The **OFFICIAL** DENON AVR-4520CI thread - Page 189 - AVS Forum | Home Theater Discussions And Reviews
 2377Likes
post #5641 of 13775 Old 09-05-2013, 12:34 AM
geoffrsc's Avatar
Originally Posted by JohnAV View Post
You turn off network standby.
Default is network "Always On"
OK, got it, thanks. Somehow I managed to search the manual and miss that. I appreciate the help.
geoffrsc is offline
post #5642 of 13775 Old 09-05-2013, 07:11 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7741 Post(s)
Liked: 4333
The downside, of course, is that any other devices that might be connected to the network hub will lose their connections. For example, I have my two DirecTV DVR's on the hub, and occasionally set up a recording using the DTV web app when the 4520 is powered off. This wouldn't be possible unless Network Always On was set.
AustinJerry is online now
post #5643 of 13775 Old 09-05-2013, 07:02 PM
Randy Schmidt's Avatar
Quoted: 48 Post(s)
Liked: 25
Can I use the second sub out on this receiver and tune my 18" sealed sub to just play 30 hertz and lower. I have (4) Epik Empires connected to sub 1 out.
Thanks...
Theater: Denon AVR 4520ci - Emotiva XPR-5 - Denon 3313 BDP - L/C/R Klipsch KL7800 THX, SL/SR Klipsch KS7800 THX SBL/SBL, FHL/FHR, FWL/FWR Klipsch 5800W - (2) Epik Empire subs/(1) DIY 18" sub - Darbee Darblet - Epson 5030UB/150" Fixed Mount Screen
Family Room: Denon AVR X6200W - Sony XBR55X930D - Samsung UBD-K8500 - (5) Speakercraft Profile AIM8 One
Randy Schmidt is offline
post #5644 of 13775 Old 09-05-2013, 07:14 PM - Thread Starter
batpig's Avatar
Quoted: 3732 Post(s)
Liked: 3613
The two sub outs receive an identical signal and are EQd as a summed response. So that kind of "splitting the load" functionality isn't really supported natively.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #5645 of 13775 Old 09-05-2013, 07:17 PM
Quoted: 48 Post(s)
Liked: 25
thx Batpig. You can set the volume for each sub out independently... Correct. Just not the freq.
post #5646 of 13775 Old 09-05-2013, 08:08 PM
Oven's Avatar
If I go into my AVR and change the crossover settings or change my fronts from big to small, do I need to rerun Audyssey? My speakers were detected as large.
Oven is offline
post #5647 of 13775 Old 09-05-2013, 08:12 PM
Liked: 4333
No. You may set the speakers to Small and set a crossover value with no effect on the Audyssey calibration. It is actually recommended to set all speakers to Small if you have a sub.
post #5648 of 13775 Old 09-05-2013, 08:19 PM
geoffrsc's Avatar
Yes. Also, my iPhone remote apps don't see the unit if it's not in Network Standby so I have to turn it on another way before I can use the app.
geoffrsc is offline
post #5649 of 13775 Old 09-05-2013, 08:27 PM
aries316's Avatar
First i want to say thank you to everyone in the community. I have learned so much from all of you. So I have two more questions.
1. Audyssy set my crossover on all my speakers to 40hz with the exception of my center channel it set it to 60hz. Should I change the crossovers to 60hz or leave them where they are at.
2. I am looking for a 10ft trigger to go from my Denon to my Emotiva XPA-3 Gen 2. The one that came with the Emotiva was too short. I have been looking and haven't been able to find one.
Thanks/
aries316 is offline
post #5650 of 13775 Old 09-05-2013, 09:21 PM
Liked: 4333
Thanks/
OK to raise the crossovers to any value you like.  If you have a capable sub, I would raise all satellites to 80Hz.
You should be able to pick up a longer mono cable at a Radio Shack store.  Take the short one with you and show it to them.  It will be very inexpensive.
post #5651 of 13775 Old 09-05-2013, 09:30 PM
aries316's Avatar
Thanks I'll give that a try
aries316 is offline
post #5652 of 13775 Old 09-07-2013, 06:58 PM
oink's Avatar
Quoted: 5299 Post(s)
Liked: 3036
I think I may have figured out what my 4520ci is trying to do: it is giving me the message on the Front Display it is in "H/P input on" when first turned on.
