The **OFFICIAL** DENON AVR-4520CI thread - Page 220 - AVS Forum | Home Theater Discussions And Reviews
 863Likes
post #6571 of 13580 Old 01-11-2014, 01:31 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6494 Post(s)
Liked: 3605
I measured the temperature of the 4520 after it had been running quite some time, and I measured 130 degrees F. At the hottest part of the case. My unit is on an open shelf with free air circulation on all sides. I don't think this temperature is overly hot or a cause for concern. I have never seen or heard the internal fans turn on, which would be an indication of overheating.
My recommendation would be to stop worrying about temperature and enjoy your new system.
AustinJerry is online now
post #6572 of 13580 Old 01-11-2014, 02:10 PM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5069
Originally Posted by WHATTHEDILEO View Post
It misjudges subwoofer distance (14ft away, Audyssey thinks it is 26ft),
The 'distance' setting is really nothing to do with 'distance' as such. A better name for this on-screen item would be 'delay' because that is what it actually is. Audyssey is not measuring the 'distance' of the speaker under test (in your case here, the sub), it is measuring the delay between the sound leaving the AVR and arriving, via the sub, at the mic. Audyssey does this with a very good degree of accuracy. It is perfectly normal for the actual, physical distance of the sub from the MLP to be significantly less than the 'distance' (delay) reported by Audyssey. This is because Audyssey has 'taken into account' the delays inherent in the subwoofer which are caused by DSP in the sub's circuits. You may have observed that Audyssey sets the 'distances' for the satellite speakers pretty accurately, in relation to their actual distances (because no inherent delay is there in a passive speaker). It is unlikely that the Audyssey algorithms will measure the distance/delay for one speaker (eg the centre) correctly but then measure incorrectly for another speaker (eg the Sub).
The objective, of course, is to have all sound arrive at the MLP at the same time. It is clearly impossible for Audyssey to physically relocate the sub to achieve this, so it does it a different way. It increases the 'distance' setting (the delay) from the actual 14 feet to 26 feet - an additional 12 feet. Sound travels at approx 1130 feet in one second. So it will travel 12 feet in approx 11 milliseconds. What this means in your case is that Audyssey has worked on the basis that the sub is 12 feet further away than it really is, so the AVR needs to 'start' the sound 11ms 'early' in order that it arrives at your ears at the same time as the sound from the other speakers when the system is being used. The 11ms is the time by which the signal is delayed due to the processing going on inside the Sub's amp. This is covered in the Audyssey FAQ:
f)1.    Why has Audyssey set my sub distance much greater than it actually measures?
So, far from being some sort of 'mistake', or 'misjudgement' Audyssey is working properly in the context of the system it is measuring.
... and in my opinion it SEVERELY under-emphasizes sub output without user intervention. I ran 8-point calibration TWICE, without improvement. I know sub distance is traditionally inexact in the past, but I bought this in anticipation of its amazing subwoofer calibration abilities. In it's final setup, it will control multiple subs,
Audyssey aims to deliver its target curve after calibration. Many people are unused to accurate bass. They may have spent years listening to room influences on the bass frequencies which can produce peaks of up to 20dB very commonly in an untreated room. When these peaks are removed by equalization, there is often a sense that 'something is missing' - and it is: the big peaks! If you use independent measuring after running Audyssey you will see that the bass is usually fairly accurate at reference level (Audyssey's objective) assuming the subs are capable of performing to the required standard.If you are listening below Reference Level (for movies) you will need to engage Dynamic EQ which will boost the bass to bring it perceptually back to where it would be at Reference, even at levels well below Reference. Turn on Dynamic EQ if you haven't already done so.  Of course, some people have a preference for boosted bass, which is fine, but it is always the best policy to start with Reference and then to move on to Preference once a base line has been established.
See also here:
f)5.    Since I ran Audyssey everything sounds great - but where has my bass gone?
And here for info on Dynamic EQ:
g)2.   What is Dynamic EQ?
