The **OFFICIAL** DENON AVR-4520CI thread - Page 247 - AVS Forum | Home Theater Discussions And Reviews
 863Likes
post #7381 of 13580 Old 03-17-2014, 07:59 PM
AJC71's Avatar
Originally Posted by kbarnes701 View Post
Absolutely. I certainly wouldn't want a new unit that wouldn’t let me upgrade to an object-based sound system though. Not this close it becoming reality.  Not that I need a new unit anyway at this time, but I will certainly be interested in seeing what this Fall brings.
Great, and after I just my 4520ci. Maybe they will have an upgrade for it ? Won't hold my breath..... rolleyes.gif
AJC71 is offline
post #7382 of 13580 Old 03-17-2014, 08:07 PM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Originally Posted by Tel9000 View Post
Question--
I have my 11.2 system wired up and I'm looking at this receiver to run it. I plan to use the preouts with my Rotel amps to drive the 7 main channels. I would like to use the on board amp in this receiver to power my front wide and height channels. Are the amps assignable to those channels? Will this work? Thanks for any input.
Yes you can assign amps. I do the exact thing.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #7383 of 13580 Old 03-17-2014, 08:13 PM
Tony Wilkins 99's Avatar
Quoted: 14 Post(s)
General question but since I have a 4520 I'll ask it here.
Do you guys find there is a point in number of channels where you find a 'speaker too far'?
Right now I'm just running a basic 5.1 from mine along with a second zone for my porch.  Just wondering how much I gain going to 7.1, to 9.1, or even 11.2.
Tony Wilkins 99 is offline
post #7384 of 13580 Old 03-17-2014, 08:56 PM
sathron's Avatar
I'm looking for an opinion from the group...I have had the AVR-4810ci for 4+ years and do love it. This is a replacement for the AVR-5803 which I had for 6 years. Is the 4520 a worthy "update" over the 4810. I know the 4520 has pass thru for 3d which is great (vs running a separate HDMI to my TV as I like the OSD and great up scaling from the Denon) but I am really intrigued by * Audyssey MultEQ XT32 + SubEQ HT room correction.
Just a little info which may help...I am running 9.1 (height) with an Oppo BDP-93, Samsung 55" F8000 (2D and 3D) with a HSU ULS-15, and Polk speakers FR, C FL, ,SR,SL,SBR,SBL,FHR, FHL with an Emotva XPA-5 driving the main 5...the 4810 drives the front height and the surround backs.
Again, I'd like any opinions, especially those that may have had the 4810 prior to the 4520.
Thanks in advance!
sathron is offline
post #7385 of 13580 Old 03-17-2014, 09:01 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6525 Post(s)
Liked: 3615
Thanks in advance!
I had a 4308, which is also a MultEQ XT Receiver, and the difference between XT and XT32 makes the upgrade very worthwhile, IMO.
AustinJerry is online now
post #7386 of 13580 Old 03-17-2014, 09:05 PM
Quoted: 978 Post(s)
Liked: 506
Thanks in advance!
Maybe wait a little bit longer for October to roll around and get the newest model. That's what I would do if I was you.
post #7387 of 13580 Old 03-17-2014, 09:06 PM
Quoted: 978 Post(s)
Liked: 506
I personally loved going from 7.1 to 11.2! The sound field was so much more realistic sounding for lack of better words.
post #7388 of 13580 Old 03-17-2014, 11:08 PM
Woof Woof's Avatar
Quoted: 127 Post(s)
Liked: 79
I was using 11.2 in a small ish room but for action movies, I found the addition of wide channels very noticeable. Heights isn't as directional to me but it does add a lot more ambience that is noticeable when you turn it off.
7.1 to me is almost a given these days, especially since many movies already support a native 7.1 soundtrack.
Woof Woof is online now
post #7389 of 13580 Old 03-17-2014, 11:17 PM
Woof Woof's Avatar
Quoted: 127 Post(s)
Liked: 79
Thanks in advance!
I had the 4810 for ages before deciding to go with the Marantz AV8801. I was already using the 4810 as a pre pro supplying only power for the height channels (with external power amps for all the other channels). I had a spare set of Bel Canto REF1000Ms that I had lying around but was too lazy to put it in. But as I was going to add the AV8801, I decided to bite the bullet and add the Bel Cantos in to power the surrounds and using one of my other amps to drive the heights.
There is IMHO a noticeable upgrade going from the 4810 to the 8801. Maybe that might be a path more suitable.
