The **OFFICIAL** DENON AVR-4520CI thread - Page 251 - AVS Forum | Home Theater Discussions And Reviews
 865Likes
post #7501 of 13617 Old 03-27-2014, 04:26 PM
OzHDHT's Avatar
Quoted: 861 Post(s)
Liked: 466
Originally Posted by AustinJerry View Post
If the objective is analyzing your room response and arriving at possible improvements, the other thread is the right place for the discussion. Your issue is not an issue with the Denon AVR, per we, so it is a little OT to discuss it here. JMO.
Yes Jerry, sorry not disputing the reasoning for taking it into the specific REW thread at all. Just saying I already had pointed out I really didn't want to spend days and days on this room issue affecting Audyssey as I'm just about out of patience having spent the last month and bit bit playing with both ARC and now Audyssey pretty much non-stop. You could say I'm kind of over it as much as I love the HT hobby.
OzHDHT is online now
post #7502 of 13617 Old 03-27-2014, 10:10 PM
ril850's Avatar
Quoted: 106 Post(s)
Liked: 34
I ran into something tonight by accident but it answered two issues I was having. When I power up my Pan ST60, Oppo 103 and Denon 4520, the receiver has no sound when I play the movie or music that was previously playingd, stereo or any of the surround codecs. The way around it was usually by restarting the receiver. So it happened again today and I was only getting sound from the tv speakers and I thought well let me press the apps button, then go to viera link and turn on receiver speakers and wala the av receiver sound came through. Then I switched over to YouTube app on tv and I had sound going to the receiver as it should. I was having issues before, getting ARC to work properly with TV audio much less go through Denon HDMI. So basically what I'm seeing is my set up is defaulting to tv speakers. How do I keep this from happening? Turn viera link completely off? I like some off the hdmi cec features, but to get everything to work properly seems more trouble than it's worth.
Life is what you make it.......
ril850 is online now
post #7503 of 13617 Old 03-28-2014, 03:49 AM
jdsmoothie's Avatar
Quoted: 13164 Post(s)
Liked: 6083
As many find, turning HDMI-CEC OFF on the TV and using an optical cable from the TV to the AVR is generally a better solution.
jdsmoothie is online now
post #7504 of 13617 Old 03-28-2014, 08:28 AM
stef2's Avatar
Quoted: 380 Post(s)
Liked: 232
Is it possible to play video from one source and audio from a different source on the 4520?
I know this function exists on other denon AVRs (the video select function) , but I cant seem to find it on the 4520.
My goal is to watch family pictures using my oppo player (hdmi) while listening to music played by my sonos player (digital coaxial)...
stef2 is offline
post #7505 of 13617 Old 03-28-2014, 08:35 AM
jdsmoothie's Avatar
Liked: 6083
Yup, p. 138 Owner's manual, although only works with analog video sources (eg. component).
post #7506 of 13617 Old 03-28-2014, 08:50 AM - Thread Starter
batpig's Avatar
Quoted: 3648 Post(s)
Liked: 3489
You can also assign the optical input of the Sonos to the same input as the Oppo and then set input mode to "digital" to override the HDMI audio and force the optical audio.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #7507 of 13617 Old 03-28-2014, 02:35 PM
stef2's Avatar
Quoted: 380 Post(s)
Liked: 232
Thanks to both of you!
I tried what batpig suggested and it worked like a charm...
stef2 is offline
post #7508 of 13617 Old 03-28-2014, 06:21 PM
mercury's Avatar
Liked: 101
Hello. my 2-3 week old Denon 4520CI seems to keep powering on then off. on then off. on then off... i finally had to unplug it. highly douptfull it's any type of speaker connection doing this as i use bananna plugs and everything was fine-
any thoughts??
Panasonic 65" plasma*
Denon 4520*
PSB T45* PSB B15* PSB C60*
Dual PSA XS30* Dual PSA XS15se*
Squeezbox*
Niles ZR-6 6 Source, 6 room Audio Reciever*
mercury is offline
post #7509 of 13617 Old 03-28-2014, 07:11 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7025 Post(s)
Liked: 3923
Yes. Unplug everything. See if the behavior persists. If no, then start plugging things back in one-by-one. If yes, try a hard reset.