... so observing qty(2) deficiencies in this temporary setup with a single 15" sub makes me question its effectiveness with blending multiple 18" subs.
You are questioning its effectiveness based on 'deficiencies' which are based on misunderstandings. I can assure you that MultEQ XT32 is the best way to electronically EQ your bass frequencies at anything like an affordable price. There is considerable information in the Audyssey FAQ which may be of help - linked above for contextual references and in my signature.
kbarnes701 is offline
post #6573 of 13580 Old 01-11-2014, 02:26 PM
sdrucker's Avatar
Quoted: 677 Post(s)
Liked: 449
^^ Make that MultiEQ comment "at an affordable price and to EQ without considerable measurement experience or without acquiring esoteric standalone tools".
Otherwise XT32 in particular's a fantastic bang for the buck and learning curve, period.
Audio Gear: Trinnov Altitude 16/24, NAD M27 and Wyred4Sound MMC-7 amps
Display: Panasonic VT50, Lumagen Radiance Mini. Misc.: Oppo 103, Samsung K8500 UHD player, JRiver
Speakers: PSB Imagine T2, Center, Imagine T Wides and Side Surrounds, Imagine S rear surrounds,
PSB Imagine XA Dolby AE Speakers (4), HSU ULS-15 subs (4) - 9.4.4
sdrucker is online now
post #6574 of 13580 Old 01-11-2014, 02:50 PM
DougReim's Avatar
Liked: 24
When new, my 4520 ran from 110-130 +/- so I bought a cheapie USB fan that I programmed to turn on at 120.
Now, after using it for almost a year the fan never turns on. The 4520 runs between 100-110 now, so for whatever reason my unit has cooled down almost 20 degrees since new.
Doug
TV Room Upgrade Completed
DougReim is offline
post #6575 of 13580 Old 01-11-2014, 02:55 PM
kbarnes701's Avatar
Liked: 5069
Yes, agreed.
post #6576 of 13580 Old 01-11-2014, 02:56 PM
kbarnes701's Avatar
Liked: 5069
Some things do get cooler as they age. Clint Eastwood, for example ;)
RayWK likes this.
post #6577 of 13580 Old 01-11-2014, 04:40 PM
wysiwygbg's Avatar
So 130*F is like 54*C on the case, which means that the radiator under it is at least 60-65*C, and I don't like electronic devices working at over 40*C in my house smile.gif. The thing smells of brand new hardware that's running hotter than it should biggrin.gif. I will fix it for sure! I probably will even without the Service Manual. The NB S3's shouldn't put out any noise at 5V - very very silent fans smile.gif. Did you know that cooler hardware consumes less electricity to work?
wysiwygbg is offline
post #6578 of 13580 Old 01-11-2014, 05:10 PM
Liked: 3605
I actually used an infrared thermometer to read the temp of the heat sinks under the case. The case is not hot to the touch, so I am not concerned. After all, Denon puts fans inside the case to deal with overheating, and they never turn on. What does that tell us?
post #6579 of 13580 Old 01-11-2014, 05:34 PM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
geoffrsc likes this.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #6580 of 13580 Old 01-11-2014, 06:43 PM
roadking00's Avatar
Quoted: 47 Post(s)
Originally Posted by jdsmoothie View Post
1. No audio should be required.
2.. Yes.
Note, the Dell monitor will have to be capable of receiving standard TV video resolution.
Thanks JD, media room is all set waiting on the delivery this week.
roadking00 is offline
post #6581 of 13580 Old 01-11-2014, 06:51 PM
Dreamliner's Avatar
Quoted: 368 Post(s)
Liked: 125
The question of cooling comes up every few weeks. Depending on your setup, adding a fan is quite cheap insurance for a $2000+ component. Heat kills electronics.
