The **OFFICIAL** DENON AVR-4520CI thread - Page 136 - AVS Forum | Home Theater Discussions And Reviews
 864Likes
post #4051 of 13607 Old 04-11-2013, 01:15 PM
Selden Ball's Avatar
Quoted: 3216 Post(s)
Liked: 1579
The zone 2 & 3 circuits generate additional heat when they are enabled. Check to make sure they're off if you don't need them.
Unfortunately, the video circuits generate a significant amount of heat even when they aren't in use.
Selden
Selden Ball is offline
post #4052 of 13607 Old 04-11-2013, 01:26 PM
evo5's Avatar
Quoted: 12 Post(s)
Hi, sorry if it was asked before.
I am a happy owner of an 4311 receiver...using it in 11.2 configuration...it is worth to change for the 4520? I was thinking because it have Neo X .
Thank you for your comments
evo5 is online now
post #4053 of 13607 Old 04-11-2013, 01:26 PM
DougReim's Avatar
Liked: 24
Audyssey settings.............
I've been farting around with different settings trying to get my Denon 4520 to sound good in the 2 channel stereo mode. It's just never sounded quite right to me for music (I almost always listen to music in 2 channel stereo). What I found is that Audyssey cranks up the treble while cutting the bass. Trying to compare Audyssey with the avr's tone adjustments I had to set the treble up to 5 or 6 (6 is the maximum on this receiver) to match what Audyssey has done. When you couple the heavy treble with the negative bass it sounds harsh and brittle especially at loud volume and with busy music. I just got my 3311 back from the shop and if it wasn't such a pita I'd like to hook that back up to compare the 2. I had the 3311 sounding really good with music before the transistors went away. Does this Audyssey treble boost suggest anything in my environment or in my other gear to anybody? Maybe there's something I can change, I don't know????? I've already upped my subs by 5 db's and that helps with the LF but obviously doesn't help with the boosted treble.
BTW, I'm not sure if this question belongs in the Audyssey or Denon threads so I'm posting in both.
Thanks for any suggestions.
Doug
TV Room Upgrade Completed
DougReim is offline
post #4054 of 13607 Old 04-11-2013, 01:41 PM
DougReim's Avatar
Liked: 24
Another question:
I found a deal for a $10 bluetooth receiver
http://news.cnet.com/8301-13845_3-57579056-58/get-an-xtrememac-bluetooth-audio-receiver-for-$9.99/?tag=nl.e796&s_cid=e796&ttag=e796
but it requires a 3.5mm audio in. Anyway to make this work on the 4520?
Doug
DougReim is offline
post #4055 of 13607 Old 04-11-2013, 01:58 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6968 Post(s)
Liked: 3886
For those of you claiming that the 4520 is running "hot", this is a subjective term. Can you please measure the temperature and post it here? Without facts and data, the discussion has no value.
For example, I just used a infrared thermometer and took several readings on my 4520, both at the power amps and at the video processing section. The highest temperature I recorded was 115 degrees F. I have three inches of clearance above the unit, and the equipment rack is completely open on the sides and rear, so airflow is excellent. Is this hot?
AustinJerry is online now
post #4056 of 13607 Old 04-11-2013, 02:10 PM
DougReim's Avatar
Liked: 24
I tried putting a fever strip on my box last week but it didn't work.
Doug
DougReim is offline
post #4057 of 13607 Old 04-11-2013, 02:11 PM
mogorf's Avatar
Quoted: 1096 Post(s)
Liked: 664
Under what conditions did you measure the temperatue Jerry? MV setting? Program material? Music or film? If music, what music, Vivaldi Four Seasons or Metallica? How long was the AVR turned on before you made the temperature measurement? So many parameters to be defined in order to make a conclusion. smile.gif
mogorf is online now
post #4058 of 13607 Old 04-11-2013, 02:36 PM
Liked: 3886
I have been watching HD video material for several hours at MV=15 with full 11.1 DSX enabled. Does that really make that much difference? I have measured the AVR temp a number of times, both when it has been idle, and when it has been driven hard, and have seen very little differences in temperature. At no time did I feel the temperature was "hot", although I don't have a lot of input from other posters with which to compare. BTW, I use an external amp for the LCR speakers. Back to you.
post #4059 of 13607 Old 04-11-2013, 02:44 PM
mogorf's Avatar
Liked: 664
Quite a broad question for a conclusive ending, eh? Now you introduced another "variable" by adding that you use an external amp for LCRs! How's the external amp doing in the "bakery"? LOL
P.s.: I suppose you wanted to say: MV=-15 dB. tongue.gif
post #4060 of 13607 Old 04-11-2013, 03:13 PM
Liked: 3886
-15dB, of course, thanks.  I want to preserve both my hearing, and my speakers. eek.gif  And the external amp (Emotiva XPA-3) is running cool to the touch, not much hotter than body temp.
