The **OFFICIAL** DENON AVR-4520CI thread - Page 190 - AVS Forum | Home Theater Discussions And Reviews
 2377Likes
post #5671 of 13775 Old 09-10-2013, 04:56 PM
howard68's Avatar
Quoted: 152 Post(s)
Hi
Had the 4520 ci for 9 months
It has been good until
Today it is just shutting down and the light is flashing red
Unplugged it a few times
Any advice?
howard68 is offline
post #5672 of 13775 Old 09-10-2013, 05:04 PM
jdsmoothie's Avatar
Quoted: 15377 Post(s)
Liked: 7518
Check to make sure your speaker wire connections are secure with no loose strands from one post touching another post which is the most common reason for an AVR to shut down, especially if there are small animals or kids that may have gotten behind the AVR.
jdsmoothie is offline
post #5673 of 13775 Old 09-10-2013, 05:25 PM
SoundofMind's Avatar
Liked: 166
power indicator blinking every .5 sec is most likely a speaker cable short (stray speaker wires touching)
As jd said, first thing check for stray/loose wires at all speaker wire posts (rear of AVR and rear of speakers)
power indicator blinking every 2 sec is thermal overload
aries316 likes this.
Yes, I still like playing with Dalis.
SoundofMind is offline
post #5674 of 13775 Old 09-10-2013, 05:31 PM
Liked: 166
Originally Posted by thinds View Post
...Anybody had any trouble with the subwoofer outs dropping output or content? My 4520 is not a month old yet.
Just had my POA 2800 repaired due to loose grounds ...
Just wanna check it out before I pull the trigger on the Yamaha pro series P7000 amp. Cuz if it could be the 4520, I really do not need to spend the cash on a new amp.
Hi, welcome.  I disagree with the tech, based on your report.  AFAIK there's no known sub preout issue on the 4520. Yup, prob better to spend the $ on a new amp than re-fix the old one.
post #5675 of 13775 Old 09-10-2013, 06:37 PM
howard68's Avatar
Quoted: 152 Post(s)
Thanks for the info
On the red light
Will see what it says
When it happens again
howard68 is offline
post #5676 of 13775 Old 09-10-2013, 07:11 PM
thinds's Avatar
Yep. Thanks for the + rei.
thinds is offline
post #5677 of 13775 Old 09-11-2013, 06:02 AM
Hugo S's Avatar
Quoted: 257 Post(s)
Liked: 152
Hi,
Originally Posted by kbarnes701 View Post
Here is a very good AVS thread that goes into a lot of detail about it and which hasn't - so far - been derailed by 'audiofools':
http://www.avsforum.com/t/1485846/quality-power
Hugo
Hugo S is offline
post #5678 of 13775 Old 09-11-2013, 12:01 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7738 Post(s)
Liked: 4332
Just received and installed a Sony XBR65X900a 4K flat panel.  With IP Scaler = On in the 4520, the Sony will not see a signal.  I tried all IP Scaler settings, from 4K down to 480i, and regardless of the setting, if the 4520 is scaling the video, the Sony refuses to recognize the signal.  With IP Scaler = Off, the signal is passed through the 4520 and up-converted in the Sony just fine.
Anyone else out there with a 4520 and a 4K display that can test this out?
AustinJerry is online now
post #5679 of 13775 Old 09-11-2013, 12:48 PM
kbarnes701's Avatar
Quoted: 6824 Post(s)
Liked: 5262
Hey Jerry.  I'm just guessing here, but are you trying to marry up two different '4K' standards. AIUI, the Sony 4K TV is 'Ultra HD' which has a res of 3840 x 2160. But 'real' 4K, as seen in the Sony 4K cinemas, has a res of 4096 x 2160.  Yet another brilliant example of standardisation of standards from the AV world. Could it be that your Denon has 'real 4K' upscaling and your Sony has Ultra HD?  If so, then it's likely they can't talk to each other. HST, I'd have expected them to find a res that they both have in common and settle on that.
I know that you will want the Denon to work with the TV in the way it ought to, but there's surely nothing wrong with upscaling to 4K in the Sony?
I doubt if this answer is going to help you much, but it was my first thought when I saw your problem.
kbarnes701 is offline
post #5680 of 13775 Old 09-11-2013, 02:46 PM
howard68's Avatar
Quoted: 152 Post(s)
Re set processor
Still shutting down
Will have to send it to
Doc Denon now
Will let you know how the repair process works
howard68 is offline
post #5681 of 13775 Old 09-11-2013, 02:48 PM
Liked: 4332
This issue has been reported to both Sony and Denon.  I'll report back if I get an answer.
post #5682 of 13775 Old 09-11-2013, 02:49 PM
Liked: 4332
Interesting theory, Keith, but not sure if it is the root cause.
post #5683 of 13775 Old 09-11-2013, 03:36 PM - Thread Starter
batpig's Avatar
Quoted: 3729 Post(s)
Liked: 3607
The perils of early adoption in the stupid world of HDMI. I don't have any insight into the problem but my money is on a firmware fix being necessary for one or both devices.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #5684 of 13775 Old 09-11-2013, 04:20 PM
PMA
PMA's Avatar
Quoted: 113 Post(s)
Liked: 34
Just got a message that there is new firmware for this unit. Any idea what is in it? Is there a place to go to see any release notes?
PMA is offline
post #5685 of 13775 Old 09-11-2013, 04:33 PM - Thread Starter
batpig's Avatar
Liked: 3607
See post #4 in this thread where JD posts changelog info. Denon doesn't publicize this but JD gets it through an inside connection and posts it here.
