The **OFFICIAL** DENON AVR-4520CI thread - Page 121 - AVS Forum | Home Theater Discussions And Reviews
 879Likes
post #3601 of 13736 Old 03-18-2013, 06:49 AM
bird man's Avatar
Originally Posted by AustinJerry View Post
Really, you are complaining that the tone controls don't work on the surround channels and you haven't even run Audyssey yet?  confused.gif
LOL, yes I know.
It was just that the 5308ci had the ability to control the tone of all the speakers at the same time (equalizer excluded)and the 4520 did not have this feature.
So I thought there was something wrong.
Having said that, the 4520 is a great receiver!!!
bird man is offline
post #3602 of 13736 Old 03-18-2013, 07:06 AM
SoundofMind's Avatar
Liked: 166
^IME "attack" is usually used in reference to the the attack transients-a part of the overall dynamics and basically the initial upward slope of SPL. Other comon descriptors for this are be "punchy" or "fast". I myself have never experienced a sound system that was "too aggressive" in this quality. Quite the opposite- it is rare to hear a system capable of approaching the actual dynamics of live music.
Yes, I still like playing with Dalis.
SoundofMind is offline
post #3603 of 13736 Old 03-18-2013, 07:29 AM
EVT
EVT's Avatar
Quoted: 46 Post(s)
Liked: 25
Originally Posted by howard68 View Post
The 7.1 dts thing needs to be fixed !
You can turn on dolby or dolby ex in settings
With the sound toggle button
Why not with Dts to Dts es ,
Choose 5.1 or 7.1
Not default to Dts 7.1
I don't get why you consider this an issue. If you have a 7.1 setup I assume you want to utilize your 7.1 setup correct? When you go to a movie theater and they playback a native 5.1 track they still utilize the back surround speakers. Personally, I apply PLIIx to DTS-MA sources and I've only had to apply this the very first time I played back a DTS-MA 5.1 track - since then it defaults to PLIIx.
EVT is offline
post #3604 of 13736 Old 03-18-2013, 09:00 AM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
(as pointed out by batpig) from page 99 of the AVR-3312CI owner's manual BOLD MINE :
Setting items Setting details
Surround Back
Sets the method of
generating of the surround
back channel.
nn For 2-channel sources
ON : The surround back channel is used.
OFF : No signal is played from the surround back channels.
nn For multi-channel sources
Set the decoding method for the surround back channel.
ONz1 : Convert the 5.1-channel source of the DTS/DTS-HD input
signals to the 7.1-channel output recommended by DTS and then play.
MTRX ON : Generate and play the surround back channel signals from
the surround channel signals by means of the Dolby Digital EX decoder.
ES MTRXz2 : Generate and play the surround back channel signals
from the surround channel signals of the DTS source by means of the
DTS-ES decoder.
PLgx CINEMAz3 : Generate and play the surround back signals by
decoding the signals in the Dolby Pro Logic gx Cinema mode.
PLgx MUSIC : Generate and play the surround back signals by
decoding the signals in the Dolby Pro Logic gx Music mode.
OFF : Do not play the surround back channel.
z1 This can be selected when playing the 5.1-channel source of DTS/
DTS-HD.
z2 This can be selected when playing DTS sources.
z3 This can be selected when “Speaker Config.” – “Surr.Back”
(vpage 106) is set to “2spkrs”.
If the source being played contains a surround back signal, the decoder
type is automatically selected by the AFDM function. Set “AFDM” to
“OFF” to switch to your preferred decoder.
NOTE
If the setting in “Speaker Config.” – “Surr.Back” (vpage 106) is
“None”, “Surround Back” is not displayed.
just 1 more pair of KLIPSCH Classic speakers...
RED AND BLUE=MAROON!
PANASONIC 60" PLASMA 3D, DENON AVR-3312CI, LG BD670 3D NETWORK BRD (iPhone APPs), TOSHIBA HD-XA2 HD DVD, SAMSUNG BD-UP5000 HD DVD/BRD, iPod 8 GB, 13.2: KLIPSCH La Scala 1980 (Crites Rebuilt Type AA Crossovers Sonicaps) FRONT, HERESY II "SIGNATURE EDITION" WIDE, HERESY II CENTER/SURROUND, kg2 SB, kg3/kg1 Front/Rear HEIGHT, RW-12d SW, km-rsw
SanchoPanza is offline
post #3605 of 13736 Old 03-18-2013, 09:42 AM
BRAISKI's Avatar
Quoted: 20 Post(s)
Denon 2809CI
C: Def Tech - CLR2002
F: Def Tech - BP2002TL
S: Def Tech - BP1.2X
SB: Def Tech - PM400
Sub: Plan to get the SVS-SB1000
BRAISKI is offline
post #3606 of 13736 Old 03-18-2013, 10:26 AM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
Originally Posted by BRAISKI View Post
I think normally the prices drop when the replacement model is released. Call a Authorized seller from the forums and ask for their best deal... You might be surprised by their price.