Edit:  I guess my point is that it would be nice if posters would include actual temperatures when they make claims that the unit is running hot.  No need to get Feri-esque (like this term?) and require all sorts of data about how long it has been running, what is playing, the external ambient temperature and humidity, and the lunar phase...
post #4061 of 13607 Old 04-11-2013, 03:17 PM
mogorf's Avatar
Liked: 664
post #4062 of 13607 Old 04-11-2013, 03:20 PM
nsaldanh's Avatar
Originally Posted by nezff View Post
Quick question guys. I have the marantz 8801 now. I've heard the denon and the marantz now. I honestly can't hear a $600 or difference.
Is there a reason why a unit made by tge same company cost this much more? Is the marantz a better built unit? Do the denons have more problems etc...?
No the Marantz just has a more expensive marketing team that has to cover their costs. biggrin.gif
nsaldanh is offline
post #4063 of 13607 Old 04-11-2013, 04:05 PM
petetherock's Avatar
Quoted: 1116 Post(s)
Liked: 538
Again, it's more than $600 difference in cost between the 4520 and the 8801.
$600 for the unit and another 1-2k more for amps minimum, so make that more than 3k difference in price. You can't use the 8801 without spending on amps.
petetherock is online now
post #4064 of 13607 Old 04-11-2013, 04:32 PM
nezff's Avatar
Quoted: 147 Post(s)
Liked: 67
$430 where I got mine difference. Also amps dont cost 1-2k minimum. I bought my xpa-5 for $799 shipped.
Most people running either unit is running a external amp and using the denon as a preamp. I understand your argument, but again, most users here arent using the internal amps. Then again, some are.
If you are like me, the cost difference is only in the actual units because you bought a external amp already.
nezff is offline
post #4065 of 13607 Old 04-11-2013, 06:51 PM
ceh383's Avatar
Quoted: 421 Post(s)
Liked: 2595
I'm running the internal amps....
A 5.1 system with an SVS sub, given the 92db sensitivity of my speakers....any more volume...my wife would leave me and the neighbors would complain...
Yamaha RX-A2020 | Outlaw M-2200 (x5) | Oppo BDP-103 | Sony CDP-CE500 | Dish VIP622
Definitive Technology BP-8060ST : CS-8060HD : PM-1000 | SVS PC12 Plus | PSA S1500
Sharp LC-70C6400U | miniDSP DDRC-88BM | Belkin PureAV (x2)
ceh383 is offline
post #4066 of 13607 Old 04-11-2013, 07:02 PM
nezff's Avatar
Quoted: 147 Post(s)
Liked: 67
I'm going to order the 4520 and compare it to my 8801. I'll keep the one I like and then probably list the the other for sale on here.
nezff is offline
post #4067 of 13607 Old 04-11-2013, 07:52 PM
audio1246's Avatar
btw compared to the Onkyo 5508 + Emotiva XPA-5, the Denon 4520 sounds more musical (IMHO). And yes I am not missing the amp so far.
audio1246 is offline
post #4068 of 13607 Old 04-12-2013, 03:14 AM
evo5's Avatar
Quoted: 12 Post(s)
Nobody?
evo5 is online now
post #4069 of 13607 Old 04-12-2013, 04:42 AM
Liked: 538
Nobody?
If that's your only reason, I am not sure.
But I wrote about a review of the 4520, and I owned the 4311. I run a 11.2 system. See my signature for my blog, cheers.
evo5 likes this.
post #4070 of 13607 Old 04-12-2013, 05:54 AM
cybrsage's Avatar
Liked: 154
For just that it is a waste of money. I prefer NEO:X over DTS, but it is not worth a thousand dollars to get it.
cybrsage is offline
post #4071 of 13607 Old 04-12-2013, 08:02 AM
SergeantYnot's Avatar
Liked: 31
^ I agree. The 4520 also has DSX for 11.2 (I believe the 4311 does too?). I still prefer DTS:NEO X though over Audyssey's implementation. It sounds more fluid.
SergeantYnot is offline
post #4072 of 13607 Old 04-12-2013, 08:15 AM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
Nobody?
11.2 output from all outputs at one time?
just 1 more pair of KLIPSCH Classic speakers...
RED AND BLUE=MAROON!