And because of this, is not outputting sound to my speakers.
In other words, it believes it is hooked up to headphones when it is not.
Anyone else having this problem?
oink is offline
post #5653 of 13775 Old 09-07-2013, 07:06 PM
jdsmoothie's Avatar
Quoted: 15390 Post(s)
Liked: 7528
This a problem that is quite common with the XX09 models, but don't recall any 4520CI owners experiencing it.
jdsmoothie is offline
post #5654 of 13775 Old 09-07-2013, 07:22 PM
Liked: 4333
Is this caused by a defective headphone jack, JD? You may recall that I returned a 4520 for replacement because of a defective headphone jack as well as a defective calibration mic jack, which I believe are on the same board.
post #5655 of 13775 Old 09-07-2013, 07:59 PM
jdsmoothie's Avatar
Liked: 7528
Sorry, it's been too long since then and had indeed forgotten, although likely related if your unit also displayed the "H/P input ON" message. The issue with the XX09 models is caused by build up of dust on the connections rather than a defective jack.
post #5656 of 13775 Old 09-07-2013, 11:21 PM
oink's Avatar
Liked: 3036
My 4520 is a direct from Denon refurbish.
oink is offline
post #5657 of 13775 Old 09-08-2013, 01:27 AM
jdsmoothie's Avatar
Liked: 7528
I would first try the solution used with the XX09 models which is to blow compressed air into the headphone jack or insert/remove a headphone plug a few times.
post #5658 of 13775 Old 09-08-2013, 04:35 AM
jake51's Avatar
Quoted: 109 Post(s)
When I try to enter the code to control my Cambridge Audio BD player, I get the FAIL message
Actually, the code for Cambridge BD players is not on the list?
40157 is the only Cambridge code on the entire list
Is there a solution?
jake51 is offline
post #5659 of 13775 Old 09-08-2013, 05:24 AM
nexusdoan's Avatar
Hey Guys,
I am trying to play two different audio sources on Zone 1 vs. Zone 2. I can get the same audio (airplay) to play on both but am unable to watch TV on Zone 1 while listening via airplay on Zone 2. Is this not possible?
nexusdoan is offline
post #5660 of 13775 Old 09-08-2013, 05:35 AM
mhrischuk's Avatar
Quoted: 63 Post(s)
Liked: 88
Hello I Have a Denon 4520ci set up with 9.2 is there a benefit to getting a Emotiva XPA-5 5-Channel Power Amplifier to take some of the load of the AVR? I know if i add an amp i can go to 11.2 but is there any other advantage?
Do you need more power? I have always heard that it's best to have too much than not enough. You want to be able to handle the spikes without distorting everything below. Headroom.
As so many have repeated... it depends on how loud you like to listen.
I like loud. I wanted to be able to feel the power. At levels like that you can hear if there is something weak in the system.
My current setup using the 4520 only uses the AVR amps for the four surrounds.
My front LCR's are Seaton CAT12's and a Seaton CAT8 center. These are self powered with a total of 5000 watts.
Sub is SVS PB-13 Ultra.
Total system power 4 x 150 + 750 (sub) + 5000 = 6350 watts
I think I'm done for a while.
Seriously though right now I think my only real complaint with the 4520ci is the lousy remote with the almost unreadable display that constantly flashes on and off even if you walk past it. Horrible for a flagship unit.
See My System Here
Processor: Emotiva XMC-1
R/C/L Amps... (3) Emotiva XPR-1's (1750w x 3 = 5250w)
Surround Amps: Emotiva XPA-5 G2 (200 x 4 = 800w) not using 5th
Zone 2: Emotiva Mini-X a-100 driving 2 Boston Acoustics Voyager 70's
10050 watts total power.
mhrischuk is offline
post #5661 of 13775 Old 09-08-2013, 05:55 AM
kbarnes701's Avatar
Quoted: 6824 Post(s)
Liked: 5262
If you are able to drive your speakers, in your room, to the SPL levels you require, without clipping, then more power won't serve any useful purpose. So the question is, can you?  If yes, then you are all set. If no, then more power might be useful.
