The **OFFICIAL** DENON AVR-4520CI thread - Page 142 - AVS Forum | Home Theater Discussions And Reviews
 863Likes
post #4231 of 13580 Old 04-29-2013, 11:11 AM
kertofer's Avatar
OK, that is awesome! Thanks batpig!
kertofer is offline
post #4232 of 13580 Old 04-29-2013, 12:27 PM
onelesd's Avatar
Originally Posted by flyingvfreak View Post
Anyone use the fans from cooler guys. Do I use a usb powered fan and blow air into it or suck the heat out..or both like a PC set up?
I use 2 of the cooler guys USB fans on top of my 4520 blowing out the back - the fans are plugged into my HTPC because the 4520 USB port didn't power them for some reason, though I didn't try to figure that out. The 4520 barely gets warm and I can't hear the fans at all when I'm 10 feet away.
Fan: http://www.amazon.com/gp/product/B005AKCNBY/
onelesd is offline
post #4233 of 13580 Old 04-29-2013, 12:58 PM
Gary Hudson's Avatar
There is a setting for which USB is active. If you set it for the back then the fans can be powered by the unit.
onelesd likes this.
Gary Hudson is offline
post #4234 of 13580 Old 04-29-2013, 01:45 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3037 Post(s)
Liked: 2969
Very handy way to cool an AVR. I'm looking forward to replacing my trusty 4310 with a 4520 soon ! smile.gif
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #4235 of 13580 Old 04-29-2013, 11:30 PM
onelesd's Avatar
That did it, thanks!
For anyone else looking for the setting, select iPod/USB as the source, then press "option" on your remote. The fans stay powered even when another source is selected.
onelesd is offline
post #4236 of 13580 Old 04-30-2013, 04:54 AM
jjmcmast's Avatar
I'd like some observations from other users. The lights on the front panel for Wide, Subwoofer and Height speaker don't come on at all even though sound is coming out of all of these speakers ( as well as all the others), regardless of which sound mode that I use. I think that they used to light up, up until a few weeks ago.
The chap from the Denon distributor first suggested that it was the sound mode that should be looked at, then he suggested turning Audyssey DSX off then on, now he says that as long as the sound is coming out, there isn't a problem.
Would anybody who has these lights showing please let me know what surround mode and inputs turn them on and which turn them off?
jjmcmast is offline
post #4237 of 13580 Old 04-30-2013, 06:30 AM
audio1246's Avatar
You may have the front display set to show input channel indicators. Change it to show "output" channel indicators and then you should see what all channels get used.
Refer to page 153 in the manual.
Hope this helps.
audio1246 is offline
post #4238 of 13580 Old 04-30-2013, 04:33 PM
jjmcmast's Avatar
Audio1246
Thanks heaps for that. You pointed me straight to the solution.
It seems interesting to me, that while it was on input setting, regardless of the disc being played, the subwoofer light was never on.
Is the '.1' not really a discrete channel on the discs as I believed?
jjmcmast is offline
post #4239 of 13580 Old 04-30-2013, 08:37 PM
audio1246's Avatar
post #4240 of 13580 Old 04-30-2013, 09:13 PM
ceh383's Avatar
Quoted: 418 Post(s)
Liked: 2575
I need an opinion,
I received my replacement 4520 today, it has a 208XXX... serial number, the one that failed on me was 212XXX.... From what I have read, this is from an early production run when these units were having most of the problems they've encountered.
I'm wondering if it's worth the investment in time to set this up, it will take several hours to get it all done, or should I send it back and say no thanks?
Yamaha RX-A2020 | Outlaw M-2200 (x5) | Oppo BDP-103 | Sony CDP-CE500 | Dish VIP622
Definitive Technology BP-8060ST : CS-8060HD : PM-1000 | SVS PC12 Plus | PSA S1500
Sharp LC-70C6400U | miniDSP DDRC-88BM | Belkin PureAV (x2)
ceh383 is online now
post #4241 of 13580 Old 04-30-2013, 09:26 PM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
chances are this one will be fine, but there are no guarantees: I trained my wife to do all this stuff, while I earn the $, an' tweak it when I get home...
but, Friday, we're gonna move together my 3312 to t'other side of the room...and Jerry Rig 11.1 with an old AVR...yes, eventually, I'll have to have one of these...
just 1 more pair of KLIPSCH Classic speakers...