Dreamliner is offline
post #6582 of 13580 Old 01-11-2014, 07:58 PM
wysiwygbg's Avatar
Given the fact that they don't give me 10 year warranty, but 2 years, means to me, that it is possible, that someone calculated a way for this device (and any other device with the same warranty length) to fail not long after it's guarantee is over. It's also possible they had a large delivery of fans by mistake, and had to find a place to put them, if they actually have set them to start working at too high temperatures, measured with a better than an infrared thermometer tool - my hand! Also I don't like electronics running hot here, because it's a fire hazzard - if I can keep 'em cool, I do it.
post #6583 of 13580 Old 01-11-2014, 08:24 PM
Quoted: 978 Post(s)
Liked: 506
I wouldn't go as far as saying its a fire hazard but excessive heat does shorten the life of electronics. Usually it would be failures involving transistors or capacitors, but anything can burn up to stop it from working. I have seen traces on boards burn up.
Even dust build up mixed with a little bit of humidity can cause a short as well.
The manufacturer does not calculate that "shortly a after a warranty their item is doom to fail". It's more of how long do they want the responsibly of having to take care of the cost of an item.
post #6584 of 13580 Old 01-11-2014, 08:36 PM
jdsmoothie's Avatar
Quoted: 12082 Post(s)
Liked: 5502
Ummm .. that would be 3 years actually. smile.gif And not sure about Bulgaria, but here in the states, if purchased with a credit card, the card issuer will often add an extra 4th year for free as well. smile.gif
jdsmoothie is online now
post #6585 of 13580 Old 01-11-2014, 09:28 PM
Liked: 3605
I don't know why this has evolved into an argument.  I simply expressed an opinion that I didn't think this unit runs hot.  There is certainly nothing wrong with providing extra cooling.
post #6586 of 13580 Old 01-12-2014, 05:15 AM
DougReim's Avatar
Liked: 24
That's a stretch.
If Denon designed their units, especially their higher end stuff to fail after three years they'd have gone out of business years ago I would think.
Pain Infliction likes this.
Doug
DougReim is offline
post #6587 of 13580 Old 01-12-2014, 08:40 AM - Thread Starter
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
So THAT part's the stretch but nobody's bothered by the "they got a mistake shipment of fans and had to find a place to put them" theory. tongue.gif
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #6588 of 13580 Old 01-12-2014, 09:01 AM
Quoted: 978 Post(s)
Liked: 506
+1! I forgot to touch on that subject. Yeah that sounds like a conspiracy theorists idea lol.
post #6589 of 13580 Old 01-12-2014, 12:20 PM
chutachut's Avatar
Pain Infliction and AV_mike,
Thanks for the help! I decided to go ahead and get the X4000 from a local dealer (not the same model, but may still help others). It seemed that there weren't many options to solve the issue that would cause me to get a different receiver. While they do come on almost instantly, there is a .5 sec delay between them, which is just enough that I haven't had any problems in about 20 power cycles. I do have a Harmony 900, so it's good to know there is another option if it starts acting up.
Thanks again!
Mike
chutachut is offline
post #6590 of 13580 Old 01-12-2014, 04:30 PM
kamiraa's Avatar
Liked: 31
Well I've heard a lot of discussion in the past, when to get an aftermarket amp. So I figured I would post up my real world testing results of VERY high end amps (MC275Mk6s in Mono, and MC601s Mono Blocks) vs. the built in AVR-4520ci amps.
My methodology was:
Left speaker , built in AVR-4520ci amp
Right speaker, external amps (McIntosh gear)
Level matched the Left and Right with a SPL meter
Running in pure/direct stereo mode to avoid confusion (with Audyssey Disabled, and sub-woofer turned off)
Controlled by a computer over HDMI
Using a built in audio playback software with FLACS to quickly move the Left / Right Balance to A/B the two amps.
One thing I will say, the AVR-4520ci can put out a lot of power (over 280W peak, 190W rms) in stereo mode. My speakers B&W CM9's are very efficient, so to listen at moderate volume I'm using very little power (McIntosh is saying around 3 watts RMS, and around 30 watts peak, which is trying to figure out where it falls on their log scale).