I found improvements even before running Audyssey XT32 (I was running w/o EQ on the 4810 after a firmware update for a long time).
post #7390 of 13580 Old 03-18-2014, 03:14 AM
jdsmoothie's Avatar
Quoted: 12119 Post(s)
Liked: 5518
The recommendation by Audyssey when expanding from 5.1 to 7.1 is that adding Front Wides will provide the best experience, followed by Front Heights and lastly by rear surrounds. Although not possible in many rooms due to either room setup or WAF, using Front Wides is much more surround enveloping.
jdsmoothie is online now
post #7391 of 13580 Old 03-18-2014, 09:09 PM
sathron's Avatar
I have read so many good things about Marantz...it truly is a beast! I just can't get over the look...some people like that port hole display, but I am not a fan. I wish I could find something with the features and build quality of the Marantz 8801, but the display of the Denon 4810....
sathron is offline
post #7392 of 13580 Old 03-18-2014, 09:28 PM
Woof Woof's Avatar
Quoted: 127 Post(s)
Liked: 79
You do realise there's a display that is the same as the 4520 when you lower the front flap, right?
I like the discreet Marantz look, having gotten used to it over time. I like that in my HT room, it produces less stray light in the room even when I don't turn the display off, so I can see the input at a quick glance. I've even turned off the blow halo light smile.gif
post #7393 of 13580 Old 03-18-2014, 09:44 PM - Thread Starter
batpig's Avatar
Quoted: 3571 Post(s)
Liked: 3418
Um, that's the 4520. The Marantz is just a pre/pro version of the same exact platform. There is zero difference in features beyond the missing amps and the balanced connection option.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #7394 of 13580 Old 03-18-2014, 09:47 PM
sathron's Avatar
Batpig....if I recall, you once had the 4810...how do you like the 4520?
sathron is offline
post #7395 of 13580 Old 03-18-2014, 09:53 PM - Thread Starter
batpig's Avatar
Liked: 3418
You recall incorrectly smile.gif I have owned neither of those units.
Setup Guide and FAQ
post #7396 of 13580 Old 03-19-2014, 12:38 AM
SeattleHTGuy's Avatar
Liked: 55
I have had the 4810, the 4311, and now the Marantz 8801. Frankly, for me the 4810 was crazy problematic. The 4311 was "da bomb" and now the 8801 is simply rock, rock solid. The 8801 is not insane levels of "better" than the 4311. The 4311 is really that good. Still prefer the new toy and the somewhat better GUI and far better XLR connections but really, a used 4311 is still flat out hard to beat if you don't covet all the 4K hullaballoo!!!
SeattleHTGuy is offline
post #7397 of 13580 Old 03-19-2014, 01:31 AM
Woof Woof's Avatar
Quoted: 127 Post(s)
Liked: 79
And Neo X.
And LFC
post #7398 of 13580 Old 03-19-2014, 01:26 PM
ril850's Avatar
Quoted: 64 Post(s)
Liked: 29
Hello everyone,
question on playing dsd tracks in Pure Direct or Direct? My 4520 only shows left and right channels active, but I want my sub to come on also. Only way I have found to achieve this, is by the setting the speakers to LFE+Main or by using "Stereo". I'm using my B&W 602 S3's for my L & R channel, I really hate having to switch back and forth for music and movies. I currently have my mains set to small and LFE for bass only. I just think the sound is thin when playing in 2.0 vs. 2.1. Any ideas would be welcomed.
Life is what you make it.......
ril850 is online now
post #7399 of 13580 Old 03-19-2014, 02:21 PM - Thread Starter
batpig's Avatar
Liked: 3418
Direct modes bypass bass management so the only way the sub will play with stereo music is by enabling "double bass" / LFE+MAIN. That's just how it works.
Setup Guide and FAQ
post #7400 of 13580 Old 03-19-2014, 02:32 PM
ril850's Avatar
Quoted: 64 Post(s)
Liked: 29
Thanks, Batpig.
I've seen your website. Awesome by the way. I got the sub to come on with LFE and Mains small, by using "Stereo". Do I lose any sound quality, besides not being able to see DSD on the front display.
post #7401 of 13580 Old 03-19-2014, 02:35 PM
Selden Ball's Avatar
Quoted: 3065 Post(s)
Liked: 1497
To put it another way, the Stereo option enables audio processing, including bass management. That redirects the frequencies below the crossover to the subwoofer. Since Direct sounds "thin" in comparison, the implication is that your speakers in your room really can't provide the bass extension needed by whatever music you're playing.
In other words, don't use Direct.