RED AND BLUE=MAROON!
PANASONIC 60" PLASMA 3D, DENON AVR-3312CI, LG BD670 3D NETWORK BRD (iPhone APPs), TOSHIBA HD-XA2 HD DVD, SAMSUNG BD-UP5000 HD DVD/BRD, iPod 8 GB, 13.2: KLIPSCH La Scala 1980 (Crites Rebuilt Type AA Crossovers Sonicaps) FRONT, HERESY II "SIGNATURE EDITION" WIDE, HERESY II CENTER/SURROUND, kg2 SB, kg3/kg1 Front/Rear HEIGHT, RW-12d SW, km-rsw
SanchoPanza is offline
post #4242 of 13580 Old 04-30-2013, 09:50 PM
ceh383's Avatar
Quoted: 418 Post(s)
Liked: 2575
There's no way I could get my wife to even attempt to do it...
By the time I take the 3313 out of the living room, set it up in the bedroom, install the 4520 in the living room, reprogram the remotes, run Audyssey on both, run REW, make adjustments, test everything...It's 8~10 hours or more worth of work.
I'm just not feeling to confident....
post #4243 of 13580 Old 04-30-2013, 09:57 PM
Quoted: 197 Post(s)
Liked: 511
Well, I'd put this one in with just 1 source & run a few simple tests, test tone et C. before investing more time. If all goes well proceed from there.
post #4244 of 13580 Old 04-30-2013, 09:59 PM
Quoted: 197 Post(s)
Liked: 511
Best wishes, wish I could pop over to help.
post #4245 of 13580 Old 04-30-2013, 10:23 PM
ceh383's Avatar
Quoted: 418 Post(s)
Liked: 2575
The last one ran perfectly for two weeks before I had problems with it, that's why I'm a bit leery.
Lately, Mr. Murphy has been no friend of mine....LOL
*EDIT* Those KLIPSCH HERESY II "SIGNATURE EDITION" speakers look very similar to some KLH speakers I had many, many years ago..
post #4246 of 13580 Old 04-30-2013, 10:30 PM
Quoted: 197 Post(s)
Liked: 511
Well "if you aim at nothing, you'll hit it, every time."
post #4247 of 13580 Old 04-30-2013, 10:35 PM
ceh383's Avatar
Quoted: 418 Post(s)
Liked: 2575
True enough, my eye sight isn't what it used to be....Today I need more powerful scopes and/or larger targets....LOL....
post #4248 of 13580 Old 05-01-2013, 12:40 PM
Jerry Incollingo's Avatar
Would it violate any forum rules to post the serial numbers of defective units we had in our possession so others can track whether or not they received one that's been making the rounds? I have 2 of the 3 serial numbers of defective 4520's I'd be happy to post.
Jerry Incollingo is offline
post #4249 of 13580 Old 05-01-2013, 01:15 PM
ceh383's Avatar
Quoted: 418 Post(s)
Liked: 2575
It would be interesting to have a list of serial numbers along with a list of the problems they had.
I've got one number...Hopefully not two...
post #4250 of 13580 Old 05-01-2013, 01:46 PM
highschoolbozo's Avatar
I have been running my 4520 with a 208xxxxxx serial number since late-October - no problems! I had to reset the microprocessor twice, early on, but I can't even remember what those issues were at this time.
IMHO...I think it it is probably worth your time to give this one a try...
