New Denon 4311Ci Problems. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-16-2012, 05:50 PM - Thread Starter
a aa's Avatar
Hi all,
First time poster here, though I've been lurking for several years.
A couple of days ago I received the Denon 4311CI I ordered from one of the dealers mentioned in the Great Deals Found thread, (see: http://www.avsforum.com/t/1388717/denon-4311ci-ee-for-1329-99) and am having some problems with it.
First, I noticed that when playing cable programs from my Time Warner supplied Scientific Atlanta 8300HD DVR, there are a lot of dropouts and freezes on both live and recorded programs. It is not the cable as I've swapped the HDMI cable and the problem still persists.
The second problem is that the the on screen menu no longer displays on the TV when using the remote control. I can access the menu and it will display on screen ONLY if I use the button on the front panel, behind the flip down door, but not from the remote. It was working from the remote one minute then it just disappeared! The volume bar still shows,when changing volume but nothing else.
Alsoo, while I am at it,does the setup button - shift+search - do anything? It does not operate any functions on my unit.
I've read through the various 4311 threads and am aware of disappearing GUIs and HDMI connection problems but thought that these problems were fixed some time ago? I am now starting to think I have a dud unit.
I'd be very grateful for any help that fellow Denon 4311 owners can provide.
a aa is offline
post #2 of 7 Old 09-16-2012, 06:12 PM
cwglideman's Avatar
Quoted: 53 Post(s)
Liked: 55
Hi,
you're likely to find more help by posting your issue in the 4311 owners thread, that's where all the experts hang out.
cwglideman is online now
post #3 of 7 Old 09-16-2012, 07:31 PM - Thread Starter
a aa's Avatar
Thanks for the reply. I'll copy and paste over there.
a aa is offline
post #4 of 7 Old 09-16-2012, 07:35 PM - Thread Starter
a aa's Avatar
Did you mean 'The "Official" Denon AVR-4311CI/AVR-A100 thread'?
I couldn't find an official 4311 owners thread.
a aa is offline
post #5 of 7 Old 09-17-2012, 06:35 AM
KidHorn's Avatar
Quoted: 1460 Post(s)
Liked: 961
Did you try running the HDMI straight from the cable box to the TV and see if you still have freeze issues?
KidHorn is offline
post #6 of 7 Old 09-17-2012, 06:54 AM - Thread Starter
a aa's Avatar
Hi KidHorn,
Yes, until I took delivery of the 4311, I was using a 2 Ch stereo system with the cable box HDMI fed straight to my Panasonic Plasma, and the analogue L&R audio outputs on the cable box going to the amps Aux inputs. No dropouts at all. Good Sound.
a aa is offline
post #7 of 7 Old 09-17-2012, 08:16 AM
80sGuy's Avatar
Quoted: 191 Post(s)
Liked: 36
Sometimes cable boxes do have their own problems too. I've had my share with both cable boxes and modems and the problems usually go away after replacements. You might wanna swap out another box from cable company and see if it fixes the problem.
80sGuy is offline