For my setup, I start noticing AVR-4502ci built in amps distortion starting at -18db, that gets unbearable by -10db, the McIntosh gear never picks up distortion all the way to 0db, it just keeps going! The louder it gets, the better it sounds!!
At around -20db before the distortion really starts, the built in AVR-4520ci built in amps are AMAZING! A/B'ing them back and forth showed very subtle details, with the McIntosh gear I could hear extra detail such as string picking, breathing, cymbals, crowd noise. It was great, but not worth the extra money at this volume (in my opinion)
At anything from -15db and down, it's night and day difference and well worth the price.
So, basically, if your room is big enough or you listen to music from -15db or louder, the stock amps can't hang in comparison to higher end gear. If your room is smaller, or you listen to lower volumes (-18 and quieter), don't worry about external amps. Not worth the price in my opinion.
This just speaks to the quality of how amazing of a deal we get with our AVR-4520ci and how well built the 9 amplifier inside the amp are!
I hope this was helpful to some!
DougReim likes this.
kamiraa is offline
post #6591 of 13580 Old 01-12-2014, 04:44 PM
Quoted: 978 Post(s)
Liked: 506
My methodology was:
Nice test and write up!
post #6592 of 13580 Old 01-12-2014, 05:21 PM
ingersol1211's Avatar
Yea, very interesting I'm curios what was the SPL when the 4520 started to distort? I can get around 105dbl when my paradigm s.6s start to sound stressed.
ingersol1211 is offline
post #6593 of 13580 Old 01-12-2014, 05:44 PM
kamiraa's Avatar
Liked: 31
Since SPL based on pressure, it will depend on the room and distance you are listening at.
For me, about 12 feet speaker to ear, it was around 82dbA.
kamiraa is offline
post #6594 of 13580 Old 01-12-2014, 06:30 PM
Thanks Kamiraa, your right so many variables involved, when I took my readings I was about 7 ft. In front of my speakers which are about 8ft. apart with a SPL meter in one hand and the remote in the other and unfortunately no hearing protection as my ears rang for awhile afterwords.
post #6595 of 13580 Old 01-12-2014, 07:14 PM
BeeMan458's Avatar
Liked: 813
Just received and got a 4520ci up and running. What are you posting about? confused.gif
I have no context to understand what you're sharing.
Tomorrow I pull out REW and start measuring the room. At this point, I'm about as uniformed and ignorant as a neophyte to the 4520 can be.
My first impressions of the 4520ci are, it's clear, clean and doesn't have as much output as a Marantz SR5008 that it's replacing. confused.gif
(i was listening at +/- 0dB and was unimpressed over that of the SR5008)
Listening to the Comcast provided, "Master and Commander" main battle scene using "Pure Direct."
At +/- 0 dB, SPL measures between 60dB and 88dB.
(again, tomorrow I start measuring the room to see if I can find out what's what with what)
BeeMan458 is offline
post #6596 of 13580 Old 01-12-2014, 07:35 PM
Liked: 3605
There is something I am not understanding about your post, and I suspect other 4520 owners will be equally concerned.
You say that you measured the 4520 as having 190W RMS power in stereo mode.  You say your speakers are very efficient, and that the McIntosh amps are only drawing 3W of power.
But then you say that the 4520 starts to distort at -18 on the MV, and becomes unbearable at -10 on the MV, and this is only at about 82dB, measured at your MLP?  How can that be so, if your speakers are so efficient?
I must say, if the 4520 amps were distorting unbearably at the modest MV levels you mention, how come we don't have hundreds of postings reporting the same findings?  As I say, I must be misunderstanding your test, because it is really very hard to believe.  :confused:
kbarnes701 likes this.
post #6597 of 13580 Old 01-12-2014, 07:43 PM
kamiraa's Avatar
Liked: 31
For movies, I listen to obviously louder, for music I listen at much lower volumes because it's just constant volume (pressure) versus a majority of talking in movies. So, I guess try the same test with your favorite kind of musical CD.