Having "too much" power is pointless. If your speakers can be cleanly driven to xxdB using Y watts, then having 5Y watts won't make any difference. The additional power will be left on the table.
Here is a very good AVS thread that goes into a lot of detail about it and which hasn't - so far - been derailed by 'audiofools':
http://www.avsforum.com/t/1485846/quality-power
SoundofMind likes this.
kbarnes701 is offline
post #5662 of 13775 Old 09-08-2013, 10:44 AM
SoundofMind's Avatar
Liked: 166
^Nice link, Keith.
Yes, I still like playing with Dalis.
SoundofMind is offline
post #5663 of 13775 Old 09-08-2013, 10:49 AM
mhrischuk's Avatar
Quoted: 63 Post(s)
Liked: 88
Yea but what about bragging rights? LOL
See My System Here
post #5664 of 13775 Old 09-08-2013, 12:35 PM
kbarnes701's Avatar
Liked: 5262
post #5665 of 13775 Old 09-08-2013, 12:39 PM
kbarnes701's Avatar
Liked: 5262
Ah well... they are worth having, no doubt about that.  And appearance too - some of those McIntosh amps look totally wikkid. There are lots of good reasons for buying big, shiny, new amps. It's just that improved sound quality isn't usually one of them ;)  If I had my amps on show, I'd love a pair of those big Macs with huge meters and stuff.  I'd get a load of pleasure from owning them - but none of it would be audible, in my case.
post #5666 of 13775 Old 09-08-2013, 11:40 PM
oink's Avatar
Liked: 3036
Thanx, will give it a try.
oink is offline
post #5667 of 13775 Old 09-09-2013, 09:41 PM
JohnAV's Avatar
Quoted: 399 Post(s)
Liked: 552
New FW found tonight (9/9/2013) for the 4520CI. Says 7 mins to download. Did Main, then saw Ether IMG, then a quick reboot, and back to menu OK.
Was 3325-0843-4401 now updated to 3325-3843-4485.
Oppo Beta Group
JohnAV is online now
post #5668 of 13775 Old 09-10-2013, 02:06 AM
Wilford's Avatar
New Firmware also for European versions of AVR-4520.
Samsung UE70KU6075 - Denon AVR-4520 - OPPO UDP-203
Patos Lyric 502 - Cerwin Vega E76C - Patos Lyric SUB 10 - Dali R1000
More - wilford.no
Wilford is offline
post #5669 of 13775 Old 09-10-2013, 03:08 AM
jdsmoothie's Avatar
Liked: 7528
post #5670 of 13775 Old 09-10-2013, 03:41 PM
thinds's Avatar
This is a great forum and have used it many times for research. I thank y'all.
Now I have a prob and became a member.
Anybody had any trouble with the subwoofer outs dropping output or content? My 4520 is not a month old yet.
Just had my POA 2800 repaired due to loose grounds by cert Denon rc. Came home and hooked to 2 new Dayton subs and ran some spl thru system and was amazed. Ran it all hard. The other night I had it loud but not cranked so as not to bother my neighbor and all of a sudden heavy bass went away. Sub out was at -6 or -3. Usu at -6 if cranked. No appreciable low end increase when sw vol set to +3 or +6. Called repair center and spoke with tech who fixed and he bet it was the 4520 screwing up the sub out content and not the 20 or so year old 2800 having another issue Amp still works but does not seem to have authority now. Hooked 2800 up to old Onkyo mono sub out w y adapter as used in previous set ups and it seemed it took some volume to get the subs kicking. So much that the little outdoor polks were giving out on the high end.
The low end does not sound like it did is all I know.
Just wanna check it out before I pull the trigger on the Yamaha pro series P7000 amp. Cuz if it could be the 4520, I really do not need to spend the cash on a new amp.
Thank in advance.
thinds is offline
Denon Avr 4520ci Receiver