Good luck!
highschoolbozo is offline
post #4251 of 13580 Old 05-01-2013, 03:09 PM
Quoted: 197 Post(s)
Liked: 511
post #4252 of 13580 Old 05-01-2013, 06:39 PM
jdsmoothie's Avatar
Quoted: 12094 Post(s)
Liked: 5504
To what end? Any defective units would have been repaired and either returned to the original owner or resold as a refurbished item.
jdsmoothie is offline
post #4253 of 13580 Old 05-01-2013, 06:44 PM
Quoted: 197 Post(s)
Liked: 511
When I buy a refurb 1 of these I can tell if I'm SoL (SMOOTH outa Luck) 'cause I got Jerry's old PoS(mooth) unit!!!
post #4254 of 13580 Old 05-01-2013, 07:18 PM
jdsmoothie's Avatar
Liked: 5504
Good luck with that. You can just PM him and get the information for posterity. wink.gif
post #4255 of 13580 Old 05-01-2013, 08:15 PM
ceh383's Avatar
Quoted: 418 Post(s)
Liked: 2575
From what I've read, and experienced, Denon is a reputable company. I, in no way want to imply anything to the contrary.
So...
Given the complexity of these devices and the wide array connection possibilities it would be, sometimes, impossible to replicate a problem on the test bench. In these instances it could be possible to chalk the problem up to another piece of equipment in the system. In these instances I can see a reputable company reselling the unit without any repair being made, as they saw no problem to fix. As such, I think it would be interesting to see if the same serial number turns up more than once.
"To what end" nothing more than curiosity...
post #4256 of 13580 Old 05-01-2013, 08:26 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6500 Post(s)
Liked: 3608
This sounds like a witch hunt to me.  I see no value.
AustinJerry is online now
post #4257 of 13580 Old 05-01-2013, 09:22 PM
ceh383's Avatar
Quoted: 418 Post(s)
Liked: 2575
And now back to our regularly scheduled programing....
I just did a quick rudimentary setup of the new 4520, hookups are as follows...
DTV box connected to CBL/SAT on AVR with HDMI
Monitor 1 connected to TV with HDMI
Network connected with CAT5e to AVR hub 1
Front speakers only hooked up.
On initial power up, I did a full reset per instructions in post 3 of this thread, hoping this would clear any prior user settings, account settings, etc..connect
Checked Firmware, latest rev is installed.
Using the 4520 remote, I changed the network settings from DHCP to static.
Using my laptop to connect to the AVR works, however, any settings I try to change through the GUI do not take. For instance, Top Menu>>Setup Menu>>General...Zone Rename...
I try to change "Main Zone" to Living room...The screen updates, and it's back to Main Zone.
Any ideas, am I missing something?
post #4258 of 13580 Old 05-01-2013, 10:31 PM
didactandnarpet's Avatar
Hoping so of you knowledgeable people can help me out. I've been the proud owner of a shiny new 4520 for about a week now. Everything has been great up until today. Suddenly out of nowhere my PS3 won't handshake with the receiver anymore. I literally can't do anything on the PS3 without a "snow" screen appearing and then my samsung monitor telling me to check the signal cable. The only way to get a signal is to unplug and replug the hdmi cable. It's very infuriating as the PS3 is what I use the most, and I can't use it with my new 4520. I've tried everything I can think of... both hdmi cable work flawlessly connected directly to the monitor. Not a single hdmi input on the receiver works with the PS3. Every other hdmi device I own is functioning normal when connected to the receiver. I even pulled my old pioneer receiver out of the closet to eliminate any doubt. Needless to say the PS3 worked as normal when connect to my pioneer. I've reset the microprocessor twice which didn't help at all. Disabled deep color on the PS3. From what I've gathered it may be a hdcp handshake problem. The strange thing however is that it was working fine for about a week. Is this something I should talk to Denon about? I really don't want to keep this 4520 if I can't use my PS3 with it. I've recorded a video of the problem I'm facing.
http://www.youtube.com/watch?v=8UghLsMEkvA
didactandnarpet is offline
post #4259 of 13580 Old 05-02-2013, 05:41 PM
jdsmoothie's Avatar
Liked: 5504
Ensure the cursor isn't going to the "Set Defaults" option prior to pressing ENTER, otherwise, although a reset should have cleared up any problems, also try just unplugging the unit for a few minutes.
post #4260 of 13580 Old 05-02-2013, 05:43 PM
jdsmoothie's Avatar
Liked: 5504
Try cycling the HDMI Control setting on the AVR ON/OFF as well as ensuring the Deep Color Output on the PS3 is set to OFF.
Denon Avr 4520ci Receiver
