The **OFFICIAL** DENON AVR-4520CI thread - Page 145 - AVS Forum | Home Theater Discussions And Reviews
 879Likes
post #4321 of 13736 Old 05-08-2013, 04:58 AM
kertofer's Avatar
Crap, you are correct soundofmind, I put the wrong one in my thread. I actually have one of each. The V2W has an LFE in, it is the 2Wq that I was referring too as referenced in the manufacturer pages here: http://www.vandersteen.com/pages/2Wqlit.html
kertofer is offline
post #4322 of 13736 Old 05-08-2013, 06:28 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7564 Post(s)
Liked: 4224
^ So, in order to set your Heights to Large, the Mains and the Surrounds also need to be set to Large.  And if you set Bass=LFE+Mains, you can set individual crossover values for each set of speakers.  I’m following so far.
So now you want to connect the 2WQ sub to the Height pre-out and configure the Height speakers to have a 40Hz crossover?  There could be several things wrong with this configuration.  First, in order for the sub to be contributing to the overall bass response, the Heights must be receiving the full bass signal content.  Is that really the case?  If not, what is the sub actually going to be doing?  Second, you now would have bass reproduced in all speakers as well as the sub.  It has been discussed many times—double-bass rarely produces desirable bass.
To be sure that the sub receives the full bass content, why don’t you power the fronts using the UPA-700 and configure the sub in-line with those speakers?  Of course, this still leaves the double-bass issue.
Another alternative would be to sell the 2WQ and get a more conventional sub.  This would probably get you the best overall bass quality, if that is your objective.
AustinJerry is online now
post #4323 of 13736 Old 05-08-2013, 07:14 AM
kertofer's Avatar
I totally agree with you on the double bass. That is why I was thinking of going to the LFE+Main setting, because then I can still set my Xovers individually. Audyssey set my mains to full band, but I would probably set the Xover on those up to 80Hz, set my Heights to 40Hz to enable the sub, and then leave the Xovers set where Audyssey put them on the other speakers (It set my Surrounds to 80Hz, Backs to 120Hz and my Center to 150Hz for some reason). Shouldn't this eliminate the double bass issue?
I agree with the idea of getting a different second sub, and that is in my plans, but after buying this receiver I am pretty sure the CFO is not going to give me budget for anymore home theater gear for a while. tongue.gif
kertofer is offline
post #4324 of 13736 Old 05-08-2013, 07:51 AM
Liked: 4224
This doesn't answer the first concern--does the Height channel receive the full bass signal?  If not, then your plan wouldn't work.
post #4325 of 13736 Old 05-08-2013, 07:56 AM
kertofer's Avatar
Now that question I do not have an answer to. But I will try it out tonight and let you know if I am seeing bass coming through the sub.
Thanks for the help guys!
kertofer is offline
post #4326 of 13736 Old 05-08-2013, 08:15 AM
kbarnes701's Avatar
Quoted: 6824 Post(s)
Liked: 5260
This Audyssey FAQ answer contains some good reasons why LFE + Main is a bad idea:
f)7.    What is ‘LFE + Main’ or ‘Double Bass’ and should I use it?
kbarnes701 is offline
post #4327 of 13736 Old 05-08-2013, 08:17 AM
kbarnes701's Avatar
Liked: 5260
Jerry - AFAIK the answer to that is 'no'. Roger, if he is listening, would know for sure.
post #4328 of 13736 Old 05-08-2013, 10:08 AM
SoundofMind's Avatar
Liked: 166
OK. AFAIK, the only way to get something close to proper bass management is to set fronts to large and run the Front R/L preouts to that sub, and from there to an ext amp powring the fronts.
Personally, I'd pass that 2Wq sub along to someone else and get a V2W or any good sub that accepts the AVR sub ch preout.
Yes, I still like playing with Dalis.
SoundofMind is offline
post #4329 of 13736 Old 05-08-2013, 11:20 AM
Liked: 166
Excuse me as I may not know enough about this area to ask an intelligent questions but here goes.
1. I am wondering about how well this model handles streaming HiRes MC music off a computer HD as compared to the AVR4311.
2. Also, am I correct in assuming that in that specific regard the 4520 is identical to the Mar 8801 as it shares so many chips/ and digital processing?