Edited to add: in general, leaving the audio processing enabled, including Audyssey, should produce a more accurate reproduction of the soundtrack in your room. However, you might want to investigate your settings for Dynamic EQ and Reference Offset. Unlike movies, music isn't recorded to a standard sound level, so different recordings benefit more from different values.
Selden
Selden Ball is online now
post #7402 of 13580 Old 03-19-2014, 02:47 PM
mercury's Avatar
Liked: 101
just recieved my 4520CI hooked everything up and have started the learning process.... out of the box with a HD cable movie and some low playing digital music the sound appears to be a step up on my pioneer vsx-03txh.....
running a 5.1 system with psb speakers and dual psa xs30's... i guess a 5.2 system.
ril850 likes this.
Panasonic 65" plasma*
Denon 4520*
PSB T45* PSB B15* PSB C60*
Dual PSA XS30* Dual PSA XS15se*
Squeezbox*
Niles ZR-6 6 Source, 6 room Audio Reciever*
mercury is offline
post #7403 of 13580 Old 03-19-2014, 03:08 PM
ril850's Avatar
Quoted: 64 Post(s)
Liked: 29
Same here!
post #7404 of 13580 Old 03-20-2014, 01:08 AM
ril850's Avatar
Quoted: 64 Post(s)
Liked: 29
I'm not sure what I did or didn't do, but my ARC is no longer working on either monitor 1 or 2 going to my Panasonic ST60. I'm not sure if it was the Panasonics recent firmware that broke it? I'm supposed to set the Denon to TV Audio right? Ughhh so annoyed, any ideas. Tried switching HDMI cables already and they are all working fine.
post #7405 of 13580 Old 03-20-2014, 02:22 AM
jdsmoothie's Avatar
Liked: 5518
No setting change should be made to the "HDMI Audio Out" setting as it should be left at its default of "AVR" as this is only used while the AVR is powered on and you want to pass the audio from the HDMI source to the "TV" (eg. when there are no speakers connected). For HDMI(ARC) to work correctly, HDMI Control must be enabled on the AVR and VieraLink must be enabled on the TV as well as the TV set to send audio to "Home Theater". Also try resetting the TV by powering OFF and unplugging for 10 minutes..
post #7406 of 13580 Old 03-20-2014, 07:29 AM
mercury's Avatar
Liked: 101
Silly question...
in a basic 5.2 set-up to i assign the surounds as-
surrounds-
or
sourounds back
Denon 4520*
Squeezbox*
mercury is offline
post #7407 of 13580 Old 03-20-2014, 07:37 AM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
Surrounds
just 1 more pair of KLIPSCH Classic speakers...
RED AND BLUE=MAROON!
PANASONIC 60" PLASMA 3D, DENON AVR-3312CI, LG BD670 3D NETWORK BRD (iPhone APPs), TOSHIBA HD-XA2 HD DVD, SAMSUNG BD-UP5000 HD DVD/BRD, iPod 8 GB, 13.2: KLIPSCH La Scala 1980 (Crites Rebuilt Type AA Crossovers Sonicaps) FRONT, HERESY II "SIGNATURE EDITION" WIDE, HERESY II CENTER/SURROUND, kg2 SB, kg3/kg1 Front/Rear HEIGHT, RW-12d SW, km-rsw
SanchoPanza is offline
post #7408 of 13580 Old 03-20-2014, 08:24 AM
ril850's Avatar
Quoted: 64 Post(s)
Liked: 29
Thanks, JD I'll give it a try.
Have another question for the thread here. If I want to upscale the signal from my cable box yet leave the video signal from my Oppo 103 untouched and just have it pass through, is that possible. I currently have all "Video Conversion" set to "Off".
post #7409 of 13580 Old 03-20-2014, 11:36 AM
ril850's Avatar
Quoted: 64 Post(s)
Liked: 29
No luck, its driving me nuts, I just reset my TV and still nothing. I know everything is wired correctly. My next option is resetting the receiver, but I really don't want to run Audyssey again. How do I restore to factory defaults?
post #7410 of 13580 Old 03-20-2014, 11:47 AM
ril850's Avatar
Quoted: 64 Post(s)
Liked: 29
Originally Posted by chi_guy50 View Post
Thanks, batpig.  You pretty well confirmed my previous understanding.
So is that graphic you supplied the one viewable on the 4520 (showing in/out channels) or not?  (Your last sentence left me a bit confused).
Crap, I just saw this and asked on the same thing on your youtube video. That sucks, but now I know at least.
Denon Avr 4520ci Receiver