ellisr63 is offline
post #3607 of 13736 Old 03-18-2013, 10:32 AM
Dave T's Avatar
I'm having a very strange issue that I'm hoping you guys can help me with.
I have a digital source that I want to play in Zone 2. I was able to do this for a while, but then it stopped working. The installer who sold me the unit is telling me that Zone 2 can only play analog sources, and that I need an external D/A converter if I want this source to play in Zone 2. I am absolutely sure I had this working at one point, but he says that it never could have worked. There is a section in the user's manual that says that Zone 2 can only play analog sources, which he's referring to, but it appears to me that that is talking about routing digital sources out through the analog pre-out outputs to a seperate Zone 2 amplifier.
In any case, isn't there also a way to tell Zone 2 to play "whatever is playing in Zone 1", thus using the Zone 1 D/A converter? Perhaps this is how I had it working before... All I know is that I had my digital source playing in Zone 2, and I was also able to independently control the volume in Zone 2.
- Dave
Dave T is offline
post #3608 of 13736 Old 03-18-2013, 10:34 AM - Thread Starter
batpig's Avatar
Quoted: 3706 Post(s)
Liked: 3576
The only way to play a digital source to Zone2 is using the "All Zone Stereo" function, which syncs all zones to the source audio source.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #3609 of 13736 Old 03-18-2013, 11:18 AM
Dave T's Avatar
That was it, thanks!
Actually, though - according to Denon, you should be able to get 2 zone PCM digital audio to play independently in Zone 2. And that is what the source is that I'm trying to get to play. It was working at one point and now is not. I can live with the "all zone stereo" mode anyway, because my Zone 2 speakers are on the other side of the same room as zone 1 (so I don't need zone 2 to play a seperate source). But I should be able to play a seperate PCM source in Zone 2 from whatever is playing in Zone 1, and that isn't working.
Dave T is offline
post #3610 of 13736 Old 03-18-2013, 11:45 AM - Thread Starter
batpig's Avatar
Liked: 3576
I'm not sure who "according to Denon" is (e.g. a customer service rep on the phone support?) but it's not true. That feature (2.0 PCM from optical or coax) existed on the previous 4311 model but was removed with the 4520.
Setup Guide and FAQ
batpig is offline
post #3611 of 13736 Old 03-18-2013, 11:48 AM
Dave T's Avatar
It was a guy that my installer got on the phone when he was here. I assume it was a customer service rep, as you say.
I guess that I'll live with using "all zone stereo". I'm as sure as I can be that at one point I had PCM playing in Zone 2 by selecting the PCM input as my source in Zone 2, but maybe I'm crazy.
Thanks for your help!
- Dave
Dave T is offline
post #3612 of 13736 Old 03-18-2013, 05:36 PM
United2013's Avatar
Does anyone know what to do to get my phone to control the AVR. I downloaded the App just need some help setting it up.
United2013 is offline
post #3613 of 13736 Old 03-18-2013, 05:42 PM
Quoted: 197 Post(s)
Liked: 511
what kind of phone? I can help with iPhone
post #3614 of 13736 Old 03-18-2013, 05:53 PM
jdsmoothie's Avatar
Quoted: 15054 Post(s)
Liked: 7263
Choose 5.1 or 7.1
This change was more than likely the result of the fact that in years past, many owners were confused about how to simulate 7.1 from DTS 5.1 audio due to the special surround parameter settings and therefore Denon has apparently just made it the permanent default (ie. nothing to be fixed).