AustinJerry is online now
post #7510 of 13617 Old 03-28-2014, 07:13 PM
mercury's Avatar
Liked: 101
Thanks. yes. unplugged everything and still turns on/off.... will look up hard reset-
thanks-
Denon 4520*
Squeezbox*
mercury is offline
post #7511 of 13617 Old 03-28-2014, 07:32 PM
mercury's Avatar
Liked: 101
Ok... after disconectting all hook-ups and confirming the problem was still there i performed a Microprocessor Reset.... it seemed so far to work.
ill let it sit tonight and start re-hooking everything up Sat morning-.
any idea why this happened???
ill keep you posted-
thanks and have a good evening.
Denon 4520*
Squeezbox*
mercury is offline
post #7512 of 13617 Old 03-28-2014, 10:55 PM
OzHDHT's Avatar
Quoted: 861 Post(s)
Liked: 466
Well using Jerry's guide and 'futzing' around with REW is proving to be just as bigger a p.o. on my Sat afternoon as I'd anticipated. The guide's great, but I simply can't get my ASIO4All driver to switch on my UMIK-1. All I can do is get left channel measurements in of the front speaker that's it. If I thought I was at my limits of patience already, I've now officially reached it. I have yet another limited amount of time while my gf is out to make measurement then try to get on that REW thread and post , then wait for learned responses to somehow point me in the direction of doing something with my room to get this 4520 measuring properly...It ridiculous but I almost feel like pulling that damn MRX out and stuffing around with ARC graphs again to see if it measures similarly and it's active measurement mode could more quickly pin point the room issues..I seriously doubt I'll do that though as I don't have the time.
post #7513 of 13617 Old 03-29-2014, 07:33 AM - Thread Starter
batpig's Avatar
Liked: 3489
ASIO is very buggy. I have the same thing you do and haven't yet had time to troubleshoot any further. Some folks say that uninstalling and then reinstalling can cure the blues.
For now I'm using the simple analog method with a mini jack to RCA stereo cable from the headphone jack of my computer. With an RCA splitter on the end you can also measure L + R together or C using PLII Cinema.
Setup Guide and FAQ
batpig is offline
post #7514 of 13617 Old 03-29-2014, 08:32 AM
mercury's Avatar
Liked: 101
well unfortunitly my 4520CI is showing the same problem this AM.... turns on then off on then off. iv'e done the reset iv'e changed outlets and iv'e unhooked everything-
ill keep the forum posted!
Denon 4520*
Squeezbox*
mercury is offline
post #7515 of 13617 Old 03-29-2014, 08:49 AM
jdsmoothie's Avatar
Liked: 6083
Is the unit connected to a power strip? If yes, disconnect and try connecting directly to the outlet to rule out a defective power strip.
post #7516 of 13617 Old 03-29-2014, 09:06 AM
mercury's Avatar
Liked: 101
Thanks JD..... tried that-
the reset i did was holding down the power button + info + back.
is that the correct method.?
Denon 4520*
Squeezbox*
mercury is offline
post #7517 of 13617 Old 03-29-2014, 09:45 AM
jdsmoothie's Avatar
Liked: 6083
Yes, as noted in post #3 of this thread, there are actually three different resets that you can do on the 4520CI ....
post #7518 of 13617 Old 03-29-2014, 02:23 PM
harrybnbad's Avatar
Quoted: 58 Post(s)
Originally Posted by laulau View Post
I don't do any home automation myself, but anyone doing so with Crestron might be interested in this bit of news:
http://www.soundandvision.com/content/crestron-home-automation-integration-now-available-select-denon-and-marantz-receivers
Crestron Connected ???? ok. That sounds great. If I only knew why. Other than climate, light and shade, etc, that type of automation. Looking at their web site I see media players. REALLY? Like what....I'd love to connect zone 2 and 3 and even 4 with a Ethernet cable and have audio and video sent to my other zones. I'm sure i'm miss reading something here. I seem to do that a lot. While, yes, it would be nice to control lighting with lets say my 4520 avr. But seems like my harmony remote can already do that. I know.....Give it time. I'll be amazed at what options will come...RIGHT?