I also think it's going to depend on what kind of speaker you are listening to and if your hearing can support hearing finer detail still? It seems like a majority of the folks whom get extremely into audiophile grade equipment have "aged" ears.
I'm still younger (in my 30s), and based on tests still have extremely good hearing with fall off at 17khz. So small amounts of distortion are very apparent to me, and drive my ears nuts.
But, for some, they might not notice the differences?
I really got the McIntosh gear to support listening to music, for movies I will think that the AVR-4520ci is going to be fine at -18db.
kamiraa is offline
post #6598 of 13580 Old 01-12-2014, 07:53 PM
Zen Traveler's Avatar
Quoted: 527 Post(s)
Liked: 530
I would go in and make sure you don't have Dynamic Volume on. Fwiw, at "0" on the Main Volume after running Audyssey you should definitely be getting louder than 88 dB peaks. {Edit: They should be over 100 dB for that movie and with your speakers.}
Zen Traveler is offline
post #6599 of 13580 Old 01-12-2014, 08:19 PM
kamiraa's Avatar
Liked: 31
I must say, if the 4520 amps were distorting unbearably at the modest MV levels you mention, how come we don't have hundreds of postings reporting the same findings?  As I say, I must be misunderstanding your test, because it is really very hard to believe.  confused.gif
Hi Jerry, just some corrections from your post, the power ratings from the Denon AVR-4520ci I'm quoting are from the manual (page 202). I was never sure exactly how much power they were pulling, until I had the MC601 hooked up, I can use the McIntosh "true watt meter" to estimate how much power I'm using at that moment. I was actually surprised how little power was required, but I guess the math works out if you play around. My speakers can put out 89db with 1 watt, at 1 meter. More power is needed the further you get away from that 1 meter, and obviously different frequency ranges are going to use more power and open rooms are going to use more power to achieve the same pressure since those measurements are conducted in closed chambers.
The 82dB I mentioned in my previous post is actually recorded at -18db on the Master Volume. At -10 it's in the low 90's range at my listening distances (if I'm remembering correctly)
Just because the Denon AVR-4520ci is rated at 190W RMS does not mean it can put that out without picking up noticeable distortion along the way. Like I mentioned earlier, it's going to depend on a lot of variables. For movies I will run my volume to nearly -15db and never worried or listened for distortion. Since 90% of the movie is background low volume music scores or the actors talking. The movies only get considerably loud for short portions.
If I listen to -15db through my Oppo for music I will be going deaf one of these days. It's just two situations. I guess it's either how the track is mastered on movies versus music?
But, I can say without a doubt, at -10 my ears were hurting with playing music through the AVR-4520ci, and it sounded horrible in comparison versus either of my McIntosh gear, it wasn't subtle. It was literally as I stated, night and day difference.
If you have a local Best Buy Magnolia room nearby, I know they have the lower model McIntosh integrated MA5200, and the AVR-4520ci on their panel. Go level match them with your SPL Meter, and have the rep A/B them for you. Like I said, at lower volumes the differences are so subtle I wouldn't recommend someone to spend big money on these amplifiers, at louder volumes, it a pretty massive difference.
I've been looking for data for the real distortion numbers from the AVR-4520ci and can't find anything. But, I know the McIntosh gear is around 0.001% THD across the full power spectrum and all audible frequencies.
Since I will be going to a bigger listening room/ Theater at the next house I know I will need the extra power, so this was an early purchase to prepare.
I hope this helps. If your ever in town, your welcome to swing on by.
kamiraa is offline
post #6600 of 13580 Old 01-12-2014, 08:20 PM
kamiraa's Avatar
Liked: 31
Or any offset on.
kamiraa is offline
Denon Avr 4520ci Receiver
