Onkyo AVR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-18-2012, 09:23 AM - Thread Starter
gopala33's Avatar
Quoted: 137 Post(s)
Onkyo TX-NR818 VS Onkyo TX-NR1010
why Onkyo TX-NR1010 very bad ????
both what different
gopala33 is offline
post #2 of 8 Old 09-19-2012, 07:52 AM - Thread Starter
gopala33's Avatar
Quoted: 137 Post(s)
please reply i am waiting
thanks
gopala33 is offline
post #3 of 8 Old 09-19-2012, 11:47 AM
cybrsage's Avatar
Liked: 154
Here is a comparison of the two, at Onkyo's site. Note that they also have sites in many other languages in case you would be more comfortable with one. Just go to www.onkyo.com and select a location, then go to the Receivers and select the items to compare.
cybrsage is offline
post #4 of 8 Old 09-19-2012, 12:19 PM
runnin''s Avatar
Liked: 45
Does the 1010 have a better version of Audyssey XT32? With the 818 version, apparently some functionality is not there, like eqing two subs.
runnin' is offline
post #5 of 8 Old 09-19-2012, 12:52 PM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
The 1010 supports dual sub-eq while the 818 does not. This is technically not part of XT 32, but as far as I know, every receiver outside of the 818 that has XT 32 also has dual sub eq.
KidHorn is offline
post #6 of 8 Old 09-23-2012, 10:06 AM - Thread Starter
gopala33's Avatar
Quoted: 137 Post(s)
so 1010 also has XT 32 also has dual sub eq. ????
gopala33 is offline
post #7 of 8 Old 09-23-2012, 10:23 AM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 488
Yes.
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is offline
post #8 of 8 Old 09-23-2012, 10:43 AM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
More appropriately, the 1010 features both XT32 + Sub EQ HT (dual sub integration) while the 818 only features XT32. Dual subs can be used in either case, although with the 818, the dual subs would have to be manually level and delay set rather than being done automatically by the Sub EQ HT in the 1010.
https://audyssey.zendesk.com/entries/20953442-subeq-ht-vs-multeq-xt32
jdsmoothie is offline