3. And furthermore, would that streaming capability be identical to an AVP-A1 with XT32/3D upgrade, which apparently also shares many chips?
post #4330 of 13736 Old 05-08-2013, 11:56 AM
SergeantYnot's Avatar
Liked: 31
From what I researched over on the 8801 forum and here, the DAC, video processor, and system microprocessor chips are identical in both units and both manufactured by Texas Instruments. The technical specs in both manuals appear to be identical as well, and they share the same SNR and noise floor ratings (in preamp-only mode).
SergeantYnot is offline
post #4331 of 13736 Old 05-08-2013, 02:18 PM
moparfan's Avatar
Took a call to customer service but non-Responsive remote problem solved.
I had to go into RC- setup and set the remote ID to "ID-1". It was sent set at "ID-2".
The remote works as it should now.
moparfan is offline
post #4332 of 13736 Old 05-08-2013, 05:50 PM
Jerry Incollingo's Avatar
Thanks for posting your solution, it may help others now.
Jerry
Jerry Incollingo is offline
post #4333 of 13736 Old 05-09-2013, 07:33 AM
kertofer's Avatar
So I put in a question to Ask Audyssey on my subwoofer question yesterday and received the answer back that by setting LFE+Main and leaving the crossover frequency in place as Audyssey set them (I actually bumped it up a bit fo rmy mains, which Audyssey had set to full band so I upped that to 80Hz) I am basically achieving the same thing as setting the speakers to Small. I then did some testing with having the second sub sired inline with the Height channels and setting the crossover (As Audyssey measured) to 40Hz. There was definitely bass coming through the sub, albeit not as much as I have coming through my LFE based sub, which is pretty much what you guys were theorizing.
Since this appears to be a workable solution that should not be really compromising my sound quality I plan to leave this in place until I have the extra cash to get a second LFE style sub and get rid of my old Vandy 2W.
Just wanted to follow up and let you guys know what the testing of these settings showed.
Thanks again for all the great advice!
kertofer is offline
post #4334 of 13736 Old 05-09-2013, 07:41 AM
Liked: 4224
The reduced level of the sub in line with the Height speakers is not likely contributing anything to your overall bass response (placebo at best).  Have you tried a more conventional approach--setting all speakers to Small and removing the sub?  I would wager that your overall sound quality would improve.
BTW, you never answered the question--why not use the Emotiva to drive the front speakers and hook that sub in line to these speakers?
post #4335 of 13736 Old 05-09-2013, 08:38 AM
kertofer's Avatar
AustinJerry, i will try that out and see what happens. You may be correct. I'll let you know what I get when I try that.
The reason I do not want to use the Emotiva to drive the front speakers is simply overall power output of the various channels. The Emotiva is only an 80W/channel amp whereas I have a lot more headroom on the Denon.
kertofer is offline
post #4336 of 13736 Old 05-09-2013, 09:03 AM
Liked: 4224
I have contractors working on the outside of my house today, generating quite a bit of noise.  So I decided to pull out the headphones to listen to some music.  Much to my dismay, when I plugged in the headphones, I was only getting sound from the right channel.  I have used headphones with the 4520 before, and I know that everything was working properly the last time.  I also tested the headphones on the 4311 in the bedroom, and they are not the problem.
So, I tried a deep reset, reloaded my configuration, and tried the headphones again.  No joy--still a dead left channel.  Anyone else have a suggestion?  Is a bad headphone channel enough of an issue to request a replacement, or will Denon insist on having it sent in for repair?
post #4337 of 13736 Old 05-09-2013, 09:12 AM
kbarnes701's Avatar
Liked: 5260
Sorry to hear this, Jerry. If you are in an adventurous mood you might care to take a peek under the hood of your unit and see if there is anything obviously wrong, such as a disconnected wire to the headphone jack etc. Also worth a try is to vigorously insert, remove and reinsert the headphone jack a few times to see if something is 'sticking' and you can free it if so.
