44 Old 09-23-2012, 05:24 PM
MUDCAT45's Avatar
Quoted: 397 Post(s)
Liked: 290
I haven't read the Emo thread. Does the noise stay with the same amp channel if you put different speakers on it or run another channel from the UMC to that amp channel? My bet is that you have a defective amp channel. I experienced the same problem as you and it was the amp.
Best of luck in tracing the problem.
MUDCAT45 is offline
post #38 of 44 Old 09-23-2012, 06:51 PM
Quoted: 75 Post(s)
Liked: 113
Definitely not an amp problem. I reversed the interconnects and the noise follows into different speakers on different amp channels.
rnatalli is offline
post #39 of 44 Old 09-24-2012, 06:28 AM
Quoted: 535 Post(s)
Liked: 342
I would RMA the unit. Sounds like the UMC has an issue.
Set an example:
post #40 of 44 Old 09-24-2012, 11:18 AM
Quoted: 75 Post(s)
Liked: 113
I'm not convinced the unit is defective as it's the second one I received from Emotiva with the exact same problem which is pretty specific. I also remember having a similar problem with HK receivers I thought were defective because the receivers were humming themselves. The same problem on two receivers just seemed too unlikely unless there was a bad batch coming off the line. Sure enough, I fixed that problem by having the FM antenna feed through an isolator first before connecting it to a receiver. I'm convinced there's something similar with the Emotiva going on. Last night I plugged the UMC-1 and UPA-500 direct to the wall into different outlets and did not hear the problem once in 3+ hours of usage. My power conditioner is a bit old so perhaps it's introducing something. I'm going to see how tonight goes.
rnatalli is offline
post #41 of 44 Old 09-25-2012, 01:16 PM
Quoted: 75 Post(s)
Liked: 113
I was able to find some threads on Digital Clipping in the Emotiva forums and may have found the problem. From what I understand, significant boosts to EQ bands can result in digital clipping when DV engages as DV itself boosts frequencies. Last night, I was getting the noise after a couple hours of use and then lowered all the EQ bands and the noise appears to have gone away. I will see tonight if it holds. If so, I believe simply lowering every EQ band of every speaker so that no frequency exceeds 0 will do the trick and maintain the EQ curves.
rnatalli is offline
post #42 of 44 Old 09-25-2012, 07:41 PM
Quoted: 75 Post(s)
Liked: 113
Chirping is still there. I did several full resets and did not run auto EmoQ this time and so far so good. Someone had suggested that auto EmoQ sets an offset somewhere which can result in digital clipping if the master volume wasn't set properly during setup. In any case, I know receivers with Dolby Volume will disable EQ when used so having to choose isn't new to me.
rnatalli is offline
post #43 of 44 Old 09-29-2012, 03:06 AM
hoppaz's Avatar
I had popping rear speakers which was resolved by bringing the trim levels down as close to zero as possible. You are not alone with this problem.
LCR Behringher Truth B3031A
Surr LR Behringher Truth B2030A
LFE FV15HP
hoppaz is offline
post #44 of 44 Old 10-01-2012, 06:58 AM
Quoted: 75 Post(s)
Liked: 113
I think I have mostly solved the issue and part of the solution was to lower the trim levels. I posted what I did on the Emotiva forum. I think the biggest change was to reset the unit several times and clear whatever DV offset Auto EmoQ was setting. Once that was done, I setup EmoQ manually with the settings I wrote down.
rnatalli is offline