PANASONIC 60" PLASMA 3D, DENON AVR-3312CI, LG BD670 3D NETWORK BRD (iPhone APPs), TOSHIBA HD-XA2 HD DVD, SAMSUNG BD-UP5000 HD DVD/BRD, iPod 8 GB, 13.2: KLIPSCH La Scala 1980 (Crites Rebuilt Type AA Crossovers Sonicaps) FRONT, HERESY II "SIGNATURE EDITION" WIDE, HERESY II CENTER/SURROUND, kg2 SB, kg3/kg1 Front/Rear HEIGHT, RW-12d SW, km-rsw
SanchoPanza is offline
post #4073 of 13607 Old 04-12-2013, 08:16 AM
Liked: 31
Just to clarify, the actual street price difference between both units is way more than $600 and closer to $1,000 actually. Nezf is just quoting $500-600 since he used some special credit card rewards points to get that lower price. You would have to go to an AD that only marked down the 8801 and didn't mark down the 4520 at all to get anywhere close to a $600 price difference. A4L typically has the best AD prices to be found online (outside of eBay), and I would be shocked to see the 8801 sell for $2300 ever ($600 more than current 4520 pricing), especially given its current pricing is $2900.
I would particularly like to see a pro review with the 4520 set in preamp only mode, vs the 8801 using the same external amps. In terms of feature set, it would be a tie, but overall I would venture a guess that the 4520 would be chosen as the best buy on price difference alone.
post #4074 of 13607 Old 04-12-2013, 08:17 AM
Quoted: 197 Post(s)
Liked: 511
Nevermimd
post #4075 of 13607 Old 04-12-2013, 04:25 PM
scuba-junky's Avatar
I've had my 4520Ci for about 2 months now and have had problems with it forgetting the password to my Pandora account. I did a quick search and didn't come up with anyone else reporting this problem. I'm not sure what to do......
It doesn't do it every time but 1 in every 3 or 4 attempts to log in to my Pandora account, the password will be blank and it requires me to enter it in again. Very long and tedious process. Has anyone else experienced this?
scuba-junky is offline
post #4076 of 13607 Old 04-12-2013, 07:46 PM
nezff's Avatar
Quoted: 147 Post(s)
Liked: 67
Name is nezff.
How in the world could you possibly know what price I paid and know how I got it? I don't know why you intend on quoting street price when it's totally wrong. I used no special card or magic getting either unit. The actual price I paid compared to both units was exactly $381 the first time. This time I'm actually getting the denon even cheaper so now it will be $431. I have no idea why someone in their right mind would pay full sticker price for any unit. That's just idiotic and absurd. As for the text in bold, you sir would be shocked I guess.
If anyone wants to know what authorized dealer I bought both units from, feel free to pm.
nezff is offline
post #4077 of 13607 Old 04-12-2013, 09:14 PM
ceh383's Avatar
Quoted: 421 Post(s)
Liked: 2595
I've had my 4520 for a few weeks and have had no issues at all with Pandora, entered the UID and Password once....Done....
ceh383 is offline
post #4078 of 13607 Old 04-13-2013, 04:07 AM
Jerry Incollingo's Avatar
Are you running the latest firmware on the 4520? I have had no issues on my 4520 but have seen this behavior on my 2112 after not using Pandora for a while.
Jerry
Jerry Incollingo is offline
post #4079 of 13607 Old 04-13-2013, 07:11 PM
overtkill's Avatar
I just purchased two new AVR-4520 receivers from OneCall, and one out of the two has a dead Left Surround. The other one seems to be fine, ran firmware updates on both, and did a Full Reset on the defective Left Surround one, but it did not fix it.
overtkill is offline
post #4080 of 13607 Old 04-13-2013, 07:13 PM
sourbeef's Avatar
Liked: 25
Originally Posted by phalen302 View Post
Don't know why my Denon 4520 is running like Onkyo; what I mean is running hot eek.gif It is driving my B&W CM 9 HT (5.1). Any body had similar issues or noticed it?
My Marantz AV 7701 and MM7055 were running warm when they connected to the system and Pio elite SC 65 didn't even got warm when they were connected cool.gif
thanks
Nope, just the opposite. The Denon 4520 is noticeably cooler than my previous Onkyo 705. My system is a 5.1 too. By the way, I have less than an inch clearance above my unit to the glass shelf above. smile.gif
TV - Panasonic 58PZ700U plasma
L/R - Ascend Sierra Towers with RAAL Tweets in piano black
C - Ascend Sierra Horizon with RAAL Tweet in piano black
Surr - Polk Fxi-A6
Sub - SVS PC-13 Ultra
AVR - Denon 4520-CI
Blu-ray - OPPO 103
Comcast Set Top Box
sourbeef is offline
Denon Avr 4520ci Receiver