harrybnbad is offline
post #7519 of 13617 Old 03-29-2014, 02:37 PM
harrybnbad's Avatar
Quoted: 58 Post(s)
I started messing with zone 4 once. So I could watch the same program on my porch as in the living room....( there's no cable box on the porch) It worked almost. And THEN. Lost audio inside. Almost fixed that. Lost picture outside. Almost got that, then the audio out was gone. Then I disconnected the wire. (hdmi) and put it all back together. I'm not giving up my 11.2 audio for that crap.....Now grant you. I feel if the outside tv was more up to date. DVI input and not hdmi. I thought by using another avr as a in-between would work. I didn't think it would matter. I even tried a tv with hdmi for about 2 minutes. But by then, I was giving up. Not to mention, the wife saying how much longer crap.......
So....I'd like to know.
How do others use the other zones. With what equipment do you guys use. For the most part. I have everything stored on my pc. CAT-6 though all my walls. WD live plays everything great though the 4520 into my tv. I even get 7.1 audio. Of course, it don't quite match the Blu-ray. Close though.......But to do anything else, not really sure what to get. Or how to start. Then I read, only to use hdmi with zone 4. Well that really puts limits on things. Don't it???????? So lets say, zone 2. I want to send music to my pool. How would that be done, and what equipment do I need to add. Can I play the music I can play from my pc, though the cat-6, on zone 2......?????
Sorry. I just read this. I'll stop
post #7520 of 13617 Old 03-29-2014, 07:08 PM
OzHDHT's Avatar
Quoted: 861 Post(s)
Liked: 466
Glad I'm not alone with a true Denon expert such as yourself running into the ASIO driver issue. I could always do the same and stick a mini jack to RCA cable into my HTPC's analog output. It's odd as I had the driver installed only weeks ago and working perfectly with the Dirac Live demo. I'm going to give that a shot later on when I have more time to devote to another HT session. Also going to try a tip passed on to another owner in the REW thread who has same freq measurement probs as me and try some more radical forward mic placement to see whether Audyssey's crossover settings change. Very easy to do, so what the heck eh.
EDIT: Well after much time spent messing around with REW. I came up with a simple feature I should check on all of my Revel speakers.. the built in bass compensation switch. Sure enough when I checked I quickly noticed I'd set all 3 front speakers to 'boundary compensation'. I put them back to normal, not even 'countour' mode (for extreme room modes) and bingo Audyssey issue gone, it now ,measures the L+R as full range. Funny, I had been pushing for a simpler solution than time wasting sessions with REW and sure enough I found it. Pity more people familiar with this kind of speaker tech as featured on my Revels aren't around browsing this thread wink.gif
post #7521 of 13617 Old 03-29-2014, 08:56 PM
mercury's Avatar
Liked: 101
UPDATE... after contacting accessories4less i was told to contact Denon-. I would have thought accessories4less would have handled the warrenty considering it's less then 3 weeks old. anyhow-. ill contact Denon and keep the forum posted.
although not sure if i should go for a full refund and buy retail or let Denon handle it.
any thoughts on how Denon's customer service is.?
PLEASE NOTE. Accessories4less has an exclusive agreement with Marantz, Denon & Boston Acoustics for exchanges. In the unlikely event that you have a product from one of these manufacturers fail within 30 days of date of purchase, they will exchange it for you FREE OF CHARGE. When you contact them, just let them know you purchased the item from Accessories4less and they will assist you with the exchange. This is NOT a repair situation.
