The **OFFICIAL** DENON AVR-4520CI thread - Page 172 - AVS Forum | Home Theater Discussions And Reviews
 863Likes
post #5131 of 13586 Old 07-15-2013, 06:50 PM
Oven's Avatar
I've had my 4520 since the day it came out, and I have only one gripe with the unit. I seem to inadvertently switch on zones 2, 3, and 4 even though I'm not using them. I have a 7.1 setup, with no other zones configured. I want all my available power dedicated to my 7.1. By turning on these zones am I limiting the power that's going to the 7.1 setup?
I don't know if i'm hearing things or what, but it seems the system isn't as loud when I find they're accidentally turned on, and when I turn them off the sound is louder. Anyway, is it possible to disable these zones? I can't find anything in the menus about this, but I do know the unit is highly configurable, and I feel like I've just barely scratched the surface of what it can do.
Oven is offline
post #5132 of 13586 Old 07-15-2013, 07:01 PM
Oven's Avatar
ACK! I just looked in the manual and realized I could bi-amp my fronts! All this time, I forgot the unit had this ability. Looks like once I assign it to 7.1 bi-amped, all the other zones go away. Awesome, can't wait to set it up this weekend!
Oven is offline
post #5133 of 13586 Old 07-15-2013, 08:46 PM
Gary Hudson's Avatar
I find the other zones turned on at times too. I suspect my kids are doing it but there is the possibility that I'm doing it by accident.
Gary Hudson is offline
post #5134 of 13586 Old 07-15-2013, 09:09 PM - Thread Starter
batpig's Avatar
Quoted: 3576 Post(s)
Liked: 3420
Are you guys using universal remotes? Denon changed their IR codes so what used to be the Power On command is now an All Zone Power On. If you are using a universal to power on there's a good chance they are still using the old code.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #5135 of 13586 Old 07-15-2013, 09:12 PM
Oven's Avatar
Yes, I'm using a Logitech Touch (and I hate it). That must be why they're always on.
Oven is offline
post #5136 of 13586 Old 07-15-2013, 09:41 PM - Thread Starter
batpig's Avatar
Liked: 3420
Easy fix. Just teach your universal a different command for Power On discrete. Since the receiver will power on with an input selection command, you can just teach it any old input as a proxy for Power On. For example my X4000 had the same thing and I just taught it InputAUX (front aux input) as Power On.
Setup Guide and FAQ
batpig is offline
post #5137 of 13586 Old 07-16-2013, 03:05 AM
SoundofMind's Avatar
Liked: 166
Originally Posted by Oven View PostI seem to inadvertently switch on zones 2, 3, and 4 even though I'm not using them. I have a 7.1 setup, with no other zones configured. I want all my available power dedicated to my 7.1. By turning on these zones am I limiting the power that's going to the 7.1 setup?
Simply having unused zones enabled should not affect the available power as it's not using any of the capacity of the amps or the poweer transformer.
This is not true biamping but rather "passive" biamping.  It is unlikely to make any difference in terms of SQ.  As you are still limited to the total power available through your one power transformer and still using the passive crossovers built into your speakers, this technique really does not increase the power available for any particular driver in a way that's meaningful.
Yes, I still like playing with Dalis.
SoundofMind is offline
post #5138 of 13586 Old 07-16-2013, 03:19 AM
Wilford's Avatar
Thanks, I was not aware of this. I used the codes from the Logitech Server. Result: all Zones was turned on and all was turned off at close down. I had this rather annoying problem, 5 minutes or so, after I turned on my Denon AVR-4520, it suddenly changed to another input.
Btw. I love my Logitech Ultima remote.
Samsung UE70KU6075 - Denon AVR-4520 - OPPO UDP-203
Patos Lyric 502 - Cerwin Vega E76C - Patos Lyric SUB 10 - Dali R1000
More - wilford.no
Wilford is offline
post #5139 of 13586 Old 07-16-2013, 05:39 AM
knoxtn's Avatar
I've had maybe 10 top of the line receivers in the past and this one is the first that I've had zero problems with. From day one.
knoxtn is offline
post #5140 of 13586 Old 07-16-2013, 03:41 PM
tknx's Avatar
Quoted: 29 Post(s)
I have a Harmony 700, and it seems to work fine.
Moving over to Roomie Remote IP control and also doesn't seem to be a problem, although I need to really sit down and run through the whole setup.
Denon X4300H | Salk Veracity ST | SVS SB13 Ultra | Neeo Remote (pending)
tknx is offline
post #5141 of 13586 Old 07-18-2013, 04:23 AM
fab68's Avatar
Originally Posted by GlockFan View Post
I just ordered a Brand New Denon 4520 with full factory 3 year warranty from an Authorized Denon Dealer for less than the Accessories 4 Less price.
harrybnbad, I sent you a PM.
Could you please guide me on were you got this deal? I am interested on a 4520
fab68 is offline
post #5142 of 13586 Old 07-18-2013, 09:43 AM
GlockFan's Avatar
PM Sent.