I don't know how you'd fare in the US wrt to consumer law. In the UK they would be forced to replace the unit for a new one if it was less than 6 months old. After 6 months they would probably offer a repair under warranty. Sending it in for such a (probably) minor issue is going to be a pain I agree.
post #4338 of 13736 Old 05-09-2013, 09:16 AM
Liked: 31
^ I would probably ask Denon for a replacement instead of a repair since that is probably a board issue (similar to the other reported issues of one channel not working). Then your unit can be relisted as a refurb on Denon or A4L, and months down the line we can see a fresh owner report the same issue tongue.gif
I tested headphones on mine last month and didn't have any issues at all. When you connect your headphones, do you see the display recognize the headphones being plugged in?
post #4339 of 13736 Old 05-09-2013, 09:18 AM
Liked: 4224
Yes, the headphones are recognized.  And I also tried Keith's suggestion to vigorously insert and remove the cable.  Next, I may pop the cover to see if I can see anything.
post #4340 of 13736 Old 05-09-2013, 09:22 AM
Liked: 31
That is definitely the best suggestion. As rare as it might seem, I have seen in the past a cable needing to be properly reseated after shipment on various electronics.
post #4341 of 13736 Old 05-09-2013, 09:46 AM
Liked: 4224
Well, the headphone jack is soldered onto a PC board behind the front panel.  No wires that could be loose.  Now to re-connect all the cables--what a PITA!   frown.gif
post #4342 of 13736 Old 05-09-2013, 10:03 AM
kbarnes701's Avatar
Liked: 5260
A PITA indeed, Jerry. I feel your pain. Things like this drive me nuts.
post #4343 of 13736 Old 05-09-2013, 10:04 AM
Liked: 166
You should give that a try as I'm not sure there's reaaly all that much diff between that emo and the int amps. The UPA-7 is conservatively rated @80 watts all chs driven into 8ohms. The AVR may perform somewhere in that range- but we don't have reliable bench measurements on the 4520 AFAIK. I doubt there's audible difference and neither will be all chs driven in your setup anyway. I tested a UPA2 against the 4311 driving 4ohm low effic speakers set to large and heard no diff @ reference level.
2. The front chs get full bass content-but who knows what the heights get.
I'm confused-you aren't running your other VanD sub off the 4520 sub out, are you?
post #4344 of 13736 Old 05-09-2013, 10:08 AM
davidbarrickman's Avatar
@AustinJerry
Perhaps blowing some compressed air into the headphone jack would be worth a try?
davidbarrickman is offline
post #4345 of 13736 Old 05-09-2013, 10:35 AM
Kisakuku's Avatar
Quoted: 24 Post(s)
Liked: 72
Maybe take a peek down that headphone TRS connector with a pen light just to be thorough?
Kisakuku is offline
post #4346 of 13736 Old 05-09-2013, 11:33 AM
kertofer's Avatar
That sounds like a very reasonable suggestion, and you may well be right about the Emo. It is rated at 80W/channel with all channels driven, and 100W/channel into 4Ohms, which is what my Center is, so it may well do exectly as you suggest.
Yes, I have the other sub (Vandersteen V2W) hooked up via the Sub 1 Out on the Denon.
kertofer is offline
post #4347 of 13736 Old 05-09-2013, 01:14 PM
Liked: 31
Just wanted to clarify, is the UPA-7 or UPA-700 being discussed? If the UPA-7, then that is actually rated at 125wpc (8ohm) and 185wpc (4ohm). If I remember correctly, that was the conservative rating as well as it is was higher than the stated results.
post #4348 of 13736 Old 05-09-2013, 02:10 PM
PepperOne's Avatar
I'm confused about the LED power light on the 4520. When I push the power button, the 4520 turns on and blinks red, then I hear a relay or two click and then the LED turns to a solid green. When I go to turn off the 4520, the unit will turn off and the red LED will be a solid red. Does this signify that the AVR is in stand by mode?
I remember a post by jdsmoothie that mentioned that a solid red LED in standby means that there are two possible items in the setup menu that are active. I don't remember what those two are.
Your help would be appreciated.
Gerry
PepperOne is offline
post #4349 of 13736 Old 05-09-2013, 02:24 PM
Liked: 4224
Gerry
Depends on whether the network is set to "Always On" or "Off in Standby" mode. If the former, then the power LED will remain red when the unit is in standby. If the latter, then the power LED is dark in standby.
post #4350 of 13736 Old 05-09-2013, 02:44 PM
kertofer's Avatar
I have the UPA-700, which is rate at 80W/Channel into 8Ohms and 100W/Channel into 4 Ohms. The test reports they published actually showed it going to 109-111 per channel into 4 Ohms.
kertofer is offline
Denon Avr 4520ci Receiver