Denon 4520*
Squeezbox*
mercury is offline
post #7522 of 13617 Old 03-30-2014, 03:55 AM
jdsmoothie's Avatar
Liked: 6083
Although the replacement for the Denon 4520CI is not due out until late fall, for a limited time (March 30 – April 26), Denon is lowering the MSRP on each of the Denon 4520CI and the DBT-3313UDCI BDP, whether purchased together or separately. Call for pricing.
ril850 likes this.
post #7523 of 13617 Old 03-30-2014, 03:57 AM
jdsmoothie's Avatar
Liked: 6083
D&M started doing this a couple of years ago as many of the returns that AC4L was getting back were due to operator error.
post #7524 of 13617 Old 03-30-2014, 12:00 PM
Schwa's Avatar
Quoted: 1068 Post(s)
Liked: 1132
Thanks JD for the great deal -- and for the heads-up on the deal! I'm loving my new 4520Ci and 3313UDCI -- so glad to be rid of my buggy Onkyo.
Schwa is online now
post #7525 of 13617 Old 03-31-2014, 03:27 PM
Liked: 3923
I would like to use the rear USB port to power a MiniDSP.  It took me a bit of time to find out where to select the rear USB port, but I am good now.  I have several questions:  Is the USB port active when the AVR input selector is on a different input from "iPod/USB"?  I seem to recall that some are using the rear USB to run a cooling fan, so I suspect it should be sufficient power for the MiniDSP, correct?  And does the USB port power down when the AVR is turned off?
post #7526 of 13617 Old 03-31-2014, 03:49 PM - Thread Starter
batpig's Avatar
Liked: 3489
I believe the port is powered even if you aren't on that input. For example if I plug my iPod into my X4000 it will still charge even if I'm not on the iPod/USB input.
If the 4520 works like my X4000 the USB port will still be hot when powered down to standby if the IP Control setting is set to always on. The network and USB functions are linked somehow.
Setup Guide and FAQ
batpig is offline
post #7527 of 13617 Old 03-31-2014, 04:02 PM
Liked: 3923
Thanks, BP.  I didn't associate the network and USB functions.  I'll give it a test.
post #7528 of 13617 Old 04-03-2014, 07:53 AM
dceaddy's Avatar
Gentlemen i would like to try headphones with the 4520. I am thinking about the sennheiser hd 650. What do think about them. One problem is the cable length. My sitting position is about 12 to 14 feet from the 4520. I have had no luck finding a cable that long. Can someone point me to where i can find a cable that long are should i consider wireless headphones.
dceaddy is offline
post #7529 of 13617 Old 04-03-2014, 08:52 AM
chi_guy50's Avatar
Quoted: 1404 Post(s)
Liked: 995
You could go wireless or use an extension cable, such as this one available in various lengths.  There are pros and cons either way, but at 12 to 14 feet you should be alert to trip and fall risks posed by the cord.
I'm not a headphones aficionado, but Sennheiser makes some excellent products.  I've got the HD 380 Pro, which appealed to me for its transportability (it's collapsible and comes with a nice carrying case), and I am very pleased with it.
Living Room: Sony XBR-65Z9D UHD LCD TV w/FALD; Oppo UDP-203; Sony BDP-S5200 (multi-region); Denon AVR-X5200W (Video: Dolby Atmos/DSU 7.1.4; Music: DTS Neo:X 11.1); Dayton Audio MA1260 12-Channel Amplifier (60wpc); Polk Audio RTiA7 (F/LR), CSiA6 (C), RTiA5 (FW), OWM5 (Sr, SB), 80F/X-RT (FH, TR); SVS SB-2000 (SW)
Bedroom: Sony XBR-55HX929 LCD HDTV w/FALD, DarbeeVision DVP 5000S, Yamaha R-N402 Network Receiver, Polk Audio LSiM703
chi_guy50 is offline
post #7530 of 13617 Old 04-03-2014, 09:29 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3429 Post(s)
Liked: 3406
I've got a Sennheiser shotgun mic for my camcorders that has worked extremely well for years ! They make great stuff!
Anyone that has been on the fence about buying a 4520 - now is the time for sure ! smile.gif
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
Denon Avr 4520ci Receiver