As already asked of you, perhaps you can share why you prefer 5.1 with a 7.1 setup?
jdsmoothie is offline
post #3615 of 13736 Old 03-18-2013, 06:17 PM
Jerry Incollingo's Avatar
4520 has to be hooked up to your home network, iPhone needs to be on your same network wirelessly. Run the App and it should automatically find the 4520, that simple. You should be using the official free Denon app in the Apple store,
Jerry
Jerry Incollingo is offline
post #3616 of 13736 Old 03-18-2013, 07:17 PM
United2013's Avatar
Thank you. my modem is not wireless so does that mean i can not do it?
post #3617 of 13736 Old 03-18-2013, 07:18 PM
United2013's Avatar
Yes a iPhone 4
post #3618 of 13736 Old 03-18-2013, 07:20 PM
Quoted: 197 Post(s)
Liked: 511
you'll have to connect your AVR with wired connection, mine is wired...but, your phone will need to connect wirelessly...
post #3619 of 13736 Old 03-18-2013, 07:34 PM
howard68's Avatar
Quoted: 152 Post(s)
The dts 7.1 thing
You can set dolby digital to 5.1 or ex or pl2 cinema back
Why not the same in DTS !
howard68 is offline
post #3620 of 13736 Old 03-18-2013, 07:35 PM
United2013's Avatar
cheers. So does the denon connect to my phone wireless or does my phone need to connect to my modem?
post #3621 of 13736 Old 03-18-2013, 07:40 PM
Quoted: 197 Post(s)
Liked: 511
the Denon when wired to your network, can connect to your iPhone 4 wirelessly, but, I think you'll have to have some type wireless modem for the iPhone 4 to connect to...
post #3622 of 13736 Old 03-18-2013, 07:47 PM
United2013's Avatar
That what i was thinking. I might buy wireless modem soon then i can do it. Thanks for your help
post #3623 of 13736 Old 03-19-2013, 05:57 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7568 Post(s)
Liked: 4224
The dts 7.1 thing
Your insistence would be more credible if you would explain why being able to turn off the rear surrounds is so important to you.  Otherwise, it just sounds like nitpicking.
AustinJerry is online now
post #3624 of 13736 Old 03-19-2013, 06:19 AM
Quoted: 197 Post(s)
Liked: 511
The dts 7.1 thing
again, as RECOMMENDED by dts...let's see, my choice, or recommended by dts?
also, Dolby Digital Plus 6.1 AND TrueHD 6.1 automatically adds the 7th channel...
post #3625 of 13736 Old 03-19-2013, 08:00 AM
howard68's Avatar
Quoted: 152 Post(s)
You miss the point why not
You can do it in dolby
I just miss the option
You can choose 5.1 in dolby or 7.1
This amp sounds very good
I am very sad that denon have taken away so many options that was in other units
howard68 is offline
post #3626 of 13736 Old 03-19-2013, 08:23 AM
Quoted: 197 Post(s)
Liked: 511
you can select surround back off and toggle it to every choice with the MOVIE button...
post #3627 of 13736 Old 03-19-2013, 08:40 AM
SergeantYnot's Avatar
Liked: 31
Quick question, is the included power cord the standard 6 feet in length?
SergeantYnot is offline
post #3628 of 13736 Old 03-19-2013, 08:46 AM
howard68's Avatar
Quoted: 152 Post(s)
When I am in a dts film sound track
I can not turn the back off to play it back in 5.1
It defaults to 7.1 and you have to change speaker settings
If I have a dolby sound I can change things
With the movie button
howard68 is offline
post #3629 of 13736 Old 03-19-2013, 08:48 AM - Thread Starter
batpig's Avatar
Liked: 3576
That's the only way you would want it to be, and it's the way ANY 7ch receiver will work.
Think about it -- if you have TWO back surrounds, why would you only want ONE of them making noise? Which would it be, the left one or the right one? Either one would be "wrong" because the (theoretically) central back surround signal would be off to the left or right.
What happens with a 6.1 track is that the mono back surround channel is played in dual-mono by the two back surrounds. This is how many 6.1 systems were intended to be used way back in the day, because of a localization artifact where a speaker directly behind your head can trick your ears/brain into thinking a sound directly behind you is actually in front of you.
Even before full 7.1 with stereo back surrounds was an option, many experts recommended using TWO back surrounds for 6.1 systems specifically to avoid this artifact.
Many modern receivers will allow you to override the 6.1 signal and use something like PLIIx to instead extract stereo back surrounds rather than the mono back surround. But either way you WANT it playing from both speakers.
Setup Guide and FAQ
batpig is offline
post #3630 of 13736 Old 03-19-2013, 09:05 AM
howard68's Avatar
Quoted: 152 Post(s)
I do not see why people don't see my point
I love dts es and 7.1 ect and all things surround
I just would like to have the choice to hear it as it was mixed
You can set dolby to 5.1 or 7.1 with ease on this amp
Not with DTS
howard68 is offline
Denon Avr 4520ci Receiver