GlockFan is offline
post #5143 of 13586 Old 07-18-2013, 09:46 AM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
CALL AVS Sales
just 1 more pair of KLIPSCH Classic speakers...
RED AND BLUE=MAROON!
PANASONIC 60" PLASMA 3D, DENON AVR-3312CI, LG BD670 3D NETWORK BRD (iPhone APPs), TOSHIBA HD-XA2 HD DVD, SAMSUNG BD-UP5000 HD DVD/BRD, iPod 8 GB, 13.2: KLIPSCH La Scala 1980 (Crites Rebuilt Type AA Crossovers Sonicaps) FRONT, HERESY II "SIGNATURE EDITION" WIDE, HERESY II CENTER/SURROUND, kg2 SB, kg3/kg1 Front/Rear HEIGHT, RW-12d SW, km-rsw
SanchoPanza is offline
post #5144 of 13586 Old 07-18-2013, 08:16 PM
GlockFan's Avatar
I have had a chance to spend some time with my new 4520.
I am simply amazed at how good this receiver sounds.
I put it on Pandora and cranked up some Rush and it sounded as if I was sitting on the front row at a concert. It is unbelievable!
I love it!!
GlockFan is offline
post #5145 of 13586 Old 07-18-2013, 08:25 PM
Kisakuku's Avatar
Quoted: 24 Post(s)
Liked: 72
I love it!!
128kbps does not a live concert make.
donmj1 likes this.
Kisakuku is offline
post #5146 of 13586 Old 07-18-2013, 08:30 PM
GlockFan's Avatar
It does when you my B&W CM5's cranked.. LOL
There is definitely better sources but the receiver is incredible.
GlockFan is offline
post #5147 of 13586 Old 07-18-2013, 08:58 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6621 Post(s)
Liked: 3654
A bucket of ice water would have been equally effective.
AustinJerry is online now
post #5148 of 13586 Old 07-18-2013, 09:37 PM
Kisakuku's Avatar
Quoted: 24 Post(s)
Liked: 72
Oh, so that's what people mean when they say "splash damage'!
Kisakuku is offline
post #5149 of 13586 Old 07-18-2013, 09:38 PM
GlockFan's Avatar
lol
GlockFan is offline
post #5150 of 13586 Old 07-19-2013, 03:54 AM
Wilford's Avatar
Still have this rather annoying problem, 5 minutes or so, after I turned on my Denon AVR-4520, it suddenly changed to another input from the one I’m currently using.
More - wilford.no
Wilford is offline
post #5151 of 13586 Old 07-19-2013, 08:51 AM - Thread Starter
batpig's Avatar
Liked: 3420
Is it a random input or is it always going to one specific input?
Setup Guide and FAQ
batpig is offline
post #5152 of 13586 Old 07-19-2013, 07:14 PM
harrybnbad's Avatar
Quoted: 58 Post(s)
Can someone tell me the android app that controls this amp . The 4520...
harrybnbad is offline
post #5153 of 13586 Old 07-19-2013, 10:16 PM
Kisakuku's Avatar
Quoted: 24 Post(s)
Liked: 72
http://play.google.com/store/apps/details?id=de.pskiwi.avrremote
Kisakuku is offline
post #5154 of 13586 Old 07-20-2013, 01:52 AM
Wilford's Avatar
More like random input.
I have done a reset to the CPU more than once.
More - wilford.no
Wilford is offline
post #5155 of 13586 Old 07-20-2013, 03:17 AM
jdsmoothie's Avatar
Quoted: 12216 Post(s)
Liked: 5562
If random and not "TV" all the time then not likely related to the HDMI-CEC setting on the TV, never-the-less, if ON, set it to OFF (eg. Anynet+, VieraLink, BraviaSync, etc.). Otherwise, when this issue has been seen on the lower level models, it is generally an indication of HDMI board failure.
jdsmoothie is online now
post #5156 of 13586 Old 07-21-2013, 03:07 AM
Wilford's Avatar
I tried something new, I turned OFF Network in Std By. This seems to work, so far anyway..
SanchoPanza likes this.
More - wilford.no
Wilford is offline
post #5157 of 13586 Old 07-21-2013, 08:36 AM
petetherock's Avatar
Quoted: 1078 Post(s)
Liked: 516
Yes, that worked for me too a few months back..
petetherock is offline
post #5158 of 13586 Old 07-21-2013, 09:00 AM
Quoted: 197 Post(s)
Liked: 511
Thank you, gentlemen, thank you.
post #5159 of 13586 Old 07-21-2013, 09:14 AM
Wilford's Avatar
I hope that the people at Denon Technical staff are reading this. Maybe this can be fixed in a future firmware release.
More - wilford.no
Wilford is offline
post #5160 of 13586 Old 07-21-2013, 09:26 AM
jdsmoothie's Avatar
Liked: 5562
Much better to give Denon USA or your local regional rep a call to identify the problem and resolution to them as well. smile.gif
Denon Avr 4520ci Receiver