Setup Guide and FAQ
batpig is offline
post #5686 of 13775 Old 09-11-2013, 06:45 PM
hansangb's Avatar
Just got my 4520 (Thank you JD!!!) Can anyone with URC tell me what Denon listings you used? I'm assuming it's the ones on the bottom but just wanted to be sure. I've also sent an email to URC asking them when it will be "added" by name.
hsb
Hansang
hansangb is offline
post #5687 of 13775 Old 09-13-2013, 01:58 PM
mhaneef's Avatar
1324 is pretty popular in Complete Control for URC.
mhaneef is offline
post #5688 of 13775 Old 09-14-2013, 08:45 AM
Mark1000's Avatar
Quoted: 13 Post(s)
Although it is great to have an inside man, the changelog is also available, as always, at http://firmware.denon.eu. Mark
Marantz 8802A | Rotel RB 1590 / 1555 | Bowers Wilkins 804D3 / HTM2D3 / DB3D / 703S2 / 706S2 | Oppo 105 / 203 | LG OLED55E6 | Panasonic PTAE 4000 | Cable box | Chromecast Ultra | Apple TV | 2× Darbee Darblet
Mark1000 is offline
post #5689 of 13775 Old 09-14-2013, 09:26 AM
hansangb's Avatar
Thank you.. Lot of the functions seem to map well. I'm mapping it out with MX900 editor first, and will move on to CCP when I get a chance.
Hansang
hansangb is offline
post #5690 of 13775 Old 09-14-2013, 09:31 AM
jdsmoothie's Avatar
Liked: 7518
Note access to the Europe website is only available if you have an European unit serial number to use. If you would like to offer yours, I can post it in post #6 for all to use. wink.gif
post #5691 of 13775 Old 09-14-2013, 03:49 PM
Mark1000's Avatar
Quoted: 13 Post(s)
Mark1000 is offline
post #5692 of 13775 Old 09-15-2013, 08:15 AM
jdsmoothie's Avatar
Liked: 7518
post #5693 of 13775 Old 09-15-2013, 03:20 PM
hansangb's Avatar
I need help with Airplay. I read the Denon/Marantz Airplay FAQ, and six pages of "airplay" related posts in this thread. I thought the post about setting the GUI/Net timeout to 30 vs always on was my problem, but alas that wasn't it.
Internet Radio works. Denon sees my PC as a viable source, so there's no connectivity issues.
When I start the music app (Apple's native Music app on Ipad), I just don't see the Airplay icon. Apple's troubleshooting articles all start with "make sure you're airplay devices are on..."
So other than tuning to the NET source, is there anything else I need to do for the 4520? Looking at the FAQ, I guess the older models xx11's required an Airplay App purchase from Denon. I couldn't find anything for the 4520 so that doesn't seem to be the issue. (and the manual doesn't say anything about it).
So is there anything you need to do to start Airplay function on the receiver? Other than tuning to NET source?
I can't imagine how this would factor in, but I do have a static IP assigned to the receiver.
Thank you.
Hansang
hansangb is offline
post #5694 of 13775 Old 09-15-2013, 05:03 PM
mhrischuk's Avatar
Quoted: 63 Post(s)
Liked: 88
I agree.
See My System Here
Processor: Emotiva XMC-1
R/C/L Amps... (3) Emotiva XPR-1's (1750w x 3 = 5250w)
Surround Amps: Emotiva XPA-5 G2 (200 x 4 = 800w) not using 5th
Zone 2: Emotiva Mini-X a-100 driving 2 Boston Acoustics Voyager 70's
10050 watts total power.
mhrischuk is offline
post #5695 of 13775 Old 09-15-2013, 05:54 PM
jdsmoothie's Avatar
Liked: 7518
Thank you.
http://www.avsforum.com/t/1465528/the-official-2013-denon-e-series-x-series-avr-model-owners-thread-faq/0_100#user_L1
post #5696 of 13775 Old 09-15-2013, 06:56 PM
a33montoya's Avatar
Longtime lurker here on the AVS forums I recently bought a 4520 and have set it up and everything is working great.
Build date is 04/13 according to the serial number. I ran the calibration and it set all my speakers to large except my surround backs I will try changes this to a standard all 80hz crossover. I did manage to read through this entire thread skipping the bulk of the off topic stuff which was extensive lol. I am coming from a older pioneer elite vsx-94txh and the difference is night and day no buyers remorse whatsoever. I had one question regarding changing my speakers from large to small if I leave them with what audyssey set them to will the sub only compliment my surround rears?
a33montoya is offline
post #5697 of 13775 Old 09-15-2013, 07:05 PM
Liked: 4332
The normal setting is for the subs to receive bass signals from all speakers set to small. So if only your surrounds are set to small, the subs will only get their redirected bass, in addition to whatever is on the LFE track, of course.
The recommended action is to change all speakers to small, and then set the crossover to a value you find acceptable. 80Hz is a good starting point.
post #5698 of 13775 Old 09-15-2013, 07:05 PM
a33montoya's Avatar
I forgot to add my receiver temperature averages around 115-120F I have it in a cabinet with fully opened front 12" on top but only 1/4" on the sides and 4" in the rear. Is this good or is the temp to high?
post #5699 of 13775 Old 09-15-2013, 07:07 PM
Liked: 4332
Sounds about normal to me.
a33montoya likes this.
post #5700 of 13775 Old 09-15-2013, 07:22 PM
a33montoya's Avatar
Ok so just for clarification if all my speakers are set to large LFE will still be sent to the sub. This is something I misunderstood. For some reason I thought had all speakers been set to large the sub would be bypassed. I thought LFE would be sent to the satellites. I would also like to note the calibration for this unit corrected a sub issue I had I was always able to localize bass with MCACC I tried everything with the exception of getting an eq for my sub. With the pioneer I always had it set to 80hz all small and it just was no good.
Denon Avr 4520ci Receiver
